Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
94 registered members (2010Civic, ABomb369, 28oz, 1JCB, 2009Edge, 9 invisible), 1,736 guests, and 46 spiders.
Topics290,666
Posts4,847,923
Members66,011
Most Online3,590
Jan 24th, 2017
Mercon V, should I be worried? #4492358
08/18/17 10:14 PM
08/18/17 10:14 PM
Michigan
Bakes168 Offline OP
Bakes168  Offline OP
Michigan
I have a 2001 F250 7.3L with the 4R100 trans, around 245k miles on the truck. About a year ago I did a trans fluid flush following the write up by the retired Ford trans engineer who helped design the 4R100. I filled her with the Valvoline Dex/Merc fluid that was on sale at WM. I now learn that while Mercon was originally spec'd for this trans, Ford later changed the spec to Mercon V.
Should I be worried about driving with the current fluid in there? Should I perform another flush and fill with a Mercon V spec'd fluid?
She has the 6.0L trans cooler installed, average temps run around 120-140 F with normal driving and she doesn't tow much. At the moment she is driving and shifting well, no issues.
This is my first post on BITOG, I greatly enjoy learning from/with all of you fine folks!
Re: Mercon V, should I be worried? [Re: Bakes168] #4492396
08/18/17 11:03 PM
08/18/17 11:03 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
I think you're fine, until your next -regularly scheduled- trans fluid change. Just use Mercon V then.
Re: Mercon V, should I be worried? [Re: Bakes168] #4492408
08/18/17 11:14 PM
08/18/17 11:14 PM
Utah, USA
28oz Online content
28oz  Online Content
Utah, USA
I agree. The Mercon V is a better fluid, but the Dex/Merc should meet the original spec. Just change it all at your next fluid change.
1990 Nissan 300zx - Castrol Edge Euro 0W-40
2004 Nissan Quest - Pennzoil Platinum Euro 0W-40
2003 Ford Excursion 7.3 PSD - Mobil 1 TDT 5w-40
Re: Mercon V, should I be worried? [Re: Bakes168] #4492419
08/18/17 11:31 PM
08/18/17 11:31 PM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
Wasn't the spec changed to Mercon V due to torque convert shuddering issues? I believe the work around is Lubeguard RED. That is, if you even develop any symptoms.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Mercon V, should I be worried? [Re: Bakes168] #4492434
08/18/17 11:48 PM
08/18/17 11:48 PM
5600 feet elevation, Arizona
double vanos Offline
First things first: welcome please have a seat and enjoy the ride..
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Mercon V, should I be worried? [Re: Bakes168] #4492478
08/19/17 01:13 AM
08/19/17 01:13 AM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
That retired Ford transmission engineer is pretty active on Ford-trucks.com. For your peace of mind I suggest asking there and getting a reply from the horses mouth.
Re: Mercon V, should I be worried? [Re: Bakes168] #4492642
08/19/17 09:08 AM
08/19/17 09:08 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
I've read that there are additive packages (like Lubeguard green MV ATF supplement) that can enhance a Mercon towards Mercon V specs. Might be worth a try.
Lubeguard Faqs
My 2002 Lincoln calls for Mercon V. Note that my essentially identical 1997 Lincoln called for Mercon and that run to 232K miles flawlessly. I can't see the huge difference other than trying to get more life out of the transmission. On my last trans fluid change in the 2002 (42K miles to 71K miles) the info on the quick lube service said they did it with "Mercon." (Mercon or Mercon V?...and would they even care?). It wasn't until I got here at Bitog that I realized it wasn't right. If I could go back, I'd have changed out that "potential" Mercon fluid early at 15K-20K miles. The Mercon shears at probably twice the rate of the semi-synthetic Mercon V (from articles I've read), one good reason alone to use the Mercon V which has a 30K OCI on my vehicle. My car showed no negative issues with running Mercon for those 30K miles while running as smoothly as it always had. I'm now back on Mercon V. Advantages to Mercon V are it shears less, semi-synthetic at a minimum, and a better anti-wear/detergent add package than Mercon.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Mercon V, should I be worried? [Re: Bakes168] #4492745
08/19/17 11:19 AM
08/19/17 11:19 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Just use Mercon V next drain and fill. It replaced Mercon III in all applications but the older stuff will still do the job.
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Mercon V, should I be worried? [Re: Bakes168] #4493214
08/19/17 08:41 PM
08/19/17 08:41 PM
Michigan
Bakes168 Offline OP
Bakes168  Offline OP
Michigan
That's great news, thank you all for the info!
Now, I just wish WM sold Valvoline spec'd for Mercon V in gallon jugs like the Dex/Merc....
Re: Mercon V, should I be worried? [Re: Bakes168] #4494465
08/21/17 01:46 PM
08/21/17 01:46 PM
Utah, USA
28oz Online content
28oz  Online Content
Utah, USA
The Walmart Supertech Mercon V bottles are labeled as Ford approved/licensed. Should be as good as any other?
Re: Mercon V, should I be worried? [Re: Bakes168] #4502723
08/30/17 08:10 PM
08/30/17 08:10 PM
Michigan
Bakes168 Offline OP
Bakes168  Offline OP
Michigan
I don't think I saw any of the Supertech stuff last time, I may have overlooked it. They certainly didn't have any in gallon jugs like I want.
