I have a vehicle which isn't used much (just a spare for the last couple years), an '02 Mazda Tribute LX 4x4, 3.0L Duratec 24V V6 w/ approx 190k miles.
Lately the oil light has come on and won't go off. This didn't happen suddenly, actually it first appeared about a year ago where I'd get intermittent blips from it at idle. I take an oil light pretty seriously, pulled right over, oil level good. It would come on more and more, but it was pretty freakish and random-- on a 100 degree day in traffic with A/C on, no oil light. The next morning it'd be 65F, no A/C and the light would come on at idle. In all instances of this light coming on, the oil level was good and has never been run low. It is a semi-oil burner, it'll take two or three quarts in a 5-6k interval. The pan seeps some, but the oil isn't dripping and leaving large puddles by any means; more than likely it's getting burned in the engine.
The light has me puzzled, as the engine seems normal in every respect. Has decent power and mileage (it's always had [censored] mileage, 19-20mpg, so that's nothing new) for its age, and isn't ticking, knocking or making any funny noises. Pull the oil cap while running, and I'm looking right at a spinning timing chain that is getting a [censored] nice oil shower from under the valve cover, no pressure issues there!
Before I go get a mechanical gauge, are these engines known for low oil pressure as they age and/or faulty pressure senders? The oil light is on for good now, it doesn't go off under any condition, even when started first thing in the morning with fresh oil after a change. If I do get a mechanical gauge, can anyone point me in the direction as to how to hook it up?
This currect OCI I'm using Harvest King (citgo) 5w-30 with a cheap $2.99 Rural King oil filter. This oil light issues (aside from it being on constantly) has arisen through more than one oil change, so I don't it's correlated to a certain oil or filter, but I could be wrong. I don't recall trying anything heavier than 30 weight, this engine has generally gotten top tier (Mobil, Castrol, PP, etc.) 5w-20 synthetic since we purhased it at 160k. Maybe 5w-30 synthetic a time or two. I bought Harvest King 5w-30 conventional this time, as it's cheap and I'm troubleshooting this oil light issue.
Curious to see what you guys think and any input would certainly be appreciated.
