QSUD not good for ecotec engine
Long Island,nassau county NY
2007 Pontiac G6 with 2.4 ecotec. Used QSUD for years always had to add a quart of oil every 1000 miles.Always thought the engine used oil zero leaks never thinking it could be the the oil choice. Grabbed a jug of formula shell at home Depot 3200 miles on this oil zero makeup oil. Go figure.
Same OCI?
This is as good as the post as the one who said he could "feel the difference" of rolling resistance when he put synthetic in the differential......
Not at all. Thats a big difference. Going from 1 quart per 1,000 miles (way too much!!) to almost NONE.
I can't believe it has anything to do with the oil. Its a coincidence that the rings finally freed up, sealing combustion due to correct orientation and/or junk finally breaking off the ringlands. Really, oil is just oil. Quaker State is not unusual in any way. Shell isn't either.
Originally Posted By: FermeLaPorte
Don't Quaker and Pennzoil leave wax inside the components? Formula might have cleaned it.
They're all made by Shell now.
So was QSUD the first oil used. and it consumed 1qt/1000miles from day 1?
Or worse it was running something else then switched the QSUD and it started consuming oil but you never gave it a second thought for years?
What tha cob?
Originally Posted By: urrlord
Different add packs if I remember the PQIA breakdowns of the oils.Could make a difference.
Both use Infineum additive packs. QSUD has about 20 percent more calicum.
lol
