It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
95 registered (alcyon, andyd, 1foxracing, Bandito440, 2015_PSD, 15 invisible), 1308 Guests and 66 Spiders online.
65319 Members
67 Forums
285959 Topics
Page 1 of 2 1 2 >
#4492066 - 08/18/17 04:30 PM Silverado dies while idling
LAGA Offline
Loc: IL
I have a well kept 2007 Silverado NBS 6.0 with 87K miles. 6 month OCI, injector cleaner every 3-4 months, heated garage. A week ago it died while idling in a fast food drive thur. The engine would turn over, but it would not start. No CEL. It had to be towed home where after sitting for an hour it restarted. There were no codes found using a Scangauge II. The next day, it ran great until returning home and I let it idle in the driveway, and after 3 minutes it died. No CEL, No codes. It had to sit for 4 hours until it would restart. I then took it to my mechanic where after 2 days of running and idling he found no problems or codes. I took the truck back for a week and I removed and cleaned the throttle body hoping that would help. It just died again today after pulling into a parking spot at the grocery store. No CEL. It restarted only when I held the gas peddle down while cranking. I got it home and again , no codes. Any ideas? I`m thinking crankshaft position sensor. Thanks
Four legs good, two legs better!
#4492070 - 08/18/17 04:34 PM Re: Silverado dies while idling [Re: LAGA]
Arkandspark Offline
Loc: Oklahoma
Electric fuel pump going out?
#4492073 - 08/18/17 04:41 PM Re: Silverado dies while idling [Re: Arkandspark]
LAGA Offline
Loc: IL
Mechanic says it fine.
#4492074 - 08/18/17 04:41 PM Re: Silverado dies while idling [Re: LAGA]
OneEyeJack Offline
Loc: S California
I'd start by changing the fuel filter and then looking at the fuel pump.
From there it's a matter of trouble shooting, things like the torque converter lock up solenoid and on to the rest of the fuel system after checking for leaks.
#4492079 - 08/18/17 04:48 PM Re: Silverado dies while idling [Re: LAGA]
NHGUY Offline
Loc: USA
I've seen starting issues with an Idle Air Valve sticking.It takes full throttle opening to start.
#4492083 - 08/18/17 04:51 PM Re: Silverado dies while idling [Re: LAGA]
LAGA Offline
Loc: IL
Fuel filter and pump are a single unit inside of the fuel tank which has to be dropped to change.
#4492086 - 08/18/17 04:53 PM Re: Silverado dies while idling [Re: NHGUY]
LAGA Offline
Loc: IL
I`ll look into that
#4492099 - 08/18/17 05:06 PM Re: Silverado dies while idling [Re: LAGA]
Merkava_4 Offline
Loc: Clovis, CA
Does it die slowly, or does it die quick like if somebody turned the key off ?
#4492111 - 08/18/17 05:18 PM Re: Silverado dies while idling [Re: Merkava_4]
LAGA Offline
Loc: IL
Slowly, and when AC kicks in.
#4492128 - 08/18/17 05:37 PM Re: Silverado dies while idling [Re: LAGA]
CKN Offline
Loc: Utah
Maybe this thread may help-
http://www.silveradosierra.com/vortec-5-3l-v8/normal-idle-t600969.html
#4492136 - 08/18/17 05:49 PM Re: Silverado dies while idling [Re: LAGA]
vwmaniaman Offline
Loc: Kevil,Ky
My daughters Nissan Sentra 2001, was doing that sort of thing. Cutting out at idle and when she would start up from a stop and when it shifted. We had replaced fuel pump and checked grounds and re grounded the ECU and replaced the TPS. Ended up being the Bosch single platinum spark plugs. Read about them not being good and causing problems. They looked perfect when I pulled them and replaced them with Autolite Platinums. No more issues at all.
Don't waste your time on a slipshod repair.
#4492141 - 08/18/17 05:59 PM Re: Silverado dies while idling [Re: CKN]
LAGA Offline
Loc: IL
After doing some reading, I believe if this was the case there would be a code thrown. Thanks
#4492159 - 08/18/17 06:13 PM Re: Silverado dies while idling [Re: LAGA]
CKN Offline
Loc: Utah
True-but the truck doesn't always throw the code FYI.
#4492234 - 08/18/17 07:23 PM Re: Silverado dies while idling [Re: LAGA]
Lignums Offline
Loc: Ohio
Check your fuse box. Mine developed a short inside the fuse box itself. It would run great until it warmed up and then stall out. When testing out the wires for shorts I could shut the motor off by pushing down on the box, pulling up on it kept it running. Dealer only item is the bad news.
1998 Chevy w/t 1500 4.3
2004 Buick Lesabre 3.8
2006 Gmc envoy xl 5.3
#4492241 - 08/18/17 07:28 PM Re: Silverado dies while idling [Re: LAGA]
JohnnyJohnson Offline
Loc: Wet side WA
Boy if that isn't a GM better idea to keep you coming to their shop!
2004 Toyota Corolla 121808
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
Page 1 of 2 1 2 >
