How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
96 registered members (aquariuscsm, 1978elcamino, 69Torino, 4WD, 94astro, 9 invisible), 2,283 guests, and 59 spiders.
Topics286,018
Posts4,900,861
Members67,548
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Makita polisher/buffer pads... #4494958
08/22/17 07:09 AM
08/22/17 07:09 AM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
went ahead with this now need a rec on 7" pads...not sure what or where to buy? imagine I'd need applicator and buffer pads...tia
Makita 9237CX2
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Makita polisher/buffer pads... [Re: dblshock] #4494962
08/22/17 07:15 AM
08/22/17 07:15 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Lake Country pads for cutting/polishing - be careful.
You do not apply wax/sealant with a rotary.
"Zed's dead baby, Zed's dead."
Re: Makita polisher/buffer pads... [Re: dblshock] #4494970
08/22/17 07:30 AM
08/22/17 07:30 AM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
no application? I see they make like a foam pad what's that all about?
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: Makita polisher/buffer pads... [Re: dblshock] #4494974
08/22/17 07:36 AM
08/22/17 07:36 AM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
I don't even know what 'cutting pad' means...lol and the Lake Country pads are 6.5" does that work?..sorry for all the q's.
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: Makita polisher/buffer pads... [Re: dblshock] #4494985
08/22/17 07:54 AM
08/22/17 07:54 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Honestly, I recommend you cancel the order. With your level of knowledge it is very likely you will damage your paint. Start with a Random Orbital. Griot's makes a very nice one with a lifetime warranty for a few bucks less. They also sell kits complete with everything you need - including a basic introduction to what you are trying to achieve.
Lake Country Cross Cut Rotary Pads
You do not apply a wax or sealant with a rotary - that's like trying to paint a picture with a hammer.
Re: Makita polisher/buffer pads... [Re: dblshock] #4494986
08/22/17 07:55 AM
08/22/17 07:55 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
While not the same brand this might help you
I will let the pros answer your questions. I am just a basic DA using amateur.
Rotary scares me too much for any good car. I'd rather be slow.
Re: Makita polisher/buffer pads... [Re: rooflessVW] #4494988
08/22/17 08:11 AM
08/22/17 08:11 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
+1
DA is a good place to start if you have no knowledge and you should read up on how to's and techniques.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Makita polisher/buffer pads... [Re: dblshock] #4495129
08/22/17 11:36 AM
08/22/17 11:36 AM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
well I'll have to learn on the fly cause it shipped..mainly wanted it for waxing/buffing car paint...it does go slow (variable)
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: Makita polisher/buffer pads... [Re: dblshock] #4495145
08/22/17 12:04 PM
08/22/17 12:04 PM
Port Aransas, TX
Stevie Offline
Stevie  Offline
Port Aransas, TX
I recommend that you tape all edges so you don't burn through.
Re: Makita polisher/buffer pads... [Re: Stevie] #4495269
08/22/17 02:14 PM
08/22/17 02:14 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
For $20 you can get a wax spreader and remover at WM. Let the machine and product do the work instead of your arms. Use the foam bonnet to apply the wax or sealant. Then switch to the microfiber bonnet for removal.
The rotary that you have will do a good job of polishing. Which is what gets rid of scratches, microscratches, spider webbing and swirls. When starting out use it on one of the lower speeds and that should keep you out of trouble.
You can also by some door skins or hoods cheaply at the junk yard to practice on. Start out on a small area. Buff off with a plush microfiber. Then wipe with rubbing alcohol to remove the oils from the polish.
Re: Makita polisher/buffer pads... [Re: dblshock] #4495288
08/22/17 02:31 PM
08/22/17 02:31 PM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
Thanks for the replies and heads-up..I see pads for applying cleaner/wax (no cutting) will be sure to go slow and keep cool.
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: Makita polisher/buffer pads... [Re: dblshock] #4495293
08/22/17 02:39 PM
08/22/17 02:39 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Cut refers to how much bite the pad has to help get rid of defects in the paint. Always start with the least aggressive method since the paint is razor thin. As well as the clear coat.
The most aggressive cut would be wet sanding, followed by compounding with a rotary. Polish is a step down in aggressiveness compared to compound. Meguiars Ultimate Polish would be a good start. An All in One contains a little polish and sealant, AIO. So a one step product. HD Speed is available on Autogeek. One of the guys on here recently used some of it. I'll see if I can find the thread.
https://bobistheoilguy.com/forums/ubbthr...ail#Post4435774
Re: Makita polisher/buffer pads... [Re: dblshock] #4495300
08/22/17 02:51 PM
08/22/17 02:51 PM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
wow..like anything you can go over the top here too.
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: Makita polisher/buffer pads... [Re: dblshock] #4495301
08/22/17 02:55 PM
08/22/17 02:55 PM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
just bought a 32oz. HD Speed..like a good bourbon buck an oz. cool
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Re: Makita polisher/buffer pads... [Re: dblshock] #4495311
08/22/17 03:06 PM
08/22/17 03:06 PM
WI.
dblshock Offline OP
dblshock  Offline OP
WI.
Here a guy cleans-up a headlight using a 3M 05723 compounding pad..is that a cutter?
headlight
05723 compunding pad
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Page 1 of 3 1 2 3
