Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
18 registered (hpb, dervdave, Falcon_LS, Deltona_Dave, car51, CleverUserName, 1 invisible), 764 Guests and 40 Spiders online.
65265 Members
67 Forums
285574 Topics
#4490261 - 08/16/17 03:15 PM Air out of dash and feet only
dlundblad Offline
Loc: Indiana
On my Chevy blazer.
It looks like it's all vacuum actuated. I believe it may be the AC/ heater control switch. Even with the dial turned to off, a bit of air still comes in at the feet when the vehicle is cruising at highway speeds. I just need to take the trim on the dash out so I can get to it. The lines are small so checking it may be difficult.
Rock Auto has the part for $140 shipped. Anyone have any cheaper alternatives? There's always junkyards, but how do I know the one I pull isn't faulty either?
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4490264 - 08/16/17 03:19 PM Re: Air out of dash and feet only [Re: dlundblad]
JMJNet Offline
Loc: TX, USA
Sometimes it is the motor.
The gear inside is cracked.
  • 2017 Toyota Sienna
#4490266 - 08/16/17 03:21 PM Re: Air out of dash and feet only [Re: dlundblad]
Padawan Offline
Loc: NJ
Does this happen even when the system is set to recirculate? Did it only recently start?
All of our vehicles in recent memory have allowed some air in through the vents at speed unless set to recirculate.
#4490271 - 08/16/17 03:28 PM Re: Air out of dash and feet only [Re: Padawan]
dlundblad Offline
Loc: Indiana
No re circulation.
#4490272 - 08/16/17 03:29 PM Re: Air out of dash and feet only [Re: JMJNet]
dlundblad Offline
Loc: Indiana
Pardon my ignorance, but what motor? smile
#4490273 - 08/16/17 03:29 PM Re: Air out of dash and feet only [Re: dlundblad]
John_VT Offline
Loc: Vermont
Won't go to defrost? I've had the rod pop off on my suburban.
14 crosstrek 5 spd.Milesyn sxr 0-20
98 k1500 suburban 5.7L.Milesyn sb 5-30
03 Pontiac Montana. St 5-30
01 mojave,86 trx350,2-110cc atv's
#4490274 - 08/16/17 03:31 PM Re: Air out of dash and feet only [Re: John_VT]
dlundblad Offline
Loc: Indiana
I said dash, but I should have said defrost.
From what I've read, going to defrost and feet is a safety feature so you can still drive (and see) when whatever vacuum component fails.
#4490376 - 08/16/17 05:37 PM Re: Air out of dash and feet only [Re: dlundblad]
mk378 Offline
Loc: USA
It is almost certainly electric. By 1997 vacuum controls were obsolete.
If you turn the key on and don't start (so there's no engine noise) and push buttons on the control panel, do you hear gears grinding?
#4490441 - 08/16/17 06:50 PM Re: Air out of dash and feet only [Re: dlundblad]
NHGUY Offline
Loc: USA
Google "Mode door actuator".
#4490496 - 08/16/17 07:55 PM Re: Air out of dash and feet only [Re: dlundblad]
Warstud Offline
Loc: MIchigan
That's normal for GM vehicles.
#4490515 - 08/16/17 08:09 PM Re: Air out of dash and feet only [Re: Warstud]
dishdude Offline
Loc: Phoenix
Yes. Off on these vehicles defaults to floor and fresh air allowing air to flow through the system without the fan to prevent the air in the vehicle from getting stale.
2018 Challenger SRT
#4490580 - 08/16/17 09:17 PM Re: Air out of dash and feet only [Re: dlundblad]
clinebarger Offline
Loc: Fort Worth, Texas
The lower Mode Door has "Minimum Flow Holes" that allows air flow from the outside with the system off, The Temperature Blend Door will still regulate the air temp.
All Air Mode doors are Vacuum operated.
The Temperature Blend Door is control by a electric actuator.
If you lose Mode functions.....Check the Vacuum line from the engine to the Vacuum Storage Canister, Check Valve, And the Vacuum line between the canister & firewall. The rubber lines under the hood will rot right off these trucks.
The interior vacuum harness is very reliable as are the mode actuators & switching valve.
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
#4490597 - 08/16/17 09:48 PM Re: Air out of dash and feet only [Re: mk378]
clinebarger Offline
It really depends on what vehicle your reffering to....
My 2001 Camaro is Vacuum controlled Mode Doors, And Cable controlled Temp Door....Probably the most reliable HVAC control set-up.
A lot of the Subcompact cars still use cables to control all the door functions besides the Recirculation Door which is a simple Bi-Directional electric motor.
The OP's Blazer has Vacuum controlled Mode Doors, And Electronic Step Motor controlled Temp Door.
The 100% Electronic Step Motor controlled systems are the most common today & in my opinion is the least reliable control system.....But folks got to have their fully automatic dual zone temp control!!
#4491187 - 08/17/17 03:33 PM Re: Air out of dash and feet only [Re: clinebarger]
dlundblad Offline
Loc: Indiana
Good to know the interior harnesses are very reliable. Looks very tedious to work on.
The check valve is another possibility. I'll recheck my hoses, but I replaced them hoping they were the problem.
#4491193 - 08/17/17 03:40 PM Re: Air out of dash and feet only [Re: clinebarger]
Silverado12 Offline
Loc: Central Virginia
Totally agree. I've replaced a blend door on my 2010 Mustang. Not only is it a PITA but one would think they should last longer than they do.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
16 Challenger R/T Shaker 5.7 manual B5 blue
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
