Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
79 registered (2004tdigls, 2009Edge, 10WSmuckers, advocate, Aero540T, 10 invisible), 1524 Guests and 48 Spiders online.
65303 Members
67 Forums
285870 Topics
#4494316 - 08/21/17 09:59 AM Crank Pulley Seating Question
Canadastang Offline
Loc: Ontario Canada
I installed a set of underdrive pulleys on my 2003 Town Car this weekend.
Why am I modding a Town Car? I don't know either. It's too slow and I just want it to be a bit less slow lol.
Anywho, in true BITOG fashion, I've been a bit A-R after installing the crank pulley as to whether it's fully seated. I did the proper torque sequence (66ft lbs, loosen, then 37ft lbs + 90*) but it almost looks as if the crank pulley sits out just a bit further than the original balancer did.
Maybe it's just in my head and I'm being way too obsessed over this, but I measured the gap with feeler gauges between the back of the pulley and the timing cover and I'm getting about 2.5MM. The belt tracks straight and doesn't slip or squeal, but I swear, the old balancer was just a little bit closer to the timing cover than this.
Again, maybe it's in my head, but if anyone here has a set of feeler gauges and a 2V Ford Modular, wanna go measure the gap between your timing cover and balancer for me? LOL
#4494400 - 08/21/17 11:55 AM Re: Crank Pulley Seating Question [Re: Canadastang]
emmett442 Offline
Loc: Wisconsin
The distance to the timing cover means nothing - you've used a different piece. It's dimensions probably aren't the same, so you'd be comparing apples to oranges.
If the portion the belt rides on is aligned with the rest of the accessory drive, it's correct. You can easily see this by eye.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
#4494405 - 08/21/17 12:02 PM Re: Crank Pulley Seating Question [Re: Canadastang]
bdcardinal Offline
Loc: Santa Barbara, CA
You don't wait it too close to the timing cover as it will cut a groove in it. There was a whole batch of Aluminator engines where the crank pulley would self clearance on the timing cover due to crank thrust not being set properly during assembly.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
