Employer Exit Interview.
by JustinH
1 minute 7 seconds ago
Ceratec vs. Archoil 9100
by Phishin
4 minutes 43 seconds ago
Acclaim radiator ?
by urrlord
6 minutes 57 seconds ago
Understanding Idle Control Circuit
by artbuc
54 minutes 58 seconds ago
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
Today at 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
Today at 06:58 AM
Ford 4.6L Durability?
by Auae85
Yesterday at 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
Yesterday at 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
Yesterday at 10:01 PM
Fireworks Stores
by Warstud
Yesterday at 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
Yesterday at 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
Yesterday at 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
Yesterday at 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
Yesterday at 08:49 PM
My FIL in hospice
by fdcg27
Yesterday at 08:41 PM
Spraying Polyurethane
by Texican
Yesterday at 08:37 PM
Dehumidifier icing
by Kestas
Diesel lube in Petrol Engine
by Ducked
Yesterday at 07:46 PM
New key programming cost
by 92saturnsl2
Yesterday at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Yesterday at 07:09 PM
ronw1309, Suth31, yamahaboy125, Turboholic, TrpNY
65284 Registered Users
85 registered (andyd, ARCOgraphite, A310, 2004tdigls, ArrestMeRedZ, 04sierrashortbed, 9 invisible), 1305 Guests and 43 Spiders online.
65284 Members
67 Forums
285689 Topics
Page 1 of 3 1 2 3 >
#4493355 - 08/20/17 04:54 AM 2017 Fusion best oil?
mattri Offline
Loc: Iowa
Just picked up a 2017 Fusion, 1.5 Ecoboost for the wife, Motorcraft or???
#4493357 - 08/20/17 05:22 AM Re: 2017 Fusion best oil? [Re: mattri]
Char Baby Offline
Loc: ROCHESTER, NY
MotorCraft is always a good place to start and is a good oil held in high regard here at BITOG. Decide how you & wife and the rest of the family will be using the car. If it's only going to be the daily driver then any recommend oil in the owner's manual will do.
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4493383 - 08/20/17 06:57 AM Re: 2017 Fusion best oil? [Re: mattri]
mattri Offline
Loc: Iowa
Thanks for the reply. It is just a dd, grocery getter etc. My only concern is the stop and go nature of her commute. She only drives about 5 miles a day during the week.
#4493398 - 08/20/17 07:24 AM Re: 2017 Fusion best oil? [Re: mattri]
4WD Offline
Loc: Texas
Where will it be changed: dealer, home, lube place?
#4493400 - 08/20/17 07:24 AM Re: 2017 Fusion best oil? [Re: mattri]
SilverFusion2010 Offline
Loc: Crawfordville FL
M1 5w30 is dexos1
Top notch oil.
Take it on an hour long drive on the weekend or run a shorter OCI
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
#4493405 - 08/20/17 07:29 AM Re: 2017 Fusion best oil? [Re: mattri]
mattri Offline
Loc: Iowa
Home
#4493408 - 08/20/17 07:36 AM Re: 2017 Fusion best oil? [Re: mattri]
4WD Offline
Loc: Texas
Mobil 1 from WM - then catch year end clearance for several popular synthetic oils that AZ and others will have for half price ...
I bought Castrol, Mobil 1, and Quaker State UD for $10/jug during sale.
#4493431 - 08/20/17 08:15 AM Re: 2017 Fusion best oil? [Re: mattri]
oil_film_movies Offline
Loc: MN
--You used the word "best" in the title.
--You are changing it at home.
--Its a nice new engine.
--It will be extremely short-tripped (little warm-up time).
Based on your situation, get out the big guns (short tripping worries me the most).
That would be Mobil1 Annual Protection 0w20, and change it according to the iOLM (iOLM is your engine computer's calculation of condition severity and oil life; the change oil light on your dashboard). Make sure to reset the iOLM (youtube videos on this) when you do change.
M1 Annual Protection has the best anti-oxidant package and base oils that Mobil can offer, and it should battle it out with the short tripping acid chemistry the best.
Walmart has it down to $30 per 5-quart jug after e-Gift card rebate, so its not that bad if you want the best. Otherwise, M1 EP 0w20 would also work well, for a few less $$.
Also, get rid of the factory fill oil within a couple of months after buying the car, just to clear out the metal micro-dust inside. Get a magnetic drain plug (Dimple or GoldPlug strong magnets) to collect extra iron particles for the life of the vehicle.
Oil filters are not always the same inside. Use a Fram Ultra; compare the way its made and its 4548-12 performance to any other oil filters out there if you want to research that.
If you remove the word "best" from your title, I'd say just use any oil (5w20) you see on the shelf at Walmart and any oil filter there, and change according to the iOLM.
Edited by oil_film_movies (08/20/17 08:20 AM)
#4493434 - 08/20/17 08:19 AM Re: 2017 Fusion best oil? [Re: oil_film_movies]
4WD Offline
Loc: Texas
Well Sir, that's Best Plus ... thumbsup
#4493439 - 08/20/17 08:27 AM Re: 2017 Fusion best oil? [Re: mattri]
btanchors Offline
Loc: Herndon, VA
There is another reason Mobil 1 Annual Protection is a great choice. It appears to be approved for Dexos1 Gen 2, which has added tests for Low-Speed Pre Ignition (LSPI), which can occur especially in Turbocharged Direct Injection engines, which the Ecoboost has
#4493442 - 08/20/17 08:34 AM Re: 2017 Fusion best oil? [Re: btanchors]
Loc: MN
Wondering if a dexos1 Gen2 would have helped a DI engine I had a couple of years ago that would do LSPI knocking at low-RPM, high loads. Probably.
Also, dexos1 Gen2 has new timing chain wear tests, similar to what GF-6 will have 2 years from now.
Hard to go wrong with a full synthetic dexos1 Gen2, and I think its very close to BMW LL-01FE levels of performance, if not already the same.
#4493443 - 08/20/17 08:36 AM Re: 2017 Fusion best oil? [Re: mattri]
Mathew_Boss Offline
Loc: Nebraska
Use Quaker State Ultimate Durability. It's $20 For a 5 quest jug at Wal-Mart and it's the one of the best anti wear oils which is important for short trips. If you don't like SOPUS, try Castrol Magnatec. It has produced some of the best UOA I have seen in Ford Ecoboost engines and is usually less than $18 a 5 quest jug at Wal-Mart. Change at the IOLM and enjoy your new car.
#4493452 - 08/20/17 08:46 AM Re: 2017 Fusion best oil? [Re: oil_film_movies]
This is 100% true. Best possible oil that's widely available. But dumping it according to the OLM which is what you'll need to do to maintain warranty, will have you dumping good oil. Best Value imo is the dexos1 certified M1 5w-30.
The magnetic drain plug is a good idea.
#4493453 - 08/20/17 08:48 AM Re: 2017 Fusion best oil? [Re: mattri]
gregk24 Offline
Loc: FL, USA
I would go with Mobil 1. It will probably hold up better than Motorcraft synthetic blend, especially in those conditions.
2012 Honda Accord EX-L K24z3
53,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
37,xxx miles
Castrol Edge 0w40 / OEM filter
#4493463 - 08/20/17 08:56 AM Re: 2017 Fusion best oil? [Re: SilverFusion2010]
Loc: MN
Originally Posted By: SilverFusion2010
This is 100% true. Best possible oil that's widely available. But dumping it according to the OLM which is what you'll need to do to maintain warranty, will have you dumping good oil. Best Value imo is the dexos1 certified M1 5w-30. The magnetic drain plug is a good idea.
Ford specs 5w20, not 30, yet I'd say go to a 0w20 here due to short tripping. Wouldn't have to use 0w20 (vs. 5w20), but the 0w20 isn't as thick during warm-up. I fully agree that M1 EP or plain M1 could be used instead of M1 Ann Prot here for almost the same results. The engine would be OK doing about anything if following the iOLM for sure. Sometimes we pull out all the stops, sometimes we don't care to.
Page 1 of 3 1 2 3 >
