Oil spec JASO-2TFC equivalent
Michigan
I'm picking up a used sccoter. 2010 Kymco. Manual calls for JASO-2TFC for the oil injection system. I can't find that spec oil. What would be an equivalent or exceed this spec? TCW-3?
JASO FC 2T (two stroke) oil.....some Taiwanese was using google translate and because of that all ended in a confusion
Or he/she was dyslexic
just make sure the oil is ok for injection use. some competition oils are thicker and wont work for this. a snowmobile oil would work well too..or a watercraft jet ski oil.
Then try to find PDS on web....and if it is in SAE30 (it will be most probably) or SAE40 range than it is suitable for oil pump/injection...anything above SAE40 is premix ONLY
Compare PDS of Motul 800/710 and you will see that catch
Since manuals say JASO FC....we know that he has AIRcooled engine...
So FC or FD will be adequate
JASO FD is what I'd be looking for
Watercraft jet ski oil could harm high revving AIRcooled equipement.....its addpack is different....and not suitable to bi used in AIRcooled engines
Brace yourself
http://kawtriple.com/mraxl/tips/oil_twostroke.htm
