White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
20 registered members (billt460, c502cid, Char Baby, DaleRider, 3 invisible), 796 guests, and 30 spiders.
Topics296,866
Posts4,960,386
Members66,982
Most Online2,688
Jan 19th, 2019
Cruze 1.4 turbo #4494824
08/21/17 08:16 PM
08/21/17 08:16 PM
Washington
Dylan1303 Offline OP
Washington
Just picked up a cruze 1.4t rs package and 6 speed. Has 81k miles. Oil pan gasket weeping pretty good in 1 corner. And some mystery leak by the pulleys. Not coolant or freon. It is a oil leak. But the main question is i want to use pphm or val full syn maxlife. Witch one and why? Valv carries dexos but thats not to big of a deal for me unless im missing something important about the dexos approval.
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
13 equinox 2.4 awd pp 5w30
Re: Cruze 1.4 turbo [Re: Dylan1303] #4494825
08/21/17 08:17 PM
08/21/17 08:17 PM
Washington
Washington
Also car had 5-8k oil changes on carfax at dealer i bought it from with mobil 1 syn.
Re: Cruze 1.4 turbo [Re: Dylan1303] #4494828
08/21/17 08:20 PM
08/21/17 08:20 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
What year is it? Should have a 5 year100k mile powertrain warranty that covers oil leaks.
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Cruze 1.4 turbo [Re: Dylan1303] #4494831
08/21/17 08:23 PM
08/21/17 08:23 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Snug up oil pan bolts and run the dexos1 maxlife
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Cruze 1.4 turbo [Re: Dylan1303] #4494833
08/21/17 08:24 PM
08/21/17 08:24 PM
Texas
4WD Offline
4WD  Offline
Texas
Has it had a trans drain/refill ? - they are hard on ATF ... so bad the ATF will look like old motor oil ...
Re: Cruze 1.4 turbo [Re: Nick1994] #4494845
08/21/17 08:39 PM
08/21/17 08:39 PM
Ontario
silverrat Offline
silverrat  Offline
Ontario
Where are you getting the 100k mile figure from?
2014 Mazda3 Sport Hatch
Long Live the Manual Transmission drive
Re: Cruze 1.4 turbo [Re: Dylan1303] #4494848
08/21/17 08:45 PM
08/21/17 08:45 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
5-8K on full syn will have hopefully protected the engine and turbo well enough that you won't have any huge problems. I've been running Synpower (not Maxlife) on 5K intervals in mine since new and it's at 99,850 right now. Mine has only recently developed its first leak of any consequence, at one of the cam phaser covers above the belt drive, but I believe oil pans have been known to leak on these. Snug up bolts and see if it does any good.
There's an extended warranty on the water pump to, if memory serves, 150K/10 years. The 1.4T doesn't respond well to being out of tune or run on poor fuel - check your air filter, plugs, etc. and keep it all tip-top (40K and 60K intervals, I believe) and if you aren't already start running 89 or premium fuel and I'm sure you'll feel the difference. Mine's a '13 stick shift and I'm very pleased with it, but I've maintained it to a T. The only repair it's needed is the water outlet (common), but the valve cover with integral PCV valve is known to give up before 100K. Auto's are hard on fluid, and the manuals came filled with barely enough of a poor lube which starved some bearings and, of course, kaboom, but Amsoil synchromesh pretty much solves all that.
If you aren't already on it I'd sign up on Cruzetalk.com - plenty of good info on the care and feeding of your Cruze there.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Cruze 1.4 turbo [Re: silverrat] #4494850
08/21/17 08:46 PM
08/21/17 08:46 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
The warranty booklet... 5 yr./100K
Re: Cruze 1.4 turbo [Re: silverrat] #4494853
08/21/17 08:49 PM
08/21/17 08:49 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
2015 and older Chevys are 5 year/100k miles. 2016 and newer are 5 year/60k miles.
Re: Cruze 1.4 turbo [Re: Alex_V] #4494856
08/21/17 08:59 PM
08/21/17 08:59 PM
Texas
4WD Offline
4WD  Offline
Texas
On 1.4T the PCV is part of the composite valve cover. Around the subject mileage it is prudent to get one ($100 on Amazon) - an easy change - have a look at top end.
Having said that - at 80k I asked the dealer about the PCV life expectancy- he said bring it in and the mechanics will check it out. They replaced valve cover/PCV - and all the plumbing tied to the engine ventilation system.
No charge. Car ran better.
Re: Cruze 1.4 turbo [Re: Dylan1303] #4494867
08/21/17 09:24 PM
08/21/17 09:24 PM
WI.
dblshock Offline
dblshock  Offline
WI.
I'd run a substantial oil in that engine, the wimpy Dexo ILSAC swil will be obliterated quickly.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Cruze 1.4 turbo [Re: Dylan1303] #4494871
08/21/17 09:37 PM
08/21/17 09:37 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Sounds like a Power steering pressure hose is leaking. Very common in Chevy's. Always leaks by the pulleys.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Cruze 1.4 turbo [Re: FermeLaPorte] #4494899
08/21/17 11:20 PM
08/21/17 11:20 PM
Midwest
stevejones Offline
stevejones  Offline
Midwest
Chevy put electrons in a hose?
Re: Cruze 1.4 turbo [Re: Dylan1303] #4494928
08/22/17 02:41 AM
08/22/17 02:41 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
In Oz, GM Australia spec the high HTHS Dexos2 oil in those little 1.4L Turbo Cruze engines, not the thinner Dexos1 ILSAC oil.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Cruze 1.4 turbo [Re: FermeLaPorte] #4494972
08/22/17 06:33 AM
08/22/17 06:33 AM
Texas
4WD Offline
4WD  Offline
Texas
Mine has electric power steering
