Brakes not working - brake pedal sinks
by tookien
49 minutes 1 second ago
Dave thinks I can make it 12--15k
by Marco620
Today at 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
Today at 12:16 AM
One Dollar Per Gallon?
by Y_K
Yesterday at 11:53 PM
Walmart Tightening up Returns
by John_K
Yesterday at 10:21 PM
flare nut wrench set
by spasm3
Yesterday at 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
Yesterday at 09:45 PM
How much is too much?
by Sealbilly
Yesterday at 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
Yesterday at 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
Yesterday at 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
Yesterday at 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
Yesterday at 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
Yesterday at 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
Yesterday at 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
Yesterday at 06:13 PM
2011 Chevy equinox overheating
by hardcore302
Yesterday at 06:00 PM
Are my rotors warped?
by Dylan1303
Yesterday at 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
Yesterday at 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
Yesterday at 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
Yesterday at 04:38 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
32 registered (1WildPig, ctechbob, Backwoods41695, clinebarger, David2431, 2015_PSD), 887 Guests and 46 Spiders online.
65265 Members
67 Forums
285573 Topics
Page 1 of 2 1 2 >
#4491543 - 08/18/17 01:48 AM MC FL 820S Issues?
PumpPusher Offline
Loc: Texas
My Crown Vic has a bit of a start up rattle. Not nearly as bad as the first start after an oil change, but very noticeable. When I first got the car, it had a Valvoline filter. After the first change, I went with the 820 and the sound went away. Then it started with the 820 once I passed 8k on my OCI. I change my oil every 10k and each time the noise comes back earlier and earlier. Now it started at 2k. Could it be a filter? I haven't tried an Fram Ultra since I had a stash of 820s.
#4491557 - 08/18/17 02:51 AM Re: MC FL 820S Issues? [Re: PumpPusher]
Char Baby Offline
Loc: ROCHESTER, NY
Yeah, try another filter!
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4491559 - 08/18/17 03:10 AM Re: MC FL 820S Issues? [Re: PumpPusher]
Nyogtha Offline
Loc: San Antonio, TX
^^^ +1
It doesn't have to be a Fram Ultra, but if you have one handy, why not?
If you want you stay with base end bypass you could try a Mopar MO-899 but note it has a nitrile ADBV.
Edited by Nyogtha (08/18/17 03:12 AM)
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
#4491575 - 08/18/17 04:32 AM Re: MC FL 820S Issues? [Re: PumpPusher]
PumpPusher Offline
Loc: Texas
I will, but what are the chances of getting 4 "bad" filters in a row? Could it be something else?
#4491578 - 08/18/17 04:48 AM Re: MC FL 820S Issues? [Re: PumpPusher]
Nyogtha Offline
Sure, anything's possible, but trying a different manufacturer's oil filter is an inexpensive way to rule out that component, right?
You indicate it goes away for at least 2K miles after an oil filter change, so what else other than oil is connected to your oil filter changes?
FWIW you can change the oil filter while the noise is present without changing the oil, you can just top off with the same oil to keep that variable constant with trying a new oil filter.
Some oil filters manufactured by Purolator have been exhibiting sharkbit silicone ADBV's here on BITOG.
Edited by Nyogtha (08/18/17 04:55 AM)
#4491592 - 08/18/17 06:11 AM Re: MC FL 820S Issues? [Re: PumpPusher]
bullwinkle Offline
Loc: Cincinnati, OH, USA
The XG2 fixed my MGM 4.6, after it rattled with a Hastings, and even an Affinia/Wix made CQ Blue. 5W20 Magnatec helped too.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4491594 - 08/18/17 06:16 AM Re: MC FL 820S Issues? [Re: PumpPusher]
bullwinkle Offline
Edited by bullwinkle (08/18/17 06:17 AM)
Edit Reason: double post
#4491629 - 08/18/17 07:18 AM Re: MC FL 820S Issues? [Re: PumpPusher]
DdDd Offline
Loc: NY
It sounds like by your 8k oci the oil is done in that motor.
Not every oil can last that long and its certainly past the recommended limit for older crown vics. Try another oil or test a sample. Shorter intervals.
#4491657 - 08/18/17 07:46 AM Re: MC FL 820S Issues? [Re: PumpPusher]
HemiHawk Offline
Loc: PA,US
Never had an issue like that with my Mustang (4.6 3v) using nothing but 820s filters. However, my OCIs were usually closer to 3k miles. That has been mostly from my "spirited" driving habits and length of time it takes to get me to those miles.
I will say... I just switched to a Fram Ultra XG2 after all the praises they receive on this site. Did my usual Mobil 1 5w20, and this filter. The thing I noticed is that on a "cold" start (over 70f) the engine RPM sits at a higher state than before. Good/Bad? I have no idea just something I noted. Once it finally does fully warm up I guess it settles back to normal rpm at idle.
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1997 Jeep GC 4.0
#4491659 - 08/18/17 07:50 AM Re: MC FL 820S Issues? [Re: PumpPusher]
123Saab Offline
Loc: PA
I have used the 820s for years in our 03 Ranger, and never had a startup noise of any kind. 5k OCI with Formula Shell 5w-30.
As others have stated, you're running it and the oil too long.
Twenty-twenty-twenty four hours to go I wanna be sedated
Nothin' to do and no where to go-o-oh I wanna be sedated
#4491749 - 08/18/17 09:30 AM Re: MC FL 820S Issues? [Re: PumpPusher]
merconvvv Offline
Loc: il usa
Nothing but 820 here.
No sounds filter related atleast what i can tell.
You could change to another new 820 filter to see if noise goes away since u have a stash of these filters. Add .25 quarts to .5 quarts of oil as needed. The first start might be noisy but after that
If u still have noise change the oil to see if that makes it go away.
If u still have noise try heavier oil like 10w30 or blend of 5w20 and 10w30 if heavier oil is not your cup of tea.
Is the noise present on cold start after the car has been sitting around or even on hot start ?
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
#4491783 - 08/18/17 09:57 AM Re: MC FL 820S Issues? [Re: PumpPusher]
AirgunSavant Offline
Loc: MD
I think the 820's get a bad rap. They make excellent door stops.
#4491798 - 08/18/17 10:11 AM Re: MC FL 820S Issues? [Re: PumpPusher]
RF Overlord Offline
Loc: Cape Cod, MA
I've used the FL820S on all of my (and relatives) cars for the past 14 years. 2 Grand Marquis', 2 Marauders, and a Mustang. Never heard a start-up rattle other than the one immediately after an oil change.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
'00 Grand Marquis GS - daily driver
MC 5W-20 / MC FL820S
#4491854 - 08/18/17 11:35 AM Re: MC FL 820S Issues? [Re: HemiHawk]
ZeeOSix Offline
Loc: PNW
Idle speed not dependant on what oil or filter is used. Mostly dependant on engine/coolant and ambient temperatures.
#4491941 - 08/18/17 01:27 PM Re: MC FL 820S Issues? [Re: PumpPusher]
Nitronoise Offline
Loc: Chicago Suburbs
I just serviced my wifes freestyle and 3 weeks later i was out when she left for work and heard a rattle so I am changing out her fl820
other wise I will go to a bosch
07 Ford Freestyle 135K
04 Hyundai Sonata 280K
03 Hyundai Santa Fe 165K
02 Ford Tarus 98K
00 Buick Regal SC 135K
95 Goldwing 28K
Page 1 of 2 1 2 >
