Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
109 registered members (AndyB, ad244, 28oz, 97K15004WD, 64bawagon, 53' Stude, 15 invisible), 1,865 guests, and 38 spiders.
Topics294,990
Posts4,925,558
Members66,660
Most Online2,553
Oct 27th, 2018
Fram Ultra Baseplate Holes #4490398
08/16/17 05:00 PM
08/16/17 05:00 PM
MD
AirgunSavant Offline OP
MD
I had two new Ultras, 3614 and 7317 and the TG versions.
The Ultra is my favorite period but the baseplate holes are really getting sharp. Won't know about inside until I run them. But I hope they don't go the Purolator route.
Re: Fram Ultra Baseplate Holes [Re: AirgunSavant] #4490434
08/16/17 05:44 PM
08/16/17 05:44 PM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
Every Ultra I have cut open had smooth edges on the inside and rough on the outside because that is the direction they are punched.
Re: Fram Ultra Baseplate Holes [Re: 2015_PSD] #4490440
08/16/17 05:50 PM
08/16/17 05:50 PM
MD
MD
Understood let's hope so. But when the Chinese deburr both sides I think Fram should too.
Re: Fram Ultra Baseplate Holes [Re: AirgunSavant] #4490457
08/16/17 06:02 PM
08/16/17 06:02 PM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
I think they grind the inside too. Have a look at the FRAM's that Car51 just posted.
Re: Fram Ultra Baseplate Holes [Re: 2015_PSD] #4492299
08/18/17 07:53 PM
08/18/17 07:53 PM
Louisiana
OLEJOE Offline
OLEJOE  Offline
Louisiana
I cut a Wix 51064 open that the ADBV was leaking down on and the holes in the base plate had burrs around the holes on the inside. I'm going to use the Ultra for now. Installed an Ultra on my tractor which has a horizontal orientation and it is working great. After sitting for a week, the oil light goes out before it cranks. And it starts instantly. I'm sold.
Jack of All Trades. Master of some.
Re: Fram Ultra Baseplate Holes [Re: 2015_PSD] #4492399
08/18/17 10:05 PM
08/18/17 10:05 PM
So. Cal.
kohnen Offline
kohnen  Offline
So. Cal.
That's BRILLIANT engineering! The holes are smooth at the ADBV where it counts. Burrs on the outside just don't matter. When the filter is installed on an engine, they won't hurt anything. And, if any pieces of metal get loose (unlikely) they just get sucked in to the filter and captured there.
2017 Chevy Bolt
2015 Chevy Volt
Re: Fram Ultra Baseplate Holes [Re: AirgunSavant] #4493930
08/20/17 06:14 PM
08/20/17 06:14 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
I use 7317 on my dirt bike at the bottom of the frame neck reservoir. ADBV performance is critical here, because if the frame neck drains out, the engine will take about 15 seconds to build oil pressure from zero. If the frame air locks, it may not make pressure at all.
Have had zero issues with either TG or XG 7317. Moment I jump on the kick starter, the engine catches , and the oil light is gone.
