Replaced halogen headlight with LED
by gman2304
30 minutes 2 seconds ago
Web Archive
by Duffyjr
Today at 10:25 AM
Sonoma This weekend!
by racin4ds
Today at 10:22 AM
low water pressure on new kitchen faucet
by Joe1
Today at 09:40 AM
Flashing third tail light
by Brigadier
Today at 08:59 AM
Intermittent AC Cooling
by Gebo
Today at 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
Today at 08:45 AM
Crude and foul behavior
by mjoekingz28
Today at 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
Today at 08:30 AM
Wrecking Yards
by Snagglefoot
Today at 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
Today at 08:14 AM
AAP 25% Off
by Egg_Head
Today at 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
Today at 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
Today at 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
Today at 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
Yesterday at 10:41 PM
Chevy brought the blazer back
by WiskyBadger
Yesterday at 10:07 PM
LC20 and uses in modern motor oil
by synman
Yesterday at 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
Yesterday at 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
Yesterday at 08:37 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
73 registered (4WD, 2012AccentSE, Billbert, bdcardinal, asiancivicmaniac, 4 invisible), 1459 Guests and 36 Spiders online.
65294 Members
67 Forums
285764 Topics
Page 1 of 2 1 2 >
#4489192 - 08/15/17 11:37 AM 2012 Lexus LS460 Shift Flare when cold
planeman223 Offline
Loc: Charlotte
Good day BITOGers,
My Lexus LS460 with an 8 speed Aisin AA80E transmission with 102,000 miles has a habit of flaring from 2nd to 3rd when the engine has just been started after sitting overnight. The flare is very small (300-500rpm) and it's very smooth. (There is no jerking, slamming into gear etc) Once it's warm it operates normally and I do not observe any slip/flare. The transmission has been serviced (drain and fill completed by Lexus dealer at 82,000 and 98,000 miles) using Toyota World Star fluid.
The strange thing is... When I manually shift through the gears there is no slip/flare at all even when stone cold. ClubLexus has a lengthy thread of over 15 members observing this behavior of all mileages.
What would you guys/gals do in my situation? Thank you for your advice.
#4489200 - 08/15/17 11:56 AM Re: 2012 Lexus LS460 Shift Flare when cold [Re: planeman223]
incognito_2u Offline
Loc: Long Island, N.Y.
How's the fluid level?
2006 Jeep Commander 3.7 V6 -108k (PUP/XG3600)
2006 Toyota Corolla 1.8 VVTi -76k (PPHM/XG3600)
1999 Toyota Corolla 1.8 -77k (PUP/XG4386)
#4489210 - 08/15/17 12:05 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: incognito_2u]
planeman223 Offline
Loc: Charlotte
Within factory specification.
#4489253 - 08/15/17 12:59 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: planeman223]
bigt61 Offline
Loc: Virginia
If it's a common problem, all you can do is drive it easy until it's warm. Maybe, in time, Lexus will offer to fix it. But there will have to be a few total failures for it to get on their radar.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4489254 - 08/15/17 01:01 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: planeman223]
lexus114 Offline
Loc: Easton, PA
was the fluid ever changed?
2017 Mercedes-Benz C300 4matic coupe 2.0 turbo
2016 Lexus RX 350 Autumn Shimmer AWD
#4489267 - 08/15/17 01:14 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: planeman223]
The Critic Offline
Loc: CA
The fluid level is probably wrong since the trans shifts fine once warmed up. The fluid level rises once warmed up.
It is difficult to get the fluid level correct- it takes a lot of time and the trans must be cool unless they use the new SST (not sure if that one even works on the 8spd). If you only brought the car in for a drain and refill, the car was probably not in there long enough for the fluid to cool down to <100f - so the fluid level may have been estimated.
2011 Toyota Prius - 168k - ServicePro Dexos 0W-20
2007 Honda Accord 2.4 - 128K - Idemitsu 5W-20
#4489385 - 08/15/17 02:58 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: The Critic]
This ^^
My Jeep has the NAG1......also very difficult to get the level right even after a change.
Had the same symptoms as you.
It also took me a while to adjust it to the best level
Edited by incognito_2u (08/15/17 03:00 PM)
#4489387 - 08/15/17 03:00 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: incognito_2u]
SatinSilver Offline
Loc: OH
Here's a 35 minute video on how to check the ATF level from a college instructor:
https://www.youtube.com/watch?v=cNcecuGzTDg
#4489470 - 08/15/17 04:34 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: planeman223]
planeman223 Offline
Loc: Charlotte
Thank you all for your kind replies and advice. I will have the level checked next week while it's in service. My last question concerning this behavior is why would I be able to manually shift with no slip? Wouldn't it slip then also? It doesn't.
#4489572 - 08/15/17 06:32 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: planeman223]
SilverFusion2010 Offline
Loc: Crawfordville FL
When you say manually shift... You're using a sport mode right? My theory is the transmission is programmed for higher shift pressure when in sport mode. This would make sense for sporty/aggressive driving. You don't want slip when under heavy acceleration.
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
#4489625 - 08/15/17 07:24 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: planeman223]
Eddie Online   sleepy
Loc: Florida, Cape Coral
I just reviewed Toyota video on how to check the ATF level. The exercise appears to be something a kid came up with. How does a company with thousands of engineers & scientist, design a AT that is so bleeping sensitive to fluid level. A really dumb setup in my opinion. Ed
CX5 Touring 2.5L :-)
#4489656 - 08/15/17 08:00 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: planeman223]
PeterPolyol Offline
Loc: toronto
Maybe it's just botched pressure control logic, something a reflash can [eventually] solve. All those members experiencing the same thing has got to suggest it's not a one-off issue. The flare may not even be from clutchpack or brake-band engagement, it could be as simple as ill-timed TC release for the shift. Some modern autos lockup the TC on even the lower gears, and momentarily unlock/slip it for the shifts. Who knows, but it seems like a logic issue to me.
#4489905 - 08/16/17 06:46 AM Re: 2012 Lexus LS460 Shift Flare when cold [Re: SilverFusion2010]
planeman223 Offline
Loc: Charlotte
It's off to the side +/- where you can manually push the lever for an upshift and pull for a downshift. In this manual mode there is no slip even when stone cold.
#4490018 - 08/16/17 09:57 AM Re: 2012 Lexus LS460 Shift Flare when cold [Re: Eddie]
lexus114 Offline
Loc: Easton, PA
Agreed! friggin stupid
#4491020 - 08/17/17 12:33 PM Re: 2012 Lexus LS460 Shift Flare when cold [Re: planeman223]
nthach Offline
Loc: California
Toyota made that tool specifically for the FWD 6 speeds, the RWD units don't call for it.
Double-check the fluid level both cold & hot(you need to put the tranny in "service mode" where the D light will be on once you hit the hot check temp or Techstream). Use the check plug, it should trickle if the level is OK.
Wouldn't hurt to see if there's a new calibration/firmware for the PCM.
Page 1 of 2 1 2 >
