Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
98 registered members (2015_PSD, bbhero, Astro14, ArrestMeRedZ, AdditiveOCD, 209paulc, 7 invisible), 1,540 guests, and 39 spiders.
Topics296,753
Posts4,958,255
Members66,964
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
2001 Chevy Malibu WOT power loss #4493846
08/20/17 04:44 PM
08/20/17 04:44 PM
Crawfordville FL
SilverFusion2010 Offline OP
Crawfordville FL
Engine pulls hard until about 3500 rpm then just stops pulling. Back off to about 1/3 throttle and it starts pulling again. I recently replaced the EGR valve. No trouble codes at this time. Starts and runs fine, drives fine as long as you don't go past about 1/3 pedal when revving high.
Not the transmission. I can hold a gear and wiggle the accelerator and feel the power come and go.
Anybody seen this before?
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4493881
08/20/17 05:24 PM
08/20/17 05:24 PM
VA
Thax Offline
Thax  Offline
VA
Check the condition of the catalytic converter, might be plugged. Check the temperature of the exhaust pipe before and after the converter , good converter will be 30-100 degrees hotter after the converter.
2000 Ford Explorer Limited 5.0L AWD
2018 KIA Soul EX 2.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4493966
08/20/17 06:49 PM
08/20/17 06:49 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Ignition? If you're losing spark on one cylinder that would be 25% of your power. You'd feel that.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4493969
08/20/17 06:54 PM
08/20/17 06:54 PM
Crawfordville FL
Crawfordville FL
Doesn't feel like a misfire and I'm not getting any misfire or cat codes. I will check the cat with a infrared thermometer when I have a chance, and I'll pull the plugs I can get to. I dunno if I can get to the back 3 without pulling the intake manifold.
On a V6 1 cylinder would be 16.67% power loss
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4493980
08/20/17 07:08 PM
08/20/17 07:08 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Oh I thought this was an ecotec 4 cylinder.
If its a V6, it has the coilpack waste-spark ignition. If a coil is bad you'd lose 2 cylinders.
Theres a couple reasons why it may not pop a miss fire code.
1.Its at a higher RPM. It may need a better understanding of the engine. You said you replaced the EGR. Did you reset the computer? IF so it may need to learn the engine more.
2. Its not missing at low rpm. It takes significantly less power to spark in a low rpm situation. To help it, the computer may also be hitting the spark 2 or 3 times each time the piston comes up. If the first spark doesnt jump, maybe the next one will and so forth. There is no time at higher rpm to be able to do multiple spark per cycle.
3. On some vehicles, the miss % has to be really high, 20-30% of all events in order to trigger a code.
-Colton
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4494002
08/20/17 07:36 PM
08/20/17 07:36 PM
Crawfordville FL
Crawfordville FL
It actually might be the cat. It's setting a P0401 insufficient EGR flow detected. A bit of googling, and I find that a clogged cat/high back pressure can cause this code. So next weekend I get to drown bolts in PB blaster and pray, swear and bash knuckles trying to get the thing off. I don't have an oxyacetylene torch so the easy way is out.
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4494026
08/20/17 08:09 PM
08/20/17 08:09 PM
NY
joegreen Offline
joegreen  Offline
NY
It's a long shot but try cleaning the maf if it has one.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: 2001 Chevy Malibu WOT power loss [Re: joegreen] #4494052
08/20/17 08:38 PM
08/20/17 08:38 PM
Crawfordville FL
Crawfordville FL
Cleaned MAF and throttle body today. No change except the idle smoothed out.
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4494216
08/21/17 06:27 AM
08/21/17 06:27 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
So wait... you just replaced the EGR and its throwing an EGR code?
New Part Defective?
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4494239
08/21/17 07:01 AM
08/21/17 07:01 AM
ME
eljefino Offline
eljefino  Offline
ME
I also smell a cat problem. It's wierd the EGR code is for "insufficient" but whatever. You could have cooked stuff with all the backpressure.
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4494280
08/21/17 08:05 AM
08/21/17 08:05 AM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
EGR problems can be felt at the time you describe. If it's vacuum operated they usually bypass the vacuum until you're cruising along and putting some power into the pedal.
A plugged cat can also cause similar problems.
Since you have a code for EGR that's where you should start, before going for the plugged cat since that could be considerably more hairy if you don't have a torch. What's indisputable is that the code was triggered and the code in the computer has a specific set of criteria that triggers it. You also recently touched the EGR valve, so there's the fact that something was wrong before with it (or at least you thought there was), that you replaced it and might have even made a mistake. This may not be a coincidence, usually areas where things are touched deserve a higher priority. Go back and see if the EGR system is good and check the valve operation. If none of those pan out, maybe the cat is blocked and the backflow is causing disturbances in the EGR since it routes exhaust gases.
If you had a service manual that shows you the diagnostics for that code it would be even better.
2015 Civic LX Coupe
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4494300
08/21/17 08:36 AM
08/21/17 08:36 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Put a vacuum gauge on it and rev it.
http://www.aa1car.com/library/exhaust_backpressure.htm
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4494307
08/21/17 08:47 AM
08/21/17 08:47 AM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Egr ports clean ?
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: 2001 Chevy Malibu WOT power loss [Re: SilverFusion2010] #4494412
08/21/17 11:09 AM
08/21/17 11:09 AM
Crawfordville FL
Crawfordville FL
The other EGR valve was bad and throwing a stuck closed code. I tested the valve before replacement. I'll look at the EGR ports but a clogged cat makes more sense to me with the power loss vs not enough EGR flow.
It makes sense to me. LIM leak, poisons cat, clogs up.
I'm going to run a coathanger through the EGR ports but I don't expect to hit anything.
Re: 2001 Chevy Malibu WOT power loss [Re: NoNameJoe] #4494420
08/21/17 11:25 AM
08/21/17 11:25 AM
Crawfordville FL
Crawfordville FL
Not vacuum. Electronic solenoid with integrated position sensor.
Page 1 of 3 1 2 3
