Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
110 registered members (2015_PSD, Anduril, ABCarr, AandPDan, Al, 2004tdigls, 12 invisible), 2,199 guests, and 28 spiders.
Topics287,749
Posts4,933,778
Members67,850
Most Online2,967
Mar 10th, 2019
2006 LBZ Duramax, 5,300mi, Delvac1 CK-4 #4490846
08/17/17 09:09 AM
08/17/17 09:09 AM
Richmond, VA
DNVDMAX Offline OP
DNVDMAX  Offline OP
Richmond, VA
Previous UOA for reference:
HERE
I left the truck tuned as it was before and cleaned the air filter.
Started off with a NAPA Platinum Filter then, after receiving the previous UOA, I installed a Fram HM9100 ($1.50 @ WM) at 981mi into this oil change.
I did not top it off when I changed the filter.
At 5314mi I sampled the oil via the oil filter housing; I removed the filter and let the oil from the center of the housing drip in the sample bottle.
Now the truck has a Fram Ultra installed and I added 1/2 quart to get back to full.
Code:
MI/HR on Oil			5,314			15,592			10,746			21,466			13,893
MI/HR on Unit			148,361			143,047			127,455			106,671			85,205
Sample Date			08/05/17		05/03/17		08/10/14		01/13/14		03/05/12
Oil				Delvac1 ESP CK-4	M1 TDT			Rotella T5 		Rotella T6 5w-40	Rotella T6 5w-40
				5W-40			5W-40			10w-30
Make Up Oil Added		0 qts			0 qts			0 qts			.5 qts (Filter)		0 qts
ALUMINUM			3			4			4			6			6
CHROMIUM			<1			2			<1			<1			1
IRON				23			47			49			24			34
COPPER				1			4			3			4			14
LEAD				<1			4			2			1			0
TIN				3			3			2			2			3
MOLYBDENUM			36			2			3			67			62
NICKEL				<1			4			<1			<1			0
MANGANESE			Not Tested		Not Tested		Not Tested		Not Tested		1
SILVER				<1			<1			<1			<1			0
TITANIUM			<1			<1			<1			<1			0
POTASSIUM			2			<1			<1			<5			7
BORON				76			43			15			23			38
SILICON				7			13			11			6			8
SODIUM				1			8			5			10			4
CALCIUM				1212			1354			2517			860			970
MAGNESIUM			828			990			50			1171			1258
PHOSPHORUS			981			1185			1091			1070			1098
ZINC				1207			1385			1254			1312			1309
BARIUM							<1			<1			<1			0
SUS Viscosity @ 210F		Not Tested		Not Tested		Not Tested		Not Tested		77.3
cSt Viscosity @ 100C		13.3			17.0			12.7			15.0			14.84
Flashpoint in F		Not Tested		Not Tested		Not Tested		Not Tested		420
Fuel %				<1			<1			<1			<1			<0.5
Antifreeze %			No			No			No			No			0.0
Water %				<0.05			<0.05			<0.05			0.07			0.0
Insolubles %			0.6			1.6			0.5			0.3			0.1
TBN				8.8			7.0			6.1			7.2			8.3
06 GMC 2500HD DMAX EFILIVE M1 TDT 5w-40 FRAM Ultra
91 GMC K1500 5.7L 5w-30 Quaker State HM Bosch D+
72 Nova 350 SBC 74mm AirWerks Turbo 15w-40 HDEO
Re: 2006 LBZ Duramax, 5,300mi, Delvac1 CK-4 [Re: DNVDMAX] #4490914
08/17/17 10:31 AM
08/17/17 10:31 AM
Michigan
stockrex Offline
stockrex  Offline
Michigan
"Cleaned the air filter"
K&N ?
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: 2006 LBZ Duramax, 5,300mi, Delvac1 CK-4 [Re: DNVDMAX] #4490946
08/17/17 11:24 AM
08/17/17 11:24 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
The dmax has roller lifters though.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: 2006 LBZ Duramax, 5,300mi, Delvac1 CK-4 [Re: stockrex] #4490975
08/17/17 11:59 AM
08/17/17 11:59 AM
Vienna, Austria
alex_at Offline
alex_at  Offline
Vienna, Austria
K&N ?
I would guess so too.
Silicon value is pretty good in this sample .... so whatever the airfilter is its not doing a bad job.
But if I calculate the numbers of this sample to the milage of Mobil 1 TDT, TDT has done a better job ... and still had a 17 cSt after 15000 miles?
Re: 2006 LBZ Duramax, 5,300mi, Delvac1 CK-4 [Re: DNVDMAX] #4491605
08/18/17 06:29 AM
08/18/17 06:29 AM
Michigan, USA
Bighorn2500 Offline
Bighorn2500  Offline
Michigan, USA
Zinc & Phosphorus PPM look better on the Mobil 1 TDT oil as well.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2015 Jeep Cherokee 3.2L Latitude 4x4
Re: 2006 LBZ Duramax, 5,300mi, Delvac1 CK-4 [Re: stockrex] #4491661
08/18/17 07:54 AM
08/18/17 07:54 AM
Richmond, VA
DNVDMAX Offline OP
DNVDMAX  Offline OP
Richmond, VA
K&N ?
It's a 10 year old AFE ProGuard 7-Layer.
The TDT from the previous fill was CJ-4
Re: 2006 LBZ Duramax, 5,300mi, Delvac1 CK-4 [Re: DNVDMAX] #4494364
08/21/17 11:03 AM
08/21/17 11:03 AM
Indiana
njohnson Online content
njohnson  Online Content
Indiana
Delvac 1 ESP 5W-40 has moly in it now? This is new for the CK-4 formula? On the older UOAs of Delvac 1, there wasn't any moly to speak of, right?
Re: 2006 LBZ Duramax, 5,300mi, Delvac1 CK-4 [Re: DNVDMAX] #4543404
10/14/17 05:39 PM
10/14/17 05:39 PM
Vermont
Toptierpao Offline
Toptierpao  Offline
Vermont
Are those Iron numbers typical for a Duramax motor?
