2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
106 registered members (240_Ed, 1foxracing, Bailes1992, bandito, Astro14, 11 invisible), 1,701 guests, and 38 spiders.
Topics295,211
Posts4,930,031
Members66,711
Most Online2,553
Oct 27th, 2018
Drill Master rotary buffer #4492217
08/18/17 06:06 PM
08/18/17 06:06 PM
Massachusetts
turtlevette Offline OP
Massachusetts
I stopped at harbor freight yesterday on the way to the car show and picked up a drillmaster variable speed buffer on coupon for $29 and a black pad. After using it today I probably won't mess with a random orbital again when this knocks out a panel in 2 minutes. It does get hot but I'm putting a lot of pressure. A quick buff before a car show will be light pressure and quick. I could knock out the whole car in 10 minutes with this and meguiars 205.
Rotary is the way. You'd have to be incompetent to burn paint with one on a low setting.
USA-1
Re: Drill Master rotary buffer [Re: turtlevette] #4492243
08/18/17 06:30 PM
08/18/17 06:30 PM
Georgia
AVB Offline
AVB  Offline
Georgia
They are nice. I have clamped one in a vise to polish lenses on welding helmets and headlights.
Re: Drill Master rotary buffer [Re: turtlevette] #4492323
08/18/17 08:31 PM
08/18/17 08:31 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Wouldn't a faster RO do the same thing, without the chances of circular lines?
Re: Drill Master rotary buffer [Re: JHZR2] #4492384
08/18/17 09:49 PM
08/18/17 09:49 PM
Massachusetts
Massachusetts
I had been using a 10" cheapo random dual action I got years ago at autozone. It only has off/on. It'd take 30 minutes to do a panel. Results were fine just took a long time.
Or a 30 year o!d black and decker rotary that only had 2 speeds fast and crazy fast. And it slung compound all over. Too hard to control. It stripped out its gearbox earlier this week.
This HF drill master has a continuously variable thumb wheel controller. So you can go only as fast as you're comfortable with. You have to give it a rest as it does get hot. It works out perfect 2-5 minutes to do a panel then about the same amount of time to wipe the compound off with a microfiber towel while it cools off.
I don't see any swirl marks. Maybe I need to get out my jewelers monocle, but I don't see them even on black lacquer. The meguiars 205 is pretty good stuff.
USA-1
Re: Drill Master rotary buffer [Re: turtlevette] #4492428
08/18/17 10:37 PM
08/18/17 10:37 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
You may want to try an IPA wipe on a panel. The oils in M205 are good at hiding any hologramming induced by rotary.
I prefer to finish (fine polish, wax) with a DA. Max speed on my DA with M205 and a finishing pad gets a panel to flawless QUICK.
"Zed's dead baby, Zed's dead."
Re: Drill Master rotary buffer [Re: rooflessVW] #4492510
08/19/17 03:19 AM
08/19/17 03:19 AM
Massachusetts
Massachusetts
Alcohol ruins lacquer. I'm really not that picky. This sucker looks fantastic, trust me.
USA-1
Re: Drill Master rotary buffer [Re: turtlevette] #4493423
08/20/17 06:55 AM
08/20/17 06:55 AM
North TX
RTexasF Online happy
RTexasF  Online Happy
North TX
Check it for holograms out in the sun.
Re: Drill Master rotary buffer [Re: JHZR2] #4493637
08/20/17 11:42 AM
08/20/17 11:42 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
No way, there is no comparison. DA's suck plain and simple, the sell because they are "safe" if you learn to use a rotary properly there is no swirls and they are fast. This one is great with electronic speed control, there are many left out in the wild so if anyone is interested grab one while you can.
I also use an air powered 10" one for bigger jobs but its a bit hard to handle for a beginner as is the full size electrics even with variable speed.
https://www.amazon.com/Astro-9901-Electric-Polisher-Compact/dp/B004WIWC02
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4204792/New_Cheap_Rotary_Buffer
Re: Drill Master rotary buffer [Re: turtlevette] #4494977
08/22/17 06:42 AM
08/22/17 06:42 AM
NorthEast
Vikas Offline
Vikas  Offline
NorthEast
Can you show the picture? I am suspecting you had a wax spreader which comes in 10 inches and has two handles on the side. That was no DA polisher.
Re: Drill Master rotary buffer [Re: turtlevette] #4495757
08/23/17 12:16 AM
08/23/17 12:16 AM
Massachusetts
Massachusetts
Looks just like this one. I get its a light duty unit.
USA-1
Re: Drill Master rotary buffer [Re: turtlevette] #4495759
08/23/17 12:42 AM
08/23/17 12:42 AM
North TX
North TX
No, it is a wax spreader and light years behind a good DA or rotary polisher.
Re: Drill Master rotary buffer [Re: turtlevette] #4496855
08/24/17 09:19 AM
08/24/17 09:19 AM
NorthEast
Vikas Offline
Vikas  Offline
NorthEast
Looking forward to "Finish looks very bad but only in direct sunlight" topic soon by OP :-)
Re: Drill Master rotary buffer [Re: turtlevette] #4496927
08/24/17 11:20 AM
08/24/17 11:20 AM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Nope - that's not a DA polisher, turtlevette.. in fact it's as far removed from a proper DA orbital polisher as a clawhammer is removed from a jackhammer.
THIS is a proper DA Orbital polisher:
I would use one of these over a rotary polisher if you are not absolutely familiar with how a rotary works, and how it can damage your paint.
.. if I were you, I'd be looking VERY closely at the paint in direct sunlight to insure it wasn't covered in swirls now.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 266,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 60,000mi
Re: Drill Master rotary buffer [Re: Trav] #4499776
08/27/17 07:18 PM
08/27/17 07:18 PM
MTL, CANADA
Rolla07 Online content
Rolla07  Online Content
MTL, CANADA
Great advice! I bought one of them per Trav's advice, and while I have yet to use it, my friend also bought one and used it on his black benz and results were spectacular. You also cant beat it for the price.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Drill Master rotary buffer [Re: turtlevette] #4500111
08/28/17 07:18 AM
08/28/17 07:18 AM
pennsylvania
purelux Offline
purelux  Offline
pennsylvania
They do produce a better result and faster but what is possible and what is likely are not always the same. To repaint a car oem quality is thousands of dollars. So you need to consider if someone will use it enough or be careful and not cause damage. Yes da is slower and less effective but if I talked someone into a rotary instead, then they wrecked their paint. I really doubt arguing it's their fault rotary is better will make them forgive you that $3000+ paint job.
