Gas trimmers
by weeksjake. 01/22/19 09:11 AM
Supertech Heavy Duty 15W40 ...$9.64
by dblshock. 01/22/19 08:53 AM
Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
94 registered members (Al, Aikido, 4WD, AmoryBlaine, Ag76, 2015_PSD, 12 invisible), 1,956 guests, and 35 spiders.
Topics296,969
Posts4,962,611
Members67,009
Most Online2,821
Jan 21st, 2019
XG9100 on a SBC Queston for Motoking #4493583
08/20/17 10:31 AM
08/20/17 10:31 AM
New York
mohrperformance Offline OP
New York
Could a XG9100 be used for a high performance sbc with blocked filter bypass, in place of a XG5 or HP4?
Re: XG9100 on a SBC Queston for Motoking [Re: mohrperformance] #4493673
08/20/17 12:53 PM
08/20/17 12:53 PM
Detroit
Motorking Offline
Motorking  Offline
Detroit
The short answer is no. If you use a filter not cataloged for the application, there is no warranty. So if you had an issue with a failure, you are on your own. Every filter company has the same policy. There are a significant differences in the o ring between the XG5 and XG9100. That said, why not use the HP4? It is still 94% efficiency at 20 microns, the XG is 99, splitting hairs there on a clean engine that is well maintained. And, it is never a good idea to block off a bypass valve.
Jay M Buckley
FRAM
(248) 808-4551
Please email filtration questions to the email below for fastest response.
[email protected]
Re: XG9100 on a SBC Queston for Motoking [Re: mohrperformance] #4493683
08/20/17 01:12 PM
08/20/17 01:12 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
If you block off the bypass valve in the block then be sure to use a filter with a bypass valve, like the Fram racing filter Motorking mentioned.
Re: XG9100 on a SBC Queston for Motoking [Re: Motorking] #4493940
08/20/17 06:22 PM
08/20/17 06:22 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
This is one reason why I seldom upsize a filter or use a filter that the book does not call for. If you have a filter malfunction, you are on your own for damages. Yes, it's true the odds are small that a filter will malfunction, but occasionally it does.
That being said, I will admit I have a 1-quart filter on one of my 4.0 Jeeps where the book calls for a half-quart filter. That engine has about 300K miles on it and is going to be replaced this Fall anyway.
Re: XG9100 on a SBC Queston for Motoking [Re: mohrperformance] #4494133
08/21/17 01:01 AM
08/21/17 01:01 AM
SACRAMENTO, CA
rrounds Offline
rrounds  Offline
SACRAMENTO, CA
What warranty, he has a blocked off filter by-pass. Put the largest oil filter that will fit and be sure it has a by-pass valve. Without the by-pass you can get very high PSID readings on cold oil starts and that can and has damaged filters. Just check and see if it flows more than 10 gpm and should be good. 10gpm is 1(one) gal every 6 sec's or .67 qt's every second and I can't think of any SBC's that pump that much oil.
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
Re: XG9100 on a SBC Queston for Motoking [Re: mohrperformance] #4494376
08/21/17 10:17 AM
08/21/17 10:17 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
^What he said-and I would try to get a filter with the strongest can available, since that is what would fail due to the blocked off bypass. I've never used the HP Fram filters, but that would be a good way to go. Unfortunately the tank-like Bosch Distance Plus D3510 doesn't have a bypass.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: XG9100 on a SBC Queston for Motoking [Re: mohrperformance] #4494643
08/21/17 04:33 PM
08/21/17 04:33 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Well, if the filter bypass is already blocked..... go for it
I run fram 9100's on my 7.4/454 (it was made for a DuraMax). It's a pretty high setting, like 20 psi - but BETTER THAN NOTHING!
Re: XG9100 on a SBC Queston for Motoking [Re: mohrperformance] #4494707
08/21/17 05:58 PM
08/21/17 05:58 PM
Tug Hill, NY
Corelokt Offline
Corelokt  Offline
Tug Hill, NY
Bigger makes cooler due to surface area and volume. Go for it.
86 CUCV. 6.5L. Level-3 4L80. NP205. 9-16 14 ply tires, HX35/40 turbo. WMI. 5" exh. ARP studs heads & crank. Cooling upgrades. Rattle can camo.
