Whipcitywrencher
Site Donor 2024
Hi Bitogers I have a problem with my abs system, maybe you guys can help me with... with all the fuses in and no light on dash comes on (no codes) go down the road, brakes work as they should, but just before I get to a complete stop the pedal will go to the floor and a groan noise from power booster...I can feel a vibration in the pedal when it does this...Doesn't do it all the time, about 3 out of ten times ...I've replaced the rear speed sensor that mounts on top the differential, I took off the two front speed sensors and cleaned them.. still does the same thing...Im running it now with the abs fuses out, and the brakes work as they should, the only problem is abs light is on now, and it'll probably lock up on ice... not too worried about the ice driving, since the 70's had lots of cars without abs, just that stupid light bugs me, plus I would want it to work as it should...Anyone have any Ideas... Thanks
