AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
75 registered members (2003f7, Aero540T, 2010Civic, agpatel, AdditiveOCD, 8 invisible), 1,344 guests, and 63 spiders.
Topics286,438
Posts4,908,166
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
oil for camshaft break in #4490979
08/17/17 12:03 PM
08/17/17 12:03 PM
SD - South Dakota
meborder Offline OP
meborder  Offline OP
SD - South Dakota
something went wrong with the engine in my plow truck so I found a low mileage replacement in the form of a 1990 305 from a c1500.
not being sure that the little 305 is up to the task of pushing snow and counter balance weight in a 3/4 ton truck, I've decided to put a bigger cam in the engine in hopes of bolstering performance all around. the nice thing about this is that the factory cam is SOOOO small, that it doesn't take much of a cam at all to increase performance through out the entire range.
FWIW, the cam I've chosen is a single pattern 204/204 @ 0.050" lift (260/260 advertised) and has 0.427" lift on intake and exhaust. this is a flat tappet engine. new lifters and appropriate springs are also part of the upgrade. this is still a small cam by just about anyone standards.
so, what do I use to break in the new camshaft at start up?
I've seen several break in oils available, but most of them are being advertised as containing no friction modifiers to aide in break-in. this makes sense for a full rebuild (not sure that I agree, but I it makes some sense), but for an engine that is all ready broken in except for the cam, I'm not sure that a oil without friction modifiers is really that good of an idea.
I'd prefer to buy the right oil, vs putting in an additive if at all possible.
the long term plan is to run it on a ZDDP rich oil for the remainder of my ownership.
any suggestions on specific oils to use?
Too many cars using too many different oils to list in 150 characters.
Re: oil for camshaft break in [Re: meborder] #4490984
08/17/17 12:08 PM
08/17/17 12:08 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
I may be wrong but most breakins are for the piston and rings not the cam and valve train
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: oil for camshaft break in [Re: meborder] #4490997
08/17/17 12:16 PM
08/17/17 12:16 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
You didn't mention any cam break in lube. You should certainly use that on the cam and lifters.
Also, make sure to get the engine fired and running quickly. If you end up with lots of cranking, you'll wipe all the lube off before the splash oiling starts.
I haven't done any flat tappet engines since they changed the oil but anything with zinc added should serve you well.
Re: oil for camshaft break in [Re: meborder] #4490999
08/17/17 12:18 PM
08/17/17 12:18 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Try a google search for break in for flat tappet cam .
I looked this up once , but can not remember the result . Forgot about it when it was pointed out to me that my 1991 305 Chevy engine had roller lifters .
Best of luck , :-)
Wyr
God bless
Re: oil for camshaft break in [Re: meborder] #4491022
08/17/17 12:36 PM
08/17/17 12:36 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
You could try something like this.
Re: oil for camshaft break in [Re: meborder] #4491040
08/17/17 12:47 PM
08/17/17 12:47 PM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
88862586 - GM Engine Oil Supplement, Lucas #10063, Comp Cams #159 etc. Race only, or older high zinc/ZDDP oils work best, but a high zinc additive will suffice. Many flat tappet cams come with assembly lube (like a moly/zinc paste) that you rub into the lobes/coat lifter bases with. Keep your RPM around 2K for the first 10-15 minutes of break in.
Breaking in a cam with those specs is a relatively low risk affair.
Re: oil for camshaft break in [Re: meborder] #4491047
08/17/17 12:56 PM
08/17/17 12:56 PM
NC
BigD1 Offline
BigD1  Offline
NC
Just did the cam break in on my Toyota pickup along with a new cylinder head. I lubed it up real good with Permatex Ultra Slick engine assembly lube. Cam looked really good after 150 miles when I went in to adjust the valves hot.
I used Ford Motorcraft 10W-30 diesel oil available at Walmart in five quart jugs. Would have used the Rotella 10W-30, but they don't stock it. I needed almost five quarts, so buying a gallon jug plus one quart would have been about the same price. PQIA just tested the Motorcraft oil too.
http://pqiadata.org/Ford_Motorcraft__SDF_10W30.html
1992 Toyota Pickup--Castrol GTX 10W-40--ACDelco PF53
Re: oil for camshaft break in [Re: meborder] #4491051
08/17/17 01:03 PM
08/17/17 01:03 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I did a simple cam swap in my Suburban's 350 2 1/2 years and about 4,000? miles ago, and used VWB with Lucas' high-zinc break-in additive. So far the engine purrs like a kitten. Just make sure to get the RPM's up and keep them there (I've heard 2,000 for 20 mins.) ASAP. Probably change the oil after about 500 mi., I'd say stick with a high zinc oil or additive the first time around, then assume your regular OCI and don't be too worried about any extra zinc additive thereafter. I've seen plenty of evidence that with a calm cam it isn't necessary after break-in.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: oil for camshaft break in [Re: meborder] #4491057
08/17/17 01:15 PM
08/17/17 01:15 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
Also, the cam you're using doesn't require a ton of spring pressure. It shouldn't be too much of a break in.
Re: oil for camshaft break in [Re: meborder] #4491078
08/17/17 01:35 PM
08/17/17 01:35 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Originally Posted By: meborder
the cam I've chosen
You should let the cam manufacturer choose the cam. Speaking from experience.
To answer your question: Slather up the cam and lifters with assembly lube and break in with SAE 30.
Re: oil for camshaft break in [Re: NYEngineer] #4491117
08/17/17 02:11 PM
08/17/17 02:11 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
This.
We aren't talking about a Lunatti Voodoo here.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: oil for camshaft break in [Re: OVERKILL] #4491182
08/17/17 03:24 PM
08/17/17 03:24 PM
SD - South Dakota
meborder Offline OP
meborder  Offline OP
SD - South Dakota
the cam I've chosen
I will generously use the cam lube provided. I also bought some from CRC, so I can use either.
As to cam choice, it is a summit branded cam and I did get their input. They couldn't offer a better choice and said that this the one they would have recommended. I didn't go in blind.
I called Howard's and Lunati as well. Howard's recommended one with 204/214 split which I really wanted but it was a lot more money and several more weeks to get it. Lunati recommended a 284/284 from their bracket master line, which sounded like WAY too much cam for a 305 in a truck.
This.
Not quite as aggressive as the voodoo, but probably more aggressive than Lunati's bracket master line. About in line with comp's high energy line of cam, but not as much as their extreme energy. The ramp profiles on this cam are some of the more aggressive ones that summit offers, which is why I chose this one over others. It has more lift than most cams in the low 200's and the single pattern so work well with the 165/140 I/E the heads flow, or at least that was my reasoning.
Re: oil for camshaft break in [Re: meborder] #4491219
08/17/17 04:07 PM
08/17/17 04:07 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I think I would have inquired about a " RV " cam ?
Best of luck , :-)
Wyr
God bless
Re: oil for camshaft break in [Re: meborder] #4491253
08/17/17 04:49 PM
08/17/17 04:49 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
The last 4 engines that I've built or done camshaft swaps on all had really mild cams just like yours. All of them I broke in on Wal-Mart Super Tech 15w40 diesel oil. All of those engines are alive and well with one even being used in an air boat (454). It's reasonably priced and has a nice dose of zinc for break in on a flat tappet camshaft. Good luck with your car swap. Report back how it goes.
Luke
Re: oil for camshaft break in [Re: bioburner] #4491256
08/17/17 04:53 PM
08/17/17 04:53 PM
out there
spasm3 Online content
spasm3  Online Content
out there
Not on a flat tappet engine.
You want a high zinc oil, a light coating of moly paste on the cam lobes, and you want to run it at 2000 minimum with variance rpm for 20 minutes, no idle. There was a article posted that described 2 10 minute breakin periods with a cool down in between, again no idling.
Lower spring pressure should have less risk, but i'd still not take the chance, break it in right.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Page 1 of 3 1 2 3
