Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
18 minutes 14 seconds ago
Ruger LCP .380
by PW01
Yesterday at 11:24 PM
Launching boat with stick shift
by troutfisher
Yesterday at 11:22 PM
Free oil
by Spitter
Yesterday at 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
Yesterday at 10:04 PM
RC cars
by red7404
Yesterday at 09:36 PM
Any Good 4K Movies ?
by Warstud
Yesterday at 09:06 PM
Gray on Oil Dipstick?
by chinee
Yesterday at 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
Yesterday at 08:15 PM
Parking wars show.
by Chris142
set for years
by 93cruiser
Yesterday at 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
Yesterday at 07:26 PM
Trying to fix chainsaw
by turtlevette
Yesterday at 06:48 PM
tire rotation
by marine65
Reese hitch $30 Walmart YMMV
by pda1122
Yesterday at 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
2016 Honda Pilot appears to be consuming oil
by pilot1226
Yesterday at 06:00 PM
New belt squeal cause damage to belt?
by pda1122
Yesterday at 05:33 PM
Food Safety - If You Have Children
by Zee09
Yesterday at 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
Yesterday at 05:02 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
53 registered (bbhero, 4WD, cb4017, boulderdentist, CKN, 3 invisible), 1060 Guests and 33 Spiders online.
65303 Members
67 Forums
285886 Topics
Page 1 of 2 1 2 >
#4491021 - 08/17/17 12:34 PM Michelin LTX M/S2 - dry rot severity
wing0 Offline
Loc: Ontario, Canada
Hi all,
Got these tires in Dec 2012 and put 80k km on them so far on a 2001 RX300 with 240k km.
I started noticing what looks to be dry rot.
I am thinking of keeping it for another year or so before either car is gone or we replace tires again.
or I should try and claim warranty now? They don't make M/S2 nor the new defender one in this tire size.
Only the Premier one is available, which I don't prefer based on the tread pattern as it may not be as good in winter time.
Opinion?
#4491028 - 08/17/17 12:41 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
Nick1994 Offline
Loc: Phoenix, AZ
They don't look that bad for Michelins. Nobody will warranty that out. I'd replace them in a year or so.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4491042 - 08/17/17 12:48 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
CKN Online   content
Loc: Utah
That dry rot comes at no extra charge for those expensive tires......
#4491044 - 08/17/17 12:53 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
typ901 Offline
Loc: N. 'Burbs of Chicago, IL
Those are identical to my 06' Lexus GX-470's, Michelin LTX M/S2 tires. Changed in 2013 with 40k miles and both tread and sidewall's are dry rotted. This is my first set of Michelin's that have done this. I'll be replacing them next month.
#4491049 - 08/17/17 12:59 PM Re: Michelin LTX M/S2 - dry rot severity [Re: typ901]
wing0 Offline
I actually have MXV4 on another car and now worried to see this happen to those too.
There was a recall on LTX M/S2, but only specific sizes.
Michelin is voluntarily recalling certain sizes of its MICHELIN® LTX® M/S 2, MICHELIN® X® Radial LT2 and MICHELIN® LatitudeTM Tour tires. These tires are typically found on light trucks and SUVs.
The tires were produced between September 2012 and early June 2013.
Sizes are as follows:
MICHELIN® LTXTM M/S 2: P275/55R20 111T RBL, P265/65R18 112T and P265/60R18 109T ORWL
MICHELIN® XTM Radial LT2: P265/65R18 112T and P275/55R20 111T
MICHELIN® LatitudeTM Tour: P255/60R19 108S and P255/70R18 112T
Michelin is recalling approximately 100,000 tires in order to retrieve an estimated 2,500 tires (about 2.5% of the recalled population).
Affected tires could have partial or full sidewall perforations that could cause them to experience loss of air pressure.
#4491065 - 08/17/17 01:21 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
nwjones18 Offline
Loc: Warner Robins, GA
Looks about right for a 5yr old Michelin. I've seen more of them showing early signs of dry rot than any other brand in my admittedly limited experience.
1988 F-150. 4.9 I6 247k. 10w-40 Castrol Syn-blend ACDelco UPF2.
2005 Cadillac STS N* 108k. 5w-30 Castrol Magnatec ACDelco Classic PF61
#4491068 - 08/17/17 01:25 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
Reddy45 Offline
Loc: USA
Seems pretty typical for Michelins.
Keep in mind that the outer tread of a tire is not there to hold air, but to provide traction. You are not at risk for a blowout based on the outer tread appearance alone.
#4491070 - 08/17/17 01:27 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
02SE Offline
Loc: The Canyons
So what's the problem? you have nearly 5 years and 50,000 miles on them. It sounds like you had good service from them, and will likely replace them in the not too distant future. At that time and mileage, I've seen similar deterioration from all brands of tires.
#4491084 - 08/17/17 01:41 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
69GTX Offline
Loc: Connecticut
My Michelin Primacy MXV4 are 3 yrs old with 25K miles and started showing lower side wall cracking last year. Probably 5-6 yrs total is all I can expect. The MXV4 set prior to this were factory originals and went 52K miles/13 years. Those tires were extensively cracked, though I really never noticed it until the tread was fully worn out. I don't even keep the car out in the sun - usually sits in the shade where ever I park it.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4491097 - 08/17/17 01:50 PM Re: Michelin LTX M/S2 - dry rot severity [Re: CKN]
ArcticDriver Offline
Loc: USA
Exactly, that is actually "siping" designed into the tire as the tread depth is worn away.
Seriously, it is just some weather checking (considered superficial) and not a warranty issue.
The new Defenders appear to be a decent tire and have a different compound in the material.
Multiple Diesel and Gasoline vehicles
#4491134 - 08/17/17 02:27 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
CELICA_XX Offline
Loc: Oklahoma
That doesn't look bad at all.
What is the date code ?
15 Toyota Prius - M1 EP 0w20
02 Toyota ECHO - Valv MaxLife Full Syn 5w30
97 Lexus LX450 - M1 0w40
93 Lexus LS400 - Valv MaxLife Full Syn 5w30
#4491137 - 08/17/17 02:29 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
Drive Em smile
#4491234 - 08/17/17 04:17 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
Rand Offline
Loc: NE,Ohio
Minor weather checking. not even close to serious "dry rot" yet.
also not warranty-able currently. and IIRC the warranty is 6 years on Michelin.
2017 Jeep Cherokee Trailhawk V6
#4491243 - 08/17/17 04:30 PM Re: Michelin LTX M/S2 - dry rot severity [Re: wing0]
Gasbuggy Offline
Loc: PA
LOL, probably still get $200 on craigslist
CTS-V+Recaros 5w30 Magnatec
Volvo P1800 5w30 Euro L
Land Rover Series 10w40 VWB
76' 300D Edge 0w40
02 Yukon 10w30 MaxLife
95 Accord - 386k. Mobil 2 RIP
#4491294 - 08/17/17 05:35 PM Re: Michelin LTX M/S2 - dry rot severity [Re: Gasbuggy]
Loc: USA
Yep...just advertise them as "used one season--like new" and they will be some of the deepest tread "one season" tires on there. grin
Page 1 of 2 1 2 >
