Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
122 registered members (14Accent, 86lxjunker, 2015_PSD, 01rangerxl, 17 invisible), 1,960 guests, and 55 spiders.
Topics286,163
Posts4,903,356
Members67,569
Most Online2,967
Mar 10th, 2019
labor to replace struts/shocks on Nissan/Infiniti #4492625
08/19/17 08:45 AM
08/19/17 08:45 AM
OBX & Central FL
NormanBuntz Offline OP
OBX & Central FL
On my wife's 2007 M35 with 102K miles, it seems from the tire wear that it's time to replace the front struts and rear shocks. I can buy KYB Excel G parts for less than $300 delivered, so there's no way I will pay through the nose for parts from the Infiniti dealer.
Excluding high cost areas like CA and NY, anyone have any recent experience knowing the labor for this job on a like year Nissan Maxima or Infiniti? The internet quotes by www.repairpal.com and others don't list the labor, only the total cost.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: labor to replace struts/shocks on Nissan/Infiniti [Re: NormanBuntz] #4492647
08/19/17 09:15 AM
08/19/17 09:15 AM
Lyndhurst NJ
Audios Online content
Audios  Online Content
Lyndhurst NJ
For a non AWD car its about 4 hours plus alignment. Always get the mounts bump stops and boots as well since you're in there.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: labor to replace struts/shocks on Nissan/Infiniti [Re: NormanBuntz] #4492747
08/19/17 11:23 AM
08/19/17 11:23 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I bought KYB excel G parts and had them installed, they have been very good. Like stock. Id agree on 3-4 hours plus alignment.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: labor to replace struts/shocks on Nissan/Infiniti [Re: NormanBuntz] #4492783
08/19/17 12:13 PM
08/19/17 12:13 PM
texas
danez_yoda Online content
danez_yoda  Online Content
texas
Get an estimate from your local area here if you want someone else to do it.
https://repairpal.com/
If you're doing it yourself with a basic garage you'd better double the estimates they are giving and be daym careful with the springs.
I did my tacoma with a 6 pack in tow. rears took all of 30 minutes, fronts tool longer because of all the stuff you had to remove and loosen to get to them.
Other than time, it wasn't bad but it tied up the truck all day.
You can do it without an alignment immediately afterward if you don't need one now. jut mark the parts with a paint stick so you put them back exactly (+/-) where they were. If in doubt, get an alignment.
Re: labor to replace struts/shocks on Nissan/Infiniti [Re: NormanBuntz] #4492969
08/19/17 04:21 PM
08/19/17 04:21 PM
Plano, TX
dparm Offline
dparm  Offline
Plano, TX
Has the car ever seen salty roads? If so, it will be a bit riskier to DIY since things tend to rust up and then snap when you apply a lot of torque from a breaker bar.
2017 Chevrolet Corvette Grand Sport
Re: labor to replace struts/shocks on Nissan/Infiniti [Re: NormanBuntz] #4492982
08/19/17 04:34 PM
08/19/17 04:34 PM
USA
slacktide_bitog Offline
USA
Repairpal does break down the parts and labor cost. Just click on "view estimate details smile
The labor estimate is about $300 for the front two. Of course, you will also need an alignment.
The rears you can probably do yourself since they're just shocks with no spring to compress.
Re: labor to replace struts/shocks on Nissan/Infiniti [Re: NormanBuntz] #4493003
08/19/17 04:55 PM
08/19/17 04:55 PM
WI
HoosierJeeper Offline
WI
Count on $50-80 an hour for labor.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: labor to replace struts/shocks on Nissan/Infiniti [Re: NormanBuntz] #4493032
08/19/17 05:30 PM
08/19/17 05:30 PM
Southern NY
MoneyJohn Offline
MoneyJohn  Offline
Southern NY
I just replaced struts of 2006 Sentra. I got all weird numbers from the mechanics, from $120/each to Pepboys in Bronx quoted me $330 to install all 4. I had Gabrield ReadyMounts (don't buy them, not impressed).
Since I didn't want to pay even that (because that was the whole reason for buying ReadyMounts), I installed myself. Bought new impact wrench and it was a breeze (and I just started working on the cars 2 months ago, so not even an amateur). Screwed up on the last one when the bolt snapped at 20 ft/lb torque. That cost me a little to fix. Even though I spent a little more than $330, at the end I got a tool so not all money wasted with the idea of DIY.
Do you have YourMechanic.com in your area? They come to your place, expensive but everything will be done in front of you.
2015 Subaru Forester 2.5i Premium w/ EyeSight
2006 Nissan Sentra 1.8S Special Edition
