2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
86 registered members (alphadog, Aichiguy, agpatel, AdditiveOCD, 77GrandPrix, 11 invisible), 1,422 guests, and 62 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Castrol GTX Magnatec 10W-30 #4491786
08/18/17 09:58 AM
08/18/17 09:58 AM
Douglas County, Colorado
bigj_16 Offline OP
bigj_16  Offline OP
New Product Data Sheet as of 08/16/2017
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/839908B7F978D4B18025817E00560781/$File/BPXE-9RBLF6.pdf
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4491796
08/18/17 10:07 AM
08/18/17 10:07 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
Impressive NOACK.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4491811
08/18/17 10:24 AM
08/18/17 10:24 AM
bigj_16 Offline OP
bigj_16  Offline OP
I think these are pretty good specs for a "synthetic blend". What is interesting, also, is that Castrol is pricing this at about $26 (5 qt.) on Amazon and at Walmart, which is on the high end for a "synthetic blend".
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4491820
08/18/17 10:38 AM
08/18/17 10:38 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
The Walmart here has it for $19.xx.
That Noack number is excellent! Thanks for sharing.
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
ST SYN 5W30, ST9688 (next)
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
M1HM 10W30, OEM (next)
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4491822
08/18/17 10:45 AM
08/18/17 10:45 AM
NC
BigD1 Offline
BigD1  Offline
NC
5W-30 was a blend up unitl early Spring of this year, and then it changed over to full synthetic. Not sure about 10W-30, but it could be full syn now because the retailers were still showing the old syn blend label for the 5W-30 long after it had changed over. My local Walmart will still have some of the old jugs of the 5W-30 syn blend on the shelves some times.
1992 Toyota Pickup--Castrol GTX 10W-40--ACDelco PF53
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4491824
08/18/17 10:48 AM
08/18/17 10:48 AM
bigj_16 Offline OP
bigj_16  Offline OP
It is listed as a blend on the Castrol USA website
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4491827
08/18/17 10:52 AM
08/18/17 10:52 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Correct...
http://www.castrol.com/en_us/united-stat...-motor-oil.html
M1HM 10W30, OEM
PPeL 5W30, OEM
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4491829
08/18/17 10:59 AM
08/18/17 10:59 AM
bigj_16 Offline OP
bigj_16  Offline OP
Those SOB's over in the UK get "Castrol Magnatech Stop-Start". Now I feel inadequate. wink
http://www.castrol.com/en_gb/united-king...stop-start.html
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4491836
08/18/17 11:10 AM
08/18/17 11:10 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
I'm with you on that one. A few more certs than our version.
M1HM 10W30, OEM
PPeL 5W30, OEM
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4491945
08/18/17 01:30 PM
08/18/17 01:30 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
I cant download from that link.
What is the noack ?
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4492008
08/18/17 03:12 PM
08/18/17 03:12 PM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
GTX Magnatec 10W-30
CLINGING MOLECULES PROTECT FROM THE START
Description
Did you know testing confirms that up to 75% of engine wear occurs during the first 20 minutes of warm up?*
When your engine stops, oil drains off critical engine parts, but Castrol GTX MAGNATEC’s intelligent molecules don’t –
they form an extra layer of protection during warm up, when your engine needs it most, dramatically reducing engine
wear and keeping critical parts up to 4X smoother.*
* As tested in the industry Sequence IVA wear test.
Castrol GTX MAGNATEC also delivers:
Superior wear protection on critical engine parts
Unsurpassed level of protection against viscosity breakdown
Unique synthetic technology to fight against harmful sludge build-up
High level of fuel economy based on US industry standards
Typical Characteristics
Name Method Units Typical Values
Density @ 15C, Relative ASTM D4052 g/ml 0.87
Appearance Visual - Clear & Bright
Viscosity, Kinematic 100C ASTM D445 mm˛/s 11.6
Viscosity, CCS -25C ASTM D5293 mPa.s (cP) 3702
Viscosity, HTHS 150C ASTM D4683 cP 3.18
Viscosity, MRV / Yield Stress -25C (15W) ASTM D4684 mPa.s (cP) 16266
Noack Volatility ASTM D5800 % Loss 6.95
Viscosity, Kinematic 40C ASTM D445 mm˛/s 71.54
Viscosity Index ASTM D2270 None 157
Pour Point ASTM D97 °C -39
Viscosity, Brookfield Scanning ASTM D5133 °C 17331
70 Camaro 5.7L 59k
Re: Castrol GTX Magnatec 10W-30 [Re: bigt61] #4492009
08/18/17 03:12 PM
08/18/17 03:12 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Great NOACK for a blend. I'd use it thumbsup
There's no replacement...'scosity for natural viscosity
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4492038
08/18/17 03:50 PM
08/18/17 03:50 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Thanks nice oil.
Dont know why my phone cannot download castrol pdfs or chevron pdfs even from their websites.
Valv qs pp m1 downloads are okay !
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4492095
08/18/17 05:04 PM
08/18/17 05:04 PM
MD
AirgunSavant Offline
MD
Given the great results of the old 5w30 I'm not sure a FS version of the 10w30 brew would be that much better. I don't buy CM. At $25.
New Jet.com customers can get it sometimes for $13 when you use the 15% coupon. I did last month.
You have to keep an eye on it.
Re: Castrol GTX Magnatec 10W-30 [Re: bigj_16] #4492183
08/18/17 06:38 PM
08/18/17 06:38 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Looks pretty good.
If the NOACK and CCS numbers are to be trusted, this stuff would be a really good pick.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
