My Ford orange turned pink
by BeerCan
06/21/18 12:45 PM
Any plants/garden experts?
by maverickfhs
06/21/18 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
06/21/18 12:23 PM
Brake fluid for a '03 Volvo S60
by earthworm
06/21/18 11:22 AM
Oil Weight Change - Mid Production Cycle
by PolarisX
06/21/18 11:20 AM
Kia ATF - OEM, Eneos, Maxlife - TDS - DIFFERENT!
by Spddm0n
06/21/18 11:19 AM
Dillon Precision Is Simply The Best!
by 2015_PSD
06/21/18 11:17 AM
First OCI - 156k miles Prius
by Greg L
06/21/18 11:11 AM
Brake Squeal on Rear Discs
by BlitzPuppet
06/21/18 11:10 AM
Coolant leak.
by LeakySeals
06/21/18 11:05 AM
Looking for a Home Depot coupon 10% off?
by GravelRoad
06/21/18 10:59 AM
Which is more important for low wear HTHS or ZDDP?
by Building3
06/21/18 10:40 AM
Valvoline DuraBlend 80W-90
by dogememe
06/21/18 10:34 AM
Lifter Tick
by Delta
06/21/18 10:28 AM
I Got Locked Up Today
by Zee09
06/21/18 10:24 AM
GM new 2.7 turbo pick up motor
by ZZman
06/21/18 09:45 AM
PUP at Canadian Tire $33 CAN
by Snagglefoot
06/21/18 09:15 AM
How to use up a case of SF?
by atikovi
06/21/18 09:08 AM
Read The Fine Print- Credit Cards
by Zee09
06/21/18 09:06 AM
Employer Exit Interview.
by JustinH
06/21/18 08:53 AM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
104 registered (aquariuscsm, badtlc, atikovi, ammolab, 14Accent, 13 invisible), 1576 Guests and 58 Spiders online.
65286 Members
67 Forums
285710 Topics
Page 1 of 2 1 2 >
#4490557 - 08/16/17 08:53 PM 507.00 or 505.01 VW ?
LloydT Offline
Loc: Iowa
Help needed. Is the new VW oil 504.00 507.00 required in my 2015 Passat 2.0L TDI able to be used in my 2005 Passat TDI 2.0 L BHW camshaft driven injectors? I have used only VW 505.01 in my 2005 Passat BHW. I think they are different requirements. Different oil. Thanks for you help.
2005 Passat TDI 2.0L BHW
2015 Passat TDI 2.0L
Lloyd T
#4490630 - 08/16/17 10:45 PM Re: 507.00 or 505.01 VW ? [Re: LloydT]
2004tdigls Offline
Loc: maple ridge, bc
this should help, in short 507 oils superceed 505.01 oils
http://forums.tdiclub.com/showthread.php?t=158788
this being said many of us tdi owners don't follow VW's oil recommendations because the PD engines eat their cams at an alarming rate using "VW recommended oil". ( i am not trying to start an oil war)
I have been using a qualtiy DINO 15w40 (CJ) and i have over 200k on my original cam, many of my friends on the tdi club had their cams die in the 80 k range (or even lower). My OCI is 6 months or 5000 miles.
http://forums.tdiclub.com/showthread.php?t=237678
#4490658 - 08/17/17 12:05 AM Re: 507.00 or 505.01 VW ? [Re: LloydT]
edyvw Offline
Loc: Colorado Springs
Lloyd T
Use VW 505.01 in PD TDI.
You have several options, but most handy is Valvoline 5W40 MST in NAPA> Sometimes they have it on sale for $3.99 a quart. I use it in BMW in summer months.
13' BMW X5 35d (Mobil1 5W30 ESP+OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
#4490671 - 08/17/17 12:51 AM Re: 507.00 or 505.01 VW ? [Re: LloydT]
FowVay Offline
Loc: Southeastern USA
I wouldn't use a 5W-30 of any rating in a PD TDI. The VW 507.00 is an excellent oil for it's intended application but knowing the problems that the PD engines have I would use only a 5W-40 product.
As edyvw mentioned, the Valvoline that is available at every NAPA store would be a good option. I would be far more inclined to use the 505.01 in the common rail TDI than to use the 507.00 in the pumpe-düse.
Quaker State across the board.
#4490683 - 08/17/17 02:20 AM Re: 507.00 or 505.01 VW ? [Re: LloydT]
zeng Offline
Loc: Malaysia
Lloyd T
VW 507.00 or 505.01 are both recommended by VW for PD engines.
You could possibly rationalise VW 507.00 for both cars, price aside.
#4490687 - 08/17/17 02:35 AM Re: 507.00 or 505.01 VW ? [Re: LloydT]
Kamele0N Offline
Loc: Slovenia
They are both for PD engine...
505.01 is FULL saps version
507 is LOW saps version (for DPF catalyst)
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4490708 - 08/17/17 05:17 AM Re: 507.00 or 505.01 VW ? [Re: Kamele0N]
weasley Offline
Loc: UK
505 01 has a maximum sulfated ash limit of 0.8%.
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D5
2011 KTM 990 SMT
#4490732 - 08/17/17 06:17 AM Re: 507.00 or 505.01 VW ? [Re: LloydT]
LoneRanger Offline
Loc: Midwest USA
Got Good results in the late wife's 2005 Beetle TDi (1.9L) with the Pumpe Duese engine (camshaft driven unit injectors like your 2005 Passat), with Rotella T6 5W40. It's all about the oil having an HTHS value > 3.5 for that engine.
'09 Subaru Forester ...................(QSED DEXOS1 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
#4490742 - 08/17/17 06:32 AM Re: 507.00 or 505.01 VW ? [Re: weasley]
zeng Offline
Loc: Malaysia
+1
...and it usually associates with ACEA C3.
#4490757 - 08/17/17 06:59 AM Re: 507.00 or 505.01 VW ? [Re: LloydT]
scurvy Offline
Loc: Chicago IL USA
History (and UOA) has shown that CJ-4 oils protect as good or better in PDs than any VW-spec oil. Mobil 1 Turbo Diesel Truck, Shell Rotella T6, Schaeffer 9000 or Amsoil DEO are all fairly easy to get and protect well.
The CR engines got full roller valvetrains so the mega-HTHS, high moly, high ZDDP oils aren't needed.
The 2015 needs 507.00 for DPF protection; the 2005 needs CJ-4 for camshaft protection.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#4490929 - 08/17/17 10:48 AM Re: 507.00 or 505.01 VW ? [Re: LloydT]
LoneRanger Offline
Loc: Midwest USA
s'up scurvy. I used to be SootFoot over on Fred's.
#4491075 - 08/17/17 01:30 PM Re: 507.00 or 505.01 VW ? [Re: Kamele0N]
edyvw Offline
Nope.
VW 502.00=Full SAPS
VW505.01=Mid-SAPS
VW504/507=Low SAPS
#4491567 - 08/18/17 03:58 AM Re: 507.00 or 505.01 VW ? [Re: edyvw]
weasley Offline
Loc: UK
Nope.
VW 502.00=Full SAPS
VW505.01=Mid-SAPS
VW504/507=Low SAPS
Not quite.
502 00 is full SAPS (1.5% max)
505 01 is mid SAPS (0.8% max)
504 00/507 00 is a bit odd. The VW spec document says 1.5% max ash (so full SAPS). BUT, it also says that the oil must meet ACEA C3, which is 0.8% max ash, so mid SAPS. The outcome is that 504 00/507 00 = mid SAPS.
AFAIK there is no low SAPS VW spec (<0.5% ash).
2018 Volvo XC60 D5
2011 KTM 990 SMT
#4492416 - 08/18/17 11:27 PM Re: 507.00 or 505.01 VW ? [Re: weasley]
edyvw Offline
Nope.
VW 502.00=Full SAPS
VW505.01=Mid-SAPS
VW504/507=Low SAPS
Not quite.
Well, VW 504.00/507.00 is all ready old spec. if we will keep a track. it was considered low SAPS since to meet other parameters of VW504.00/507.00 oils could not have high levels of SAPS, hence most have around 0.6-0.7.
I know that spec. allows actually very high SAPS levels, but no oil has it since other parameters would not be achieved.
#4493143 - 08/19/17 07:19 PM Re: 507.00 or 505.01 VW ? [Re: LloydT]
Tornado Red Offline
Loc: Saint Paul (ex-San Diego)
Yes, different engines so different oils.
For the common-rail 2015 Passat TDI, stick to the VAG 504/507 spec oils.
For the 2005 pumpe duse (PD) Passat TDI, the best oil is probably a 5w40 meeting the API CJ-4 or new CK-4 specification.
But if you want a single oil for both engines, then you should probably use the VAG 504/507 spec oil.
'03 Golf TDI, 704k miles: Bosio DLC764, GT1749VB, Malone Tuning, G60/VR6, Bilstein HD, Recaros, Akebonos, Brembos, Pirellis, DG Panzer, Delvac 1 ESM 5W40
Page 1 of 2 1 2 >
