64801 Members
68 Forums
282040 Topics
#4489759 - 08/15/17 10:08 PM
1987 22RET SF/CC 10W-40 oil recomendations...
Loc: Monterey, Ca
Hi, I have a 1987 (Toyota truck) with a 22RET/ RTE (factory turbo) that calls for SF/CC 10W-40 oil. I had a cam shaft failure, while running Castrol Syntec synthetic oil recently (in 2001). I think it was 5W-50. I was changing the oil and filter every ~3,000 miles. The last time I blew the turbo, the rebuilder recommended I use a 5W-40 oil...
What are my best choices (cost less than $25 per gallon): ---- The temperature here is between -10 and 110F (normally its 30-90F). ---- This engine has overhead cam, that the rocker arms ride (slide) directly on the camshaft.
My last OC was with Eneos 5W-40 Synthetic oil. Often I use whatever synthetic oil is on sale.
MRY
Lifetime Gearhead
#4489794 - 08/15/17 11:14 PM
Re: 1987 22RET SF/CC 10W-40 oil recomendations...
[Re: MRYGearHead]
Loc: Fort Worth TX
I used to live not too far from you and I dont think I ever seen it get to -10
I would say m1 tdt 5w40 would be a good fit.
2011 Prius 96k miles RLI 5w20 97 Toy T100 4x4: amsoil 0w20 242k Miles 04 Toy Sienna awd: Pennzoil 0w20 281k Miles
#4489842 - 08/16/17 01:29 AM
[Re: MRYGearHead]
Loc: Malaysia
High ZDDP dual rated HDEO xW40 in CI4/CJ4, avoid SN/SM PCMO.
Edited by zeng (08/16/17 01:30 AM)
#4489843 - 08/16/17 01:52 AM
[Re: MRYGearHead]
Loc: Balearic Islands , Spain
I doubt the viscosity had anything to do with the cam failure, i would run as someone else mentioned M1 5W-40 TDT or Shell Rotella T6 5W-40. Even a 15W-40 Conventional HDEO would do like Rotella, Delo 400. If that engine is a flat tappet camshaft engine, then it might have been a low ZDDP oil that wiped it out, any of these oils i have mentioned have fairly high concentrations of Zddp.
1975 Ford Capri II Ghia 3000 V6 1988 Ford Escort 1.6 Xr3i Convertible Finnish expat living in Spain My clothes smell like 15W-40 HDEO and 20W-50.
#4489851 - 08/16/17 02:21 AM
[Re: MRYGearHead]
Loc: Central Washington
Agree with the diesel oil recommendations.. 15W40 would do fine in this engine. But one of the 5W40 diesel oils would work great as well if you prefer synthetic.
Edited by Colt45ws (08/16/17 02:21 AM)
-Colton 2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42 Down for engine swap 2003 Ford Crown Vic PI 75k Castrol EDGE HM 5W30, Fram XG2
#4489890 - 08/16/17 06:04 AM
[Re: MRYGearHead]
Loc: PENNSYLVANIA
I believe Valvoline MC oil meets SF/SG spec and it can be had for $3 per quart.
Comes in 10w40 and 20w50 flavors
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 | TG8A | 2.5" lift | 148k miles
Software Engineer :]
#4489898 - 08/16/17 06:30 AM
[Re: MRYGearHead]
Loc: Crawfordville FL
MRY Rotella t4,5,6 can be had cheaply at Walmart and is designed around diesel turbo applications
2010 Ford Fusion SE 3.0L V6, 175k miles M1 AFE 0w-20
#4489903 - 08/16/17 06:41 AM
[Re: MRYGearHead]
Loc: Jacksonville, FL
MRY As the owner of several 22RE powered trucks I'm jealous of your factory turbo truck. I've always wanted one. I've never had a camshaft failure in a 22RE Toyota, ever, with a cumulative mileage between all the ones I currently own and have owned in the past of over 1.5 million miles. However when working in a machine shop I did see a few failures of aftermarket camshafts that were improperly heat treated. My current daily driver is an 87 4Runner, I removed the original camshaft at 277,000 miles and installed an RV cam that's been in the truck ever since. I'm now at 330,600 miles with no issues. I haven't run anything fancy for oils on the original or replacement camshaft. For your application and relatively mild overall temperatures I would run a 15w40 diesel oil or a 0/5w40 synthetic diesel oil if you're concerned about getting closer to the original API addative levels. Hard to go wrong with either one.
Luke P-3C and P-8A Maritime Weapons and Tactics Instructor, Instructor Tactical Coordinator and Mission Commander
#4489909 - 08/16/17 06:56 AM
[Re: MRYGearHead]
Loc: Olathe, KS
I had an 86 Turbo. Still miss that truck. I ran Rotella 5w-40 in mine and it seemed to do fine.
04 Toyota 4Runner | M1-209A & Mobil 1 0w-40 12 VW Passat | VW OF & 5w40 Castrol Professional 97 Honda Civic HX | Fram Ultra & Red Line 5w-30
#4491336 - 08/17/17 06:44 PM
[Re: MRYGearHead]
Loc: Monterey, Ca
Hi everyone. Thanks for the input. I'm not up with the abbreviations of the oil types. There no walmart near me. What about, Lucas Long Drain Truck Oil 10297? https://lucasoil.com/pdf/Zinc_Values_MotorcycleOil.pdfI think the Rotella will be what I'll use. The temperature spread is based in where else I might go. It does get down to 10 to 20F on occasions here. The turbo re-manufacture felt that 10W or 15W was too thick for a turbo. Nice Toyota Carj
Edited by MRYGearHead (08/17/17 06:47 PM)
Lifetime Gearhead
#4491417 - 08/17/17 08:26 PM
[Re: MRYGearHead]
So run a 5w40 HDEO
#4526297 - 09/25/17 11:27 PM
[Re: CARJ]
Loc: Monterey, Ca
Hi Carj,
Nice Toy. And I see your an HAM too, me too...
Bruce
Lifetime Gearhead
