Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
116 registered members (AMC, aquariuscsm, 77GrandPrix, 28oz, 17 invisible), 1,858 guests, and 36 spiders.
Topics294,986
Posts4,925,432
Members66,660
Most Online2,553
Oct 27th, 2018
Pt cruiser coolant pressure test findings. #4492381
08/18/17 09:48 PM
08/18/17 09:48 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
I did a pressure test on the ex wife's car and it's slowly using coolant. It's a non turbo 2.4l when the upper plenum was off in the first intake chamber I could hear a hissing noise when I did the pressure test. Never saw coolant just heard the hissing. Would that be a head gasket leak for sure? I'm not all that familiar with this engine all things considered.
2014 dodge dart GT
1995 Dodge ram 1500
Re: Pt cruiser coolant pressure test findings. [Re: ram_man] #4492486
08/19/17 12:49 AM
08/19/17 12:49 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
Pull spark plug on same chamber and listen for hissing there. Do a compression test as well.
Re: Pt cruiser coolant pressure test findings. [Re: ram_man] #4492529
08/19/17 05:25 AM
08/19/17 05:25 AM
Kevil,Ky
vwmaniaman Online content
vwmaniaman  Online Content
Kevil,Ky
Sounds like head gasket or crack in the head. Probably from being run out of water.
Don't waste your time on a slipshod repair.
Re: Pt cruiser coolant pressure test findings. [Re: ram_man] #4492581
08/19/17 07:02 AM
08/19/17 07:02 AM
PV Az
AZjeff Online content
AZjeff  Online Content
PV Az
You've found an expensive repair on X-wife's car. Now what?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Pt cruiser coolant pressure test findings. [Re: ram_man] #4492609
08/19/17 07:29 AM
08/19/17 07:29 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Well known issue on PTCruisers (ask me how I know) are coolant /cooling problems. Cracked heads, warped heads or blown head gaskets are common, as are radiator fan failures. Do the compression tests, as suggested, and take it from there.
Doesn't matter that you never saw coolant, once the engine gets up to temperature and cooling system pressure it will find it's way wherever it can go. Ideally it can only go where it's supposed to, but regardless, if there is a path it's not supposed to go, it will go there too.
Buy a bottle of coolant dye ($10) and a blacklight bulb ($3) for your trouble light, and you will see every coolant leak, slow or fast.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Pt cruiser coolant pressure test findings. [Re: ram_man] #4492902
08/19/17 02:09 PM
08/19/17 02:09 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
What if the compression is all good?
2014 dodge dart GT
1995 Dodge ram 1500
