Omnia - the band
by Shannow
06/23/18 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
06/22/18 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
06/22/18 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
06/22/18 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Another thick/thin article to discuss
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
06/22/18 06:32 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
12 registered (GMguy84, dlundblad, bbhero, huh, FT92, Jaha24k, 1 invisible), 793 Guests and 33 Spiders online.
65299 Members
67 Forums
285816 Topics
Page 1 of 2 1 2 >
#4490790 - 08/17/17 07:53 AM Used Cars with Replaced Engines
ET16 Offline
Loc: MD
I'm going the look at a used car (2005 MPV van) today with a replaced engine. I don't think that I've ever looked at a car with a replaced engine. Besides the obvious, what should I look out for?
#4490795 - 08/17/17 08:06 AM Re: Used Cars with Replaced Engines [Re: ET16]
glock19 Offline
Loc: Virginia
I would want proof that the engine swap was done by a reputable shop. If the seller told me he did it himself in his garage, I would pass.
2017 GMC Sierra SLT Z71 Crew Cab - His
2016 Toyota Highlander Limited - Hers
#4490798 - 08/17/17 08:11 AM Re: Used Cars with Replaced Engines [Re: ET16]
MarkM66 Offline
Loc: stl
I would be concerned with who did the work. It's easy to mess things up when doing something like and engine swap; mess up a plug connector, break or crimp a wire, break a sensor, etc.
#4490801 - 08/17/17 08:18 AM Re: Used Cars with Replaced Engines [Re: ET16]
Vladiator Offline
Loc: NC
Just make sure the engine runs right, make sure the CEL lights up upon start and turns off, and make sure there are no leaks around the engine and between engine and transmission. Also check the oil cap for sludge buildup. If the cap has sludge - the rest of the engine does too, and usually a lot worse than the cap.
I've replaced a few engines in my friend's shop (he has a lift, duh) and every time the engine had less miles than the car. For example - last car was Lexus IS300 with 134k that I put an engine in with 100k miles. Did I have the paperwork to prove anything? No. Did I tell the new owner about the "new" engine when I sold the car at 170k miles? No. The car is still driving out there. Last time I checked - it was at 220k.
Thicker oils give protection for severe operations such as driving in mountains, pulling a boat, dusty conditions, short trips, high rpm, overloading, overheating and overcooling. Thin oils give MPG.
#4490804 - 08/17/17 08:26 AM Re: Used Cars with Replaced Engines [Re: ET16]
jeepman3071 Offline
Loc: Storrs, Connecticut
Was it replaced with a new/rebuilt engine or a junkyard engine with unknown history?
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
#4490815 - 08/17/17 08:37 AM Re: Used Cars with Replaced Engines [Re: ET16]
bioburner Offline
Loc: Minnesota
I did a motor swap on the Ford Transit, mated it to a totally rebuilt tranny with papers now in the glove box. Original engine had 180k. The donor was a engine with under 40k. 6 months no issues but was a Ford trained mechanic that I assisted for better or worse.
Basically look at the paper trail if the work was done by reputable shop and replacement was checked out.
Saved me big $$$ and have a very nice drivable vehicle that with proper care will last easily another 180k without issues.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4490816 - 08/17/17 08:37 AM Re: Used Cars with Replaced Engines [Re: ET16]
Donald Offline
Loc: Upstate NY
It could be a plus is a reman engine or a negative if a junkyard engine that the PO did himself.
Some vehicles like my 2001 Jeep GC 4.0 are likely to need an engine by 100,000 miles due to piston skirt cracking.
2015 Ford F250 w/Powerstroke
#4490823 - 08/17/17 08:44 AM Re: Used Cars with Replaced Engines [Re: ET16]
BigD1 Offline
Loc: NC
Find out if it has a remanufactured, rebuilt, crate, or used engine. If it has a reman with paperwork, I would definitely consider it. I bought my Oldsmobile with a low mileage Jasper reman, and it has been a good engine so far.
http://accurateengines.com/difference-between-rebuilt-remanufactured-crate-engines/
1992 Toyota Pickup--Havoline HM 10W-30--Motorcraft FL-910S
#4490832 - 08/17/17 08:54 AM Re: Used Cars with Replaced Engines [Re: jeepman3071]
Vladiator Offline
Loc: NC
Newly rebuilt - $2000-$3000. Used from a junkyard, that is sparkling clean under valve cover - $600. I think the choice is obvious here. Plus the junkyard engines comes with all the sensors and most of accessories & wiring- which means less labor in swapping that over from the old engine.
#4490852 - 08/17/17 09:19 AM Re: Used Cars with Replaced Engines [Re: ET16]
zzyzzx Offline
Loc: Baltimore, Maryland, USA
I had a Jasper engine put in my 1995 Escort in 2001. I'm still driving the car too. In this particular case it's a big plus since the Jasper won't drop a valve seat.
#4490859 - 08/17/17 09:28 AM Re: Used Cars with Replaced Engines [Re: ET16]
madRiver Offline
Loc: New England
A replaced engine adds no value to a vehicle despite what the poor sap who paid for it thinks. So make sure you pay for mileage on odometer not that 30k engine.
2005 is good because if sensor or item not correctly installed the Check engine is on. Make sure it illuminates when in on position but motor not running.
My Subaru had major engine work due to valve burning requiring engine removal. Not a single issue but mechanic is Subie expert. He said it started first attempt no lights after the install.
#4490861 - 08/17/17 09:31 AM Re: Used Cars with Replaced Engines [Re: ET16]
Ethan1 Offline
Loc: 'murica
If the car runs right and there's no check engine light, what is there to worry about? What could you mess up during an engine swap that would not cause a no-start, a driveability issue, or a CEL?
#4490866 - 08/17/17 09:33 AM Re: Used Cars with Replaced Engines [Re: Vladiator]
jeepman3071 Offline
The answer is obvious - if I was to swap an engine for myself.
Buying a car with a swapped engine I would prefer the one with paperwork and a warranty over the one some guy swapped in his garage. I trust my own work not other people's work.
#4490871 - 08/17/17 09:42 AM Re: Used Cars with Replaced Engines [Re: Ethan1]
glock19 Offline
Loc: Virginia
Re-using old parts that should be changed like gaskets or belts.
#4490880 - 08/17/17 09:48 AM Re: Used Cars with Replaced Engines [Re: zzyzzx]
tig1 Offline
Loc: Illinois
I(myself and Dad) put a Jasper 6 cyl engine in a 66 Chevy in 1972. It performed very well.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Page 1 of 2 1 2 >
