Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
51 registered members (AVB, advocate, boulderdentist, carlprop, ABomb369, 5 invisible), 834 guests, and 32 spiders.
Topics291,025
Posts4,854,640
Members66,070
Most Online3,590
Jan 24th, 2017
abs not working correctly 97 explorer 4wd #4488660
08/14/17 07:23 PM
08/14/17 07:23 PM
West Ma.
rollinpete Offline OP
West Ma.
Hi Bitogers I have a problem with my abs system, maybe you guys can help me with... with all the fuses in and no light on dash comes on (no codes) go down the road, brakes work as they should, but just before I get to a complete stop the pedal will go to the floor and a groan noise from power booster...I can feel a vibration in the pedal when it does this...Doesn't do it all the time, about 3 out of ten times ...I've replaced the rear speed sensor that mounts on top the differential, I took off the two front speed sensors and cleaned them.. still does the same thing...Im running it now with the abs fuses out, and the brakes work as they should, the only problem is abs light is on now, and it'll probably lock up on ice... not too worried about the ice driving, since the 70's had lots of cars without abs, just that stupid light bugs me, plus I would want it to work as it should...Anyone have any Ideas... Thanks
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive184k miles
Last Change;
Penn. Plat. HM. 5w30
Fram xg8a, Fram CA8141
I like my oil (slippery).
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488669
08/14/17 07:32 PM
08/14/17 07:32 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
What is the condition of your brake linings? I had exactly your symptoms in a Ranger that needed rear drums and shoes.
Re: abs not working correctly 97 explorer 4wd [Re: Ethan1] #4488699
08/14/17 08:05 PM
08/14/17 08:05 PM
West Ma.
West Ma.
the rotors and pads fairly new about 10k on them, linings? you may have something, do you think the front hoses could be stretched, they all look okay but who knows...still why would they work okay with the fuses out...doubt theres a way to check them shrug
Pete.
Last Change;
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488710
08/14/17 08:16 PM
08/14/17 08:16 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
My father had the exact same situation on his Expedition. Ended up being a baffed wheel speed sensor. Put a scanner on it and monitor them. Which one is buggered up will be readily apparent when you recreate the issue.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488713
08/14/17 08:20 PM
08/14/17 08:20 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You may have a bad front wheel speed sensor, cleaning it does nothing for it if its not reading correctly. Put a scan tool on it and see what the readings are for L/R. I had a 99 ranger do this on me.
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488769
08/14/17 09:23 PM
08/14/17 09:23 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Does it have drums or discs in the rear?
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488779
08/14/17 09:42 PM
08/14/17 09:42 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
the above posters are correct..one of the speed sensors are dropping out right before you come to a stop, making the abs module think a wheel is locking up.
2013 escape 2.0 awd
2008 fusion 2.3 mtx
1996 f150 4.9 2wd mtx
1999 kaw zrx 1100
many husqvarnas
Re: abs not working correctly 97 explorer 4wd [Re: Ethan1] #4488828
08/14/17 11:15 PM
08/14/17 11:15 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
I am 99% sure those were all rear disc, the only shoes were for parking brakes.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488848
08/14/17 11:38 PM
08/14/17 11:38 PM
West Ma.
West Ma.
Your right ,It does have rear disc brakes, shoes for parking...you guys are probably right one of the front sensors is probably messed up but witch one...the bearings are still okay no noise or movement, I dont want to throw parts at it $ , I dont have a scan tool for abs, just have a cheap code reader...whats a good and cheap scan tool that would do the job...Seems like the older I get the more I need speciallty tools and the less i'll use them afterwards... ???
Pete.
Last Change;
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488874
08/15/17 12:26 AM
08/15/17 12:26 AM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
Disconnect the wheel sensor connector. DVOM across the sensor's pins. Ohm sensor...record it.
Set DVOM to voltage....spin wheel...record voltage. Lowest voltage of the two....not good.
Set DVOM to Hz......spin wheel...record Hz. Look for drop outs or fluctuation.
Having a scan tool with ABS PIDS is great. You can see what the ABS module sees, but you have to make due with what you got. Don't know why there is no code.
Since you have a hard fault, I wouldn't waste time checking the tone rings.....unless you actually have a damaged sensor. On second thought, check your tone rings. If they are cast, check for tiny cracks at the base of the teeth, stamped-check for a bent section. Nothing worse than throwing on a new sensor, and then finding out in addition to a bad sensor the tone ring is cracked/bent.
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488875
08/15/17 12:28 AM
08/15/17 12:28 AM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
Are you familiar with FORScan?
http://forscan.org/home.html
Have a second person drive while you watch a data list of all ABS pids
You should see your problem, if it's ABS related
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488876
08/15/17 12:29 AM
08/15/17 12:29 AM
Lakeville, MN
MNgopher Offline
MNgopher  Offline
Lakeville, MN
Had the same symptoms on an '03 F150 - and it was a bad front wheel speed sensor. You will need a scanner that can tell you which channel is flakey. It won't set an ABS code.
And my '97 Explorer was rear discs with parking brake drum setup.
Re: abs not working correctly 97 explorer 4wd [Re: rollinpete] #4488892
08/15/17 01:27 AM
08/15/17 01:27 AM
Wisconsin
Black_Thunder Offline
Wisconsin
the front wheel bearings are probably on their way out. its bearing/hub unit with the sensor included.
my 98 was doing the same thing but AWD i took the hubs off and you could barely turn the bearings by hand.
turns out once the bearings start to go the metal shavings go into the grease causing the sensor not to read the tone wheel very well and thats why the abs does screwy things without hitting the brake hard or locking up the wheels it would kick on.
I'd buy Callahan autoparts if I could.
