Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
87 registered members (AndyB, 16HC, advocate, ABomb369, Ablebody, aquariuscsm, 7 invisible), 1,212 guests, and 38 spiders.
Topics290,699
Posts4,848,544
Members66,021
Most Online3,590
Jan 24th, 2017
Anything wrong with using CI-4 oil? #4491518
08/17/17 11:52 PM
08/17/17 11:52 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
Now that they have this CK-4 oil and I see the weak additive package it has, why not use a good old school ci-4 oil with high tbn and ZDDP numbers? Imo it's the same as the newer stuff, just a tried an true and cheaper method of anti wear additives. Of course the only issue is the the API donut won't be current since the license expired or whatever you call it.
Opinions?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Anything wrong with using CI-4 oil? [Re: motor_oil_madman] #4491525
08/18/17 12:09 AM
08/18/17 12:09 AM
USA
Reddy45 Offline
Reddy45  Offline
USA
If you can still find CI-4 then go for it... but CK-4 is not inherently bad because the additive makeup is different.
Re: Anything wrong with using CI-4 oil? [Re: motor_oil_madman] #4491542
08/18/17 01:39 AM
08/18/17 01:39 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
I'm going back to Amsoil AME (CI-4) on my next OCI.
Extraordinarily good oil that delivers results.
Re: Anything wrong with using CI-4 oil? [Re: motor_oil_madman] #4491546
08/18/17 02:22 AM
08/18/17 02:22 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
There's nothing wrong with it, but there's nothing wrong with a modern CK-4, either. We went through this whole schtick with the CJ-4 rollout, too.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Anything wrong with using CI-4 oil? [Re: Garak] #4491552
08/18/17 02:44 AM
08/18/17 02:44 AM
USA
ArcticDriver Offline
USA
Except that Ford did not have an issue with CJ-4 and my Pwerstrokes were new when CJ-4 came out and that oil was basically made for them while the CK-4 is made for the new diesels and not optimally designed for my older trucks.
Multiple Diesel and Gasoline vehicles
Re: Anything wrong with using CI-4 oil? [Re: ArcticDriver] #4491558
08/18/17 03:02 AM
08/18/17 03:02 AM
Garak Offline
Garak  Offline
That may be, but there still was a Kubota panic at CJ-4 rollout, not to mention the general panic. When the first Powerstrokes came out, CJ-4 was years away yet. What, specifically, in CK-4 is not optimal for your older trucks?
Even when the 7.3 Powerstroke came out, Ford found something to panic about with respect to contemporary HDEOs. Wakefield, Chevron, Petro-Canada, Mobil, Esso, and Shell all knew nothing about making an HDEO, to hear Ford tell it back then, too, unless it had a Motorcraft label on it. Whoever made that oil at the time apparently knew what they were doing, but forgot the procedure when working on other product lines.
Dodge up here is giving away a free Cummins upgrade to people buying a new Dodge 2500 or 3500. Ford is telling us that most off the shelf HDEOs are incompatible with a new Ford diesel truck, and even their old ones, perplexingly. That's a great way to compete with Dodge right now.
Re: Anything wrong with using CI-4 oil? [Re: motor_oil_madman] #4491593
08/18/17 06:14 AM
08/18/17 06:14 AM
Michigan, USA
Bighorn2500 Offline
Bighorn2500  Offline
Michigan, USA
If you don't have a DPF you're good to go, I periodically check craigslist and score CI-4 or CJ-4 lately due to people selling their oil inventory after getting rid of their diesel trucks.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2015 Jeep Cherokee 3.2L Latitude 4x4
Re: Anything wrong with using CI-4 oil? [Re: motor_oil_madman] #4491646
08/18/17 07:34 AM
08/18/17 07:34 AM
Houston, Texas
Houston, Texas
I know their is a gas station near me that sells ci4 oil. I forgot the name but it is a company from Lousians if I remember right.
Re: Anything wrong with using CI-4 oil? [Re: motor_oil_madman] #4491658
08/18/17 07:48 AM
08/18/17 07:48 AM
Houston, Texas
Houston, Texas
Its called pure guard and it looks like Oriellys sells it.
Re: Anything wrong with using CI-4 oil? [Re: Bighorn2500] #4491691
08/18/17 08:37 AM
08/18/17 08:37 AM
Houston, Texas
Houston, Texas
what's the difference between ci-4 and ci-4 plus?
Re: Anything wrong with using CI-4 oil? [Re: motor_oil_madman] #4491747
08/18/17 09:29 AM
08/18/17 09:29 AM
Michigan, USA
Bighorn2500 Offline
Bighorn2500  Offline
Michigan, USA
"The “CI-4 PLUS” designation identifies oils formulated to provide a higher level of protection against soot-related viscosity increase and viscosity loss due to shear in diesel engines. When originally introduced, CI-4 PLUS identified CI-4 oils meeting a higher level of performance. CJ-4 oils include all CI-4 PLUS performance requirements."
Probably due to when they introduced EGR on the diesels requiring the soot suspension/protection is my thoughts.
Garak or Dnewton may be able to elaborate further on this.
Re: Anything wrong with using CI-4 oil? [Re: Bighorn2500] #4492290
08/18/17 08:41 PM
08/18/17 08:41 PM
Louisiana
OLEJOE Offline
OLEJOE  Offline
Louisiana
I use Mobil Delvac MX F2 acquired a Zoro. $22.00 a gallon and free shipping on 3 gallons. I order a full case of 4 each time. It's a CI-4+ oil that I use in my tractor. No DPF or EGR. Same rating as CAT DEO and about the same price but it's delivered to my house and I don't have to go pick it up. Haven't been able to find a virgin analysis of it but my tractor seems to like it.
Jack of All Trades. Master of some.
Re: Anything wrong with using CI-4 oil? [Re: Garak] #4493483
08/20/17 09:24 AM
08/20/17 09:24 AM
Central Iowa
TiredTrucker Offline
Central Iowa
And Ford doesn't have an issue with all CK-4 oils. There are many on the current Ford approved list in both 10w30 and 15w40 varieties.
Yeah, the CI-4+ was in response to EGR, and CJ-4 in response to DPF's. Now CK-4 is also for protection of emissions treatment systems along with the current trend to down speeding heavy diesel engines and the increased heat internally from doing so. Supposedly better oxidation control.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: Anything wrong with using CI-4 oil? [Re: TiredTrucker] #4495433
08/22/17 05:38 PM
08/22/17 05:38 PM
Garak Offline
Garak  Offline
No, they certainly don't have an issue with all CK-4 oils. But, when you look at the 5w-40 portion of the list, things are pretty sparse when it comes to big names. Delvac doesn't show up at all in any viscosity. That kind of thing isn't helpful at all.
CI-4+ also had enhanced soot control.
