Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
68 registered members (2strokeNorthstar, AdditiveOCD, anndel, 330indy, alphadog, Ag76, 4 invisible), 1,346 guests, and 36 spiders.
Topics295,007
Posts4,925,847
Members66,664
Most Online2,553
Oct 27th, 2018
F355 coolant analysis #4493551
08/20/17 09:44 AM
08/20/17 09:44 AM
NC
f355 Offline OP
f355  Offline OP
NC
I've already posted a topic on the UOA section. But figured that I'd link it here for those that may have expertise in coolant that don't navigate over to the oil analysis threads.
https://bobistheoilguy.com/forums/ubbthr...lys#Post4492583
Hey guys,
Just signed up and curious would you think of these results.
I'm in the process of inspecting to buy a 95 Ferrari F355. The car has little maintenance history so I thought it prudent to send off some fluids to get an idea if there were any critical issues that perhaps wouldn't be picked up by eye or through compression/leakdown.
Unless the community has something to say about the oil, I think it looks reasonable. In terms of the coolant, lead (Pb) content is really high. The seller has indicated that there was a small radiator leak, which he had used some Holts Conditioner to treat. However, I think that the Pb corrosion is what's at issue and require new coolant system (rads, heater core, other exchangers).
What do you guys think?
https://media.trillian.im/media/?m=aW1hZ2UvcG5nLDE0NTUsNTU5LAjbzOZcMTAto%2FNqGOjDQ7uw4NxUh9emqlsazT%2FymaRb
Thanks!!
Re: F355 coolant analysis [Re: f355] #4493599
08/20/17 10:56 AM
08/20/17 10:56 AM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
I think I would do a complete and very careful inspection of the entire vehicle because of the "cheap" coolant fix attempt. A suggestion of replacing the coolant and waiting 3 months to recheck is one way to approach the issue. Your suggestion to replace all heat exchangers is a better but, much more expensive option. I would try to get on a 355 forum and post the question. Ed
CX5 Touring 2.5L :-)
Re: F355 coolant analysis [Re: Eddie] #4493696
08/20/17 01:30 PM
08/20/17 01:30 PM
Michigan
khittner Offline
khittner  Offline
Michigan
If I was buying a Ferrari, I'd find another one. If you haven't watched Rob Ferretti's videos: superspeeders.com---on life with exotic cars, you might want to do so. Ferretti is an annoying personality, and his actual mechanical expertise is limited, but he's got fairly extensive ownership experience, and has paid lots of 5-fugure repair bills on his NYC/NJ Ferrari rental fleet. Any PO who can't provide a fairly detailed maintenance history (or refer to the legit shop that has done the work and maintained a paper trail), who's pouring some goop into a Ferrari's cooling system, rather than fixing the leak immediately upon its discovery, is not an owner that you want to buy from.
