New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
107 registered members (addyguy, 2004tdigls, arowbat, 2002 Maxima SE, Astro14, 11 invisible), 2,191 guests, and 65 spiders.
Topics286,350
Posts4,906,901
Members67,608
Most Online2,967
Mar 10th, 2019
2016 Ford 3.5EB 9765K miles castrol 0w40 #4494363
08/21/17 11:02 AM
08/21/17 11:02 AM
FL
BeerCan Offline OP
BeerCan  Offline OP
FL
7000 miles of this trip was towing at GVWR in very hot conditions at high speeds. 5qts 0w40 and 1qt 0w30
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2015 Hyundai Genesis 5.0
2012 Hyundai Genesis 3.8
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1987 Porsche 944 Turbo
1967 Plymouth GTX 440
Re: 2016 Ford 3.5EB 9765K miles castrol 0w40 [Re: BeerCan] #4494378
08/21/17 11:22 AM
08/21/17 11:22 AM
MN
oil_film_movies Offline
MN
But viscosity kv100, the one that is hot at 100 degrees C, was about normal, at 12.6. Expected value for your new oil mix would be about 12.9 or so.
This is plenty of visc! Fuel dilution, sure, but that would certainly have reduced their kv100 reading, right???
Tribologists or any geek: Would HTHS be reduced more than kv100 with that much fuel dilution?
This lab really hasn't got a clue. They were troubled by the Ti which comes standard as an anti-wear/anti-friction AW/FM additive in Castrol Edge!!!
Re: 2016 Ford 3.5EB 9765K miles castrol 0w40 [Re: BeerCan] #4494402
08/21/17 11:58 AM
08/21/17 11:58 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
I do not know this for sure, but I've been told the comments on Polaris reports are auto-generated. If a level goes above a preprogrammed limit, the "comment" is auto populated into the box. Can occasionally make for some silly remarks when viewed on the totality (such as the Ti for one).
Not that we don't occasionally see silly stuff in the comments written by people on certain UOAs from other sources ...
Six of one; half dozen of the other.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2016 Ford 3.5EB 9765K miles castrol 0w40 [Re: BeerCan] #4494538
08/21/17 03:03 PM
08/21/17 03:03 PM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
Castrol held up
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: 2016 Ford 3.5EB 9765K miles castrol 0w40 [Re: Ram02] #4494550
08/21/17 03:12 PM
08/21/17 03:12 PM
FL
BeerCan Offline OP
BeerCan  Offline OP
FL
Originally Posted By: Ram02
Castrol held up
I think so. My truck earned its keep on this trip for sure. I went from Tampa to Big Sky MT and back, we hit I think over 18 states. It was often close or over 100 degrees F and I was doing the speed limit as much as I could (75mph).
Trailer and truck weigh near GVWR. MPG was low, I averaged around 9.
Re: 2016 Ford 3.5EB 9765K miles castrol 0w40 [Re: BeerCan] #4494668
08/21/17 05:56 PM
08/21/17 05:56 PM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
Castrol held up
How close to GCWR with the trailer was it? I'm lucky to average 8 MPG with the 3.7 Transit in my sig, towing the company enclosed trailer behind it, and it is generally right at GCWR (around 12K total).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2016 Ford 3.5EB 9765K miles castrol 0w40 [Re: bullwinkle] #4494682
08/21/17 06:27 PM
08/21/17 06:27 PM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
That sounds about right. We tow our 9900 GVWR camper (35 ft bumper to hitch, 13' tall, 8' wide) with an EB F150 and I've seen 8-10 when towing. More often 8 and once in the mountains it dipped into the mid to high 7's. The truck does awesome but it does work.
Re: 2016 Ford 3.5EB 9765K miles castrol 0w40 [Re: BeerCan] #4494929
08/22/17 04:27 AM
08/22/17 04:27 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Almost 10,000 miles in a 3.5 eccobost on Edge 0W40, and 7k miles was towing.
The oil did fine. You can see it's a Euro oil with the high zinc (973 ppm) and good retained TBN (3.17), plus you have the Castrol Edge Titanium dose at 45ppm plus a touch of Boron at 28 ppm. A nice oil.
The iron wear is 30 ppm which is fine. The KV100 viscosity is 12.6 cSt which still seems OK to me, especially given many people would use an ILSAC 30 grade with a fresh KV100 of 10 to 11 cSt.
I can't help but to compare this to quite a few EB UOA's I've seen recently running Castrol Magnatec 5W30 (ILSAC brew). The Magnatec tends to show a bit less wear metal in the iron (about half), but there is nothing wrong with your iron numbers and you did push your EB much harder than most, so no problem. Your Edge, being a euro oil has higher zinc and ample TBN at 10k miles, while the Magnatec show less zinc and the Magnatec TBN looks spent to me after 9k miles.
At 10k mile OCI with heavy towing, I would stick to the Edge.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 2016 Ford 3.5EB 9765K miles castrol 0w40 [Re: BeerCan] #4494932
08/22/17 04:57 AM
08/22/17 04:57 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
For an engine that was worked like a dog for most of the OCI, this is good.
Sure would be nice to see that fuel lower.
Re: 2016 Ford 3.5EB 9765K miles castrol 0w40 [Re: BeerCan] #4495419
08/22/17 05:17 PM
08/22/17 05:17 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
Since gas evaporates fairly easily and this engine was run nice and hot, I wonder if the fuel is a result of a few short drives before the sample was taken. Maybe fuel dilution wouldn't be as bad if the last run before the oil change was a nice, long, hot run.
This is just a theory...Do you remember how the final few drives were on the oil before the change?
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
