Manual transmissioned electric car
by mjoekingz28
Today at 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
Today at 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
Today at 06:02 PM
Traveller nlgi 2
by Spitter
Today at 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
Today at 05:08 PM
Any nano reefers here?
by RichardS
Today at 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
Today at 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
Today at 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
Today at 04:31 PM
help me choose...
by chaindrive
Today at 04:07 PM
France F1 Grand Prix
by DeepFriar
Today at 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
Today at 03:16 PM
Best additive in oil to clean sludge?
by ffgb
Today at 02:19 PM
Who is a Dirt Track regular?
by thooks
Today at 01:39 PM
eco plug oil plug video is restricted
by edwardh1
Today at 01:27 PM
Political comments
by ridgerunner
Today at 01:23 PM
My Ford orange turned pink
by BeerCan
Today at 12:45 PM
Any plants/garden experts?
by maverickfhs
Today at 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
Today at 12:23 PM
Brake fluid for a '03 Volvo S60
by earthworm
Today at 11:22 AM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
109 registered (2015_PSD, 2strokeNorthstar, 2004tdigls, ammolab, 01rangerxl, 5AcresAndAFool, 13 invisible), 1497 Guests and 38 Spiders online.
65286 Members
67 Forums
285728 Topics
#4492501 - 08/19/17 02:49 AM Walbro LMT Carb, Only Runs on Full Choke
Kevinmcc2 Offline
Loc: Pennsylvania
So I have a generator that has a Walbro LMT carb on it but it only runs on full choke. I pulled the carb off 3 times so far tonight and used 2 cans of carb cleaner with no luck.. Am I missing something here? I pulled the main jet emulsion tube out and made sure that all the little holes on the sides are cleaned, shot cleaner down every port I saw but nothing. Is there a port on these carb that is harder to find?
#4492506 - 08/19/17 03:57 AM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
Lubener Offline
Loc: N.Ohio
Considering the low cost of a rebuild kit, I would do a rebuild or just replace it.. Sounds like you are reusing old gaskets, they could be leaking enough to lean out the mix.
The "thinking" man's friend.
#4492526 - 08/19/17 06:22 AM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
vwmaniaman Online   content
Loc: Kevil,Ky
If you use any ethanol fuel, it will clog the jet size with a yellowish gum that clings to the wall of the jet. You can still see thru it and carb cleaner won't cut it. Remove the jets and use a set of wire cleaners for welding torches to clean out each jet. They have the welding jet cleaners at Harbor Freight very cheap. When you have it clean, put about 4 oz of Sea Foam in the gas and try again.
Don't waste your time on a slipshod repair.
#4492530 - 08/19/17 06:35 AM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
spasm3 Offline
Loc: North Carolina
Disassemble the carb and clean it. On some carbs there are multible jets, venturis that get plugged. I use some small .014 wires to clean them. Berryman b-12 is a much better solvent that seafoam. Seafoam is 40% pale oil. The alternative is to buy a new carb. But on a generator that sits, even the new carb will eventually gum up, so it pays to learn how to disassemble and clean them. As mentioned above, the gaskets can leak , leaning things out.
Edited by spasm3 (08/19/17 06:37 AM)
13 elantra 68k 5w30 QSUD
03 chevy avalanche76k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 3900 miles m1 0w20/0w40 mix
#4492575 - 08/19/17 07:53 AM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
FowVay Offline
Loc: Southeastern USA
Make sure there are no splits in the fuel supply line. You're running excessively lean which means either not enough fuel or too much air. Fuel supply could be clogged jet or split fuel line. Too much air could be leaking gasket or cracked manifold.
Quaker State across the board.
#4492708 - 08/19/17 10:21 AM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
Merkava_4 Offline
Loc: Clovis, CA
They're showing some air bleeds that might need cleaning and also a welch plug that might need to be removed. Welch plugs get destroyed during removal so you'd have to replace it if you went that far.
http://outdoorpowerinfo.com/repairs/briggs_walbro_lmt_carb.asp
#4492794 - 08/19/17 12:30 PM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
SHOZ Offline
Loc: Illinois
I had a snowblower that needed choke to run. Turned out the timing was off due to the flywheel key almost completely sheared.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4492850 - 08/19/17 02:01 PM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
nwjones18 Offline
Loc: Warner Robins, GA
Lately I've been finding replacement carbs are so cheap they aren't worth taking apart. The carb for my generator was $12 on amazon..
1988 F-150. 4.9 I6 247k. 10w-40 Castrol Syn-blend ACDelco UPF2.
2005 Cadillac STS N* 108k. 5w-30 Castrol Magnatec ACDelco Classic PF61
#4494131 - 08/21/17 01:25 AM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: nwjones18]
Shaunsmith Offline
Loc: New York, USA
Helpful thread
#4494805 - 08/21/17 08:49 PM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
riklyn Offline
Loc: Heart of Dixie
watch the you tubes. there is something on there that covers it.
also ethanol will kill OPE, don't care what anyone says, (unless they are real anal about not leaving it in). the carb on my high dollar Echo trimmer and husqavarna blower (Zama) were both made in China and factory replacements off Ebay were less than $20 each.
also you may need to replace fuel lines.
let us know if you find what works. I have a 15 y.o. Honda 1000 that is doing pretty much the same thing.
2016 Dodge Ram 5.7 Hemi
2004 Wrangler TJ (Unlimited) 4.0
#4494954 - 08/22/17 06:58 AM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: riklyn]
Duffyjr Offline
Loc: Nebraska
Had this happen with my blower, would only run with choke on first click then eventually that winter it required two clicks but when it got under load it would start stumbling. Went to get a rebuild kit and the guy gave me the kit but also gave me a little bottle of Star Tron and told me to try that first. After a couple more times of using the blower it started clearing up and eventually started running with out the choke. I still have the kit and never did use it. I just put a couple cap fulls in every time I fill it up.
I do agree that these carbs are so cheap that may be your best option. I got one for $15 off ebay just in case it happens again.
89 GMC Sierra T5 10w30/Wix
08 Lucerne Mobil 5000 5w30
99 LeSabre QSGB 10w30/TG
18 Toro Super Recycler T5 10w30
#4495135 - 08/22/17 11:47 AM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: vwmaniaman]
wag123 Offline
Loc: Texas
All you need to use is small STEEL wire that is relatively stiff. I use twist ties with the plastic removed. Most twist ties use 27 gauge steel wire. They work well and don't cost anything. After poking the wire through all of the small orifices, spray carb cleaner through them to clean them out.
#4500559 - 08/28/17 05:38 PM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
Shaunsmith Offline
Loc: New York, USA
Very helpful best vacuums .
#4500587 - 08/28/17 06:15 PM Re: Walbro LMT Carb, Only Runs on Full Choke [Re: Kevinmcc2]
spasm3 Offline
Loc: North Carolina
I use .014 stainless stylets. If some of you want some let me know.
