One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
39 registered (BigJakeChevy, Black, AVB, bbhero, 2strokeNorthstar, Aero540T, 3 invisible), 987 Guests and 38 Spiders online.
65265 Members
67 Forums
285570 Topics
#4490857 - 08/17/17 09:25 AM IAP IC-106CS Virgin Cut Open
Hootbro Offline
Loc: DELAWARE
A few weeks back, I was stumbling around Ebay looking at filters for my Frontier and came across this IAP IC-106CS filter that was advertised for $1.88 shipped and peaked my interest because shipping would have to be more than the cost of the filter and wanted to see what one could get.
http://www.ebay.com/itm/IAP-Oil-Filter-IC-106CS-for-Honda/112302138156
Arrived out within the week by USPS First Class out of California and below is pictures of the filter before and after being cut open. Observations show it to have a prelubed gasket under the cellophane covering. The bypass valve is of a weird design I have never seen before and is some kind of metallic poppet plate design. Media was tight with about 60 pleats and measure apporx. 250 sq in of media. Center tube was much like a E-Core but with a two piece plastic ring design. Media had a fiber end cap but was resin impregnated and could not be peeled off by hand. ADBV is nitrle and was very supple but also on the thin side.
2018 Jeep Wrangler JL 3.6L (Idemitsu 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
#4490913 - 08/17/17 10:31 AM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
blupupher Offline
Loc: Katy, Republic of Texas
Interesting looking filter. And for under $2, not bad.
Now if we only knew the actual efficiency.
1994 Honda VT1100C: Peak 15w-40/TG/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
#4490932 - 08/17/17 10:49 AM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
AirgunSavant Offline
Loc: MD
Taiwan can make some really high quality machine parts.
I see a few issues here I'm not in love with but I see some things that are impressive too.
Thanks for the great pictures
#4490955 - 08/17/17 11:34 AM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
Brons2 Offline
Loc: Austin, Texas
The endcaps look a lot tougher than the ones on a Fram.
It sort of looks like a cartridge filter though that they just went ahead and built a canister for so they could use the same media for cartridge and spin-on.
2012 Hyundai Sonata GLS 6MT 2.4GDI, M1 5w30, OEM filter, 2007 Kia Rondo LX 2.4 I4 5 pass, M1EP 5w30, OEM filter
#4490968 - 08/17/17 11:51 AM Re: IAP IC-106CS Virgin Cut Open [Re: Brons2]
Hootbro Offline
Loc: DELAWARE
Yeah, the fiber end caps have some stiff resin impregnation. Attempted to see if it pulled off easily and it would not without tearing the attached media off at the base.
#4490990 - 08/17/17 12:12 PM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
901Memphis Offline
Loc: Northern Kentucky
Well it says high efficiency on the box, so you know it's good
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4491037 - 08/17/17 12:46 PM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
ZeeOSix Offline
Loc: PNW
Construction looks decent. Not sure about the bypass valve. Hard to tell how it works by looking at the photos.
#4491102 - 08/17/17 01:54 PM Re: IAP IC-106CS Virgin Cut Open [Re: ZeeOSix]
Kira Offline
Loc: Champlain/Hudson Valley
I went to the website and I have to say:
It's one of a dying breed of foreign released sites where the translation budget wasn't too high.
It's a limited, Asian truck catalog first with a few car items interspersed.
Very few oil filters offered which have automotive applications.
It is always fun to see the names of models which are unavailable here.
Hey, the one oil filter efficiency I saw was stated as being "...as high as 5 micrometers".
#4491124 - 08/17/17 02:18 PM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
Sayjac Offline
Loc: The Old North State
Interesting design. An ecore element as you note, but the pleating looks tight and uniform which is a plus for an ecore. Different type/looking bypass. I'm not going to question how it works. The Champ Labs clicker type bypass looks odd too imo. I like the looks of thread end element adbv sealing area as compared to the Champ design.
How come no ecore trusses visible from the dome end?
Thanks for c&p.
#4491177 - 08/17/17 03:21 PM Re: IAP IC-106CS Virgin Cut Open [Re: Sayjac]
Hootbro Offline
Loc: DELAWARE
Thanks for c&p.
Inner support "trusses" is a two piece affair and was taken out when I took the pic showing the inner pleat spacing.
I drilled out and took apart the bypass valve and it looks like a dimpled plate that fulcrums on a strip of spring steel.
#4491183 - 08/17/17 03:27 PM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
Sayjac Offline
^^Got it. Bypass is unique.
#4491203 - 08/17/17 03:49 PM Re: IAP IC-106CS Virgin Cut Open [Re: Sayjac]
Hootbro Offline
Loc: DELAWARE
#4491227 - 08/17/17 04:14 PM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
ZeeOSix Offline
Loc: PNW
Looks like the black rectangle piece of metal in the bypass valve works as a "beam spring".
The IAP video is pretty hokey.
#4491307 - 08/17/17 05:55 PM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
Onug Offline
Loc: Washington, USA
Having fun with Google Translate...
2016 F-150 3.5L Ecoboost
Current Oil: Mobil 1 5W-30 and Fram Ultra filter
#4491332 - 08/17/17 06:37 PM Re: IAP IC-106CS Virgin Cut Open [Re: Hootbro]
Nyogtha Offline
Loc: San Antonio, TX
Looks like an "adaptation" of Champ Labs Ecore technology coupled with an "adaptation" of Champ Labs "clicker" BPV technology. I don't recall ever seeing an Ecore with clicker bypass produced by Champ Labs. Champ Labs Ecores in applications requiring BPVs have either had combo valves or coil spring design BPVs.
The Champ Labs made AC Delco Classic PF1250 (non-Ecore) is an application that was still using clicker BPV last I looked at one of those.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
