This for my 2001 Camaro that has the most monotone sound system I've ever heard in a car with a factory multi-channel amplifier.
Head Unit, Kenwood KDC-BT365U
5 Channel Amplifier, 60watts x 4 + 600watts Sub at 2 ohm's, Kenwood XR900-5
6 1/2" Component Speakers in the doors, JL Audio C3-600
6 1/2" 2 way speakers for the rear channels mounted in the sail panels, JL Audio C2-650X
Single 10" Subwoofer, JL Audio Steathbox
Pulling the entire interior & replacing all the speaker wiring (different routing), Running 4awg power & ground cables with a 175amp fuse for the Amp, 6 RCA's, Amp turn-on wire, power antenna wire, And install as much Dynamat as I can.
