Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
32 registered members (c502cid, alcyon, anndel, Bailes1992, Chris B., 4 invisible), 543 guests, and 56 spiders.
Topics286,442
Posts4,908,257
Members67,622
Most Online2,967
Mar 10th, 2019
PP 5w-30, 2015 F150 2.7, 10K km #4492701
08/19/17 10:15 AM
08/19/17 10:15 AM
Edmonton, Alberta, Canada
advocate Offline OP
advocate  Offline OP
Code:
OIL             Pennzoil Platinum 5w-30
MILES IN USE    6000 miles, 10058 KM
MILES           12567 Miles, 20225 KM
SAMPLE TAKEN    10/09/2017
ALUMINUM        5
CHROMIUM        1
IRON            58
COPPER          6
LEAD            0
TIN             0
MOLYBDENUM      49
NICKEL          1
MANGANESE       0
SILVER          0
TITANIUM        0
POTASSIUM       3
BORON           6
SILICON         76
SODIUM          5
CALCIUM         2022
MAGNESIUM       9
PHOSPHORUS      589
ZINC            690
BARIUM          0
VI              181
Soot            2
Oxi             21
Sul             25
Nit             16
V100            8.9
V40             45.3
This is my nephews truck - 2015 F150 supercrew 4x4 with the 2.7 ecoboost and 3.55 gears. Pennzoil Platinum 5w-30 was used and the Motorcraft cartridge oil filter for about 10 months. Oil and filter were changed using the same stuff. It is used as a daily commuter mainly. It is a short interval and though TBN is high, it has sheared down to a 20 grade meaning surely that there is some fuel dilution going on. Also Si seems high, maybe still from break in... But we will be checking over the air box and filter pretty good. Any other ideas or concerns? I don't think that we should extend past 10k (6k miles) with this setup at this time.
Re: PP 5w-30, 2015 F150 2.7, 10K km [Re: advocate] #4492811
08/19/17 01:01 PM
08/19/17 01:01 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
I can understand the higher silicon level on a low mileage new vehicle, the iron seems high to me though. At ~6,000 miles the viscosity is just under the 30 weight which seems to be what happens with these Eco Boost engines, they seem to be tougher on the oil. Probably keeping to the 10,000 KM OCI is a good idea.
Whimsey
Re: PP 5w-30, 2015 F150 2.7, 10K km [Re: advocate] #4492864
08/19/17 02:17 PM
08/19/17 02:17 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
At your mileage, I think the engine is still breaking in...but the iron still seems a bit high. Maybe from all the short commutes. I'd watch it and see if it drops. You may need to shorten the OCI to a point that keeps the numbers happy. Skip mileage and think of time...maybe every 6 months.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: PP 5w-30, 2015 F150 2.7, 10K km [Re: advocate] #4492869
08/19/17 02:30 PM
08/19/17 02:30 PM
advocate Offline OP
advocate  Offline OP
What worries me is that the si being that high... compared to my truck (2016 F150 5.0) with similar mileage but a longer interval, tested at the same lab even and my si was at 11. And the iron is higher then mine by a little bit but at almost 3000 kms less and a much easier duty being just a commuter. Mine gets used for hauling and towing a travel trailer. So it should have had better results then mine especially with a shorter run. But him tbn was much stronger at 6, mine was below 2.
Re: PP 5w-30, 2015 F150 2.7, 10K km [Re: advocate] #4492926
08/19/17 03:30 PM
08/19/17 03:30 PM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
I would assume that this was just the second drain and therefore higher metals and silicon can be expected. Now that I've stated the obvious, both iron and silicon do seem a bit high. I can only agree that checking out the intake plumbing is in order. Maybe it's just break in material, but it's possible that something is loose and allowing dust to get pulled in where it shouldn't.
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: PP 5w-30, 2015 F150 2.7, 10K km [Re: advocate] #4492958
08/19/17 04:12 PM
08/19/17 04:12 PM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
Then again, in the handful of reports that I've seen that showed true intake leaks, the softer metals were ground up worse than the steel parts. If the silicon was ingested dust, I think the aluminum and chromium would be much higher than what we see here. I don't know where chromium ranks in metals, but high silicon (dirt) usually causes excess ring wear as much as anything. I'm just going by reports and problems found in a friend's fleet. Still no harm in looking at the truck's intake.
Re: PP 5w-30, 2015 F150 2.7, 10K km [Re: advocate] #4493009
08/19/17 05:06 PM
08/19/17 05:06 PM
Chicago
danielLD Offline
danielLD  Offline
Chicago
Something's not firing right in the combustion chamber. But you're going to need GC and KF to see why. Only thing we can see here is some viscosity drop and not enough spark taking place.
Re: PP 5w-30, 2015 F150 2.7, 10K km [Re: danielLD] #4493041
08/19/17 05:40 PM
08/19/17 05:40 PM
oklahoma
hyperscion Offline
hyperscion  Offline
oklahoma
dude. you are doing everything right. iron should keep dropping, give it some time, afew oil changes will wash out the higher numbers your watching. if not then?????????
Re: PP 5w-30, 2015 F150 2.7, 10K km [Re: hyperscion] #4493044
08/19/17 05:43 PM
08/19/17 05:43 PM
oklahoma
hyperscion Offline
hyperscion  Offline
oklahoma
check out intake airflow....but its prob just si gasket material...from engine build.
Re: PP 5w-30, 2015 F150 2.7, 10K km [Re: advocate] #4493230
08/19/17 09:05 PM
08/19/17 09:05 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
In itself the iron and silicon ppm appears (possibly unacceptable and) very high.
Seeing it as from a 12.5k vehicle miles, the low-ish aluminium seems to suggest normal dirt ingress suggesting vehicle operates in normal condition.
High iron could likely be vehicle breaking-in as well.
Keep going as usual ...... and monitor from time to time if iron and silicon trends down.
