Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
43 registered members (alarmguy, Char Baby, bullwinkle, AZjeff, Ctreasure, 6 invisible), 1,034 guests, and 45 spiders.
Topics295,207
Posts4,929,909
Members66,711
Most Online2,553
Oct 27th, 2018
PP 0W-20 10,065 miles Accord V6 6MT #4491826
08/18/17 09:50 AM
08/18/17 09:50 AM
Georgia, USA
Daschicken Offline OP
Georgia, USA
19 months and 10,065 miles of use got me these results. According to average speeds from fillups, fuelly is saying I do 2/3 highway and 1/3 city driving. I usually drive at very low rpm except when accelerating, and I shut the engine off when I am going to be waiting at a stop light for more than 15 seconds. As of lately, probably the last thousand or so miles in this oil change I got an engine block(coolant) heater and have been preheating the car before starting it. Yes, even when it is 85 degrees outside I still use the heater. The engine will idle at 1000 rpm cold, or 700 rpm if preheated, and it runs smoother when preheated as well!
At around the 7000 mile mark I had to add a quart of oil, I had an oil pan and drain plug leak that were fixed after this oil change, so I may not have to add any oil this time around.
Here is what Blackstone had to say:
"We're not sure how the TBN would've read without the added oil. Probably lower, but it's hard to say how much. In terms of metals, only aluminum (pistons or bearings) is a bit elevated. Iron is high, but since it accumulates with use, this level is fine for the mileage. The TBN's good at 2.5, and no contamination was found. Let's see how aluminum looks after 11,500 miles."
Code:
Oil       Penzoil Platinum 0W-20         Universal averages
Miles in use          10,065
Miles                 148,814
Sample taken         6/25/2017
Make up oil added       1 qt
Aluminum                 9                              3
Chromium                 1                              1
Iron                    20                              9
Copper                   1                              9
Lead                     0                              2
Tin                      1                              1
Molybdenum              51                              74
Nickel                   0                              0
Manganese                2                              1
Silver                   0                              0
Titanium                 0                              2
Potassium                1                              2
Boron                    5                              51
Silicon                 13                              11
Sodium                  78                              38
Calcium                2190                            2109
Magnesium                7                              130
Phosphorus              610                             691
Zinc                    693                             815
Barium                   0                              0
                               Values Should be
SUS Viscosity @ 210F    53.0         46-49
cST Viscosity @ 100C    8.17        6.0-10.2
Flashpoint in F         430           >385
Fuel %                 <0.5           <2.0
Antifreeze %            0.0            0.0
Water %                 0.0           <0.1
Insolubles %            0.3           <0.6
TBN                     3.5           >1.0
2006 Accord V6 6 Speed Sedan-146K
0W20 PP
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4491833
08/18/17 10:07 AM
08/18/17 10:07 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The block heater is a waste of time.
I would do another 10k OCI and not listen to Blackstone who want to push it.
2015 Ford F250 w/Powerstroke
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Donald] #4491849
08/18/17 10:22 AM
08/18/17 10:22 AM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
Especially with 0w20 in the south. In winter months maybe, but not in the summer. Some of those block heaters pull a good amount of electricity (might not be much $$ wise I'm not sure).
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Donald] #4491856
08/18/17 10:43 AM
08/18/17 10:43 AM
Georgia, USA
Georgia, USA
I want to push it. My undertray isn't all that fun to remove and put back on...
As far as the cost of block heating: The electricity can pay for itself in improved fuel economy with UP TO 3 hours of heater use. After that, the heat introduced and the heat lost to surroundings pretty much equal out. You can rely on a block heater to heat the coolant about 50 degrees F above ambient, but that is about all it will do. I plug in my heater for between 30 minutes to 2 hours and get increased coolant temps between 15 degrees F and 40 degrees F, even in 70+ degree weather.
0W20 PP
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4491859
08/18/17 10:47 AM
08/18/17 10:47 AM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
Is all that undertray factory??
Also, fair enough about your points on electricity and fuel economy, it sounds like you've worked out the numbers.
2017 VW GTI sport
1995 Mustang GTS
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4491869
08/18/17 11:06 AM
08/18/17 11:06 AM
MD
AirgunSavant Offline
MD
That cover is a mess!
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: HemiHawk] #4491873
08/18/17 11:11 AM
08/18/17 11:11 AM
Georgia, USA
Georgia, USA
Nope, not factory. This is what it would look like from the factory.
It is dirty because it used to leak oil, and my hands are usually oily when working on it. Plus that stuff doesn't really want to come out!
Here is the rear diffuser, which IS factory on the hybrid models.
0W20 PP
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4491886
08/18/17 11:26 AM
08/18/17 11:26 AM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
Now I only have more questions... What is the tray for? Did you add it for fuel economy savings on the highway? What is it made of? if it works to a measurable degree its pretty neat.
I do remember the filter location on my 08 Civic Si to be horrible, not sure if its the case with your 3.0.
2017 VW GTI sport
1995 Mustang GTS
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4491895
08/18/17 11:37 AM
08/18/17 11:37 AM
Minnesota
JoelB Online content
JoelB  Online Content
Minnesota
Seems like a whole lot of effort for not much gain.
Mine: 2018 Chevy spark (White) 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Wife's: 2018 Chevy spark (Blue) 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4491918
08/18/17 12:07 PM
08/18/17 12:07 PM
Danh Offline
Danh  Offline
Dunno if these UOA results are abnormal or not, but I'd stop turning off the engine at stoplights and ditch the underbody tray. There's always a bit of extra wear during start-up; factory designed systems crank the engine much faster before introducing fuel, which mitigates the problem. And one unintended consequence of the underbody tray could be higher oil temperature as it seems to inhibit airflow over the oil pan. Perhaps neither issue is a contributor, but just my $.02.
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4491955
08/18/17 12:48 PM
08/18/17 12:48 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
I keep wondering how these and the K24 models would "like" 5W30 vs 0W20,especially in the southern US.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 5W20
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4491960
08/18/17 12:53 PM
08/18/17 12:53 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
~1 ppm/1k for aluminum and 2 ppm/1k for Iron?
No problem.
However, the added 1 quart at 7K definately skewed the results somewhat.
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4491961
08/18/17 12:53 PM
08/18/17 12:53 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
dupe
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4492036
08/18/17 02:49 PM
08/18/17 02:49 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
I would recommend using duct tape on the body panel gaps, to get better fuel economy. grin
If you want to push it more, you should use PUP. I wouldn't extend it with PP without seeing the TAN.
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: PP 0W-20 10,065 miles Accord V6 6MT [Re: Daschicken] #4492084
08/18/17 03:51 PM
08/18/17 03:51 PM
Ontario, Canada
MobilinHyundia Online content
MobilinHyundia  Online Content
Ontario, Canada
I do 15 000 miles on PP and the results are excellent. Now we get PUP in Canada which I still have not tried but hopefully soon.
RIP......2009 Sonata GL 2.4L (226000km)-QS FS 5W20, OEM oil filter
2009 Sonata LTD 2.4L (170000km)Castrol Edge 5W20,
2018 Sedona SX+ -TOTAL INEO mc3 5W30 with Kia filter
