Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
103 registered members (94astro, 1.8Tango, 02z, 16 invisible), 2,379 guests, and 30 spiders.
Topics296,880
Posts4,960,772
Members66,987
Most Online2,688
Jan 19th, 2019
Noise damping of inner wheel wells #4491514
08/17/17 10:41 PM
08/17/17 10:41 PM
USA
DrRoughneck Offline OP
USA
I've taken measurements with a dB meter at various locations inside my truck and the loudest point in space in right above the front wheel wells at highway speed. Sure enough the wheel wells have just a thin plastic cover attached directly to the sheetmetal, not much is terms of sound dampening. It makes sense that most road noise comes from there, that's where the tires contact the pavement and where friction occurs.
I've looked at some luxury cars (which my car is not) and all have some sort of carpeting or thick heavy padding bolted to the wheel wells.
It sounds like the way to go. What would you use in there considering the swings in humidity, temperature and gravel projection?
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4491595
08/18/17 05:16 AM
08/18/17 05:16 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
I would look at placing sound deadening material on the inside(topside) of the wheel well liner. EBay has quite a variety of sound deadening adhesive butyl mats that would work.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4491618
08/18/17 05:48 AM
08/18/17 05:48 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
I had a 2004 Impala that had soundproofing behind the fenderwell.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4491627
08/18/17 06:10 AM
08/18/17 06:10 AM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Rubberized undercoating. Make sure there's no rust underneath, I wouldn't spray the removable plastic liners, spray the inner fender.
https://www.amazon.com/3M-03584-Professional-Rubberized-Undercoating/dp/B002H9CMCQ
Various musings: http://hangfire.net
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4491652
08/18/17 06:38 AM
08/18/17 06:38 AM
MA.
Camprunner Offline
Camprunner  Offline
MA.
Harbor Freight sells a Ruberized undercoating that works exceptionally well. They have a standard and professional grade in a can I can't think of the name off hand but I used it on my 2012 Nissan Pathfinder wheel wells and it works great. Stinks like [censored] for a few days but it works better then several other brands I have used over the years and it cost less.
The big thing in doing this is the prep get a few shop rags and two cans of Brake parts cleaner. First wash the wheel well good with soap and water then when dry spray down with brake clean and use the shop rags to wipe down the wheel wells real good. After dry spray the Ruberized undercoating on you should do at leased two coats and prob take two cans per side.
Re: Noise damping of inner wheel wells [Re: HangFire] #4491654
08/18/17 06:43 AM
08/18/17 06:43 AM
socal
barkingspider Offline
socal
This! But keep your expectations Low. I tried many different types of soundproofing/ deadening on some of my vehicles in the past. They do help a little, but not even close to my stock Cadillacs.
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4491828
08/18/17 09:52 AM
08/18/17 09:52 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
Damping NOT dampening.... were not making things moist.
As mentioned... it takes a bit to tone down the noise. I wouldn't expect a drastic change. It requires many "levels" of treatment.
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4491830
08/18/17 09:59 AM
08/18/17 09:59 AM
Los Angeles, CA
razel Offline
razel  Offline
Los Angeles, CA
Yes, I noticed that synthetic padding of sorts on the new-ish 2015 Infiniti on the inner wheel wells. On my older Infiniti, it doesn't have any and is like most cars, just metal. I ended up using underlay carpet padding above the rear wheel wells in the trunk and for the front wheels, neoprene just under the dash and above the pedals. Of course, do it safely since that's where the pedals are. I also did the door. Newer cars instead of a vapor wrap now seem to do a pretty good job of sealing, often a screwed in metal on the door, then a cardboard material like sound padding on the door plastic itself instead of a wrap. Ended up using thinner neoprene sheet cut out to the same shape on two of my early 2000's cars that still use a wrap.
I highly recommend it. It's not a tomb like seal, but it's still better. If I were to do it again, instead of the older underlay open foam carpet padding, I'd just the newer super compressed recycled jean/cloth underlay. Seems to have better sound adsorption.
Re: Noise damping of inner wheel wells [Re: razel] #4491882
08/18/17 11:24 AM
08/18/17 11:24 AM
USA
USA
Thanks for the tip. I'm looking for something to apply on the outside though.
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4491883
08/18/17 11:24 AM
08/18/17 11:24 AM
USA
USA
Have you guys used OSI's soundproofing caulk in automotive applications?
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4491970
08/18/17 01:12 PM
08/18/17 01:12 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
When purchasing any Rubberized Undercoating product, look for "Paintable" on the product label.
There are two types ... one is Asphalt based ... you don't want that one.
The other type has an oil-based paint carrier ... that's the one you want. It's paintable, the other usually* isn't, so thats the keyword you look for when shopping.
* I've seen asphalt-based rubberized undercoating that claims to be paintable. If you see the word "asphalt" anywhere on the product label, put it down and find another.
I've personally used Dominion Sure Seal Rubberized Rockerguard Undercoating, with excellent results. The usual suspects (Dupli-Color, etc) usually have a product, while the "Gold Standard" is 3MŽ's DynatronŽ Dyna-ProŽ Paintable Rubberized Undercoating PN 544, 6546.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4492763
08/19/17 10:53 AM
08/19/17 10:53 AM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
Acoustical caulk is designed to remain flexible when cured. It's also rather expensive for the brand name products. In a pinch, you could use Big-Stretch or Sonneborn's NP1.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Noise damping of inner wheel wells [Re: DrRoughneck] #4492767
08/19/17 10:57 AM
08/19/17 10:57 AM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
MLV (mass-loaded-vinyl) + vinyl adhesive would work. However, I'd remove the plastic fender liner first and install the MLV on the metal itself.
M1 10W-30 HM
