Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
27 registered members (Bailes1992, billt460, 4WD, 2015Corolla, alcyon, 3 invisible), 500 guests, and 57 spiders.
Topics286,442
Posts4,908,271
Members67,622
Most Online2,967
Mar 10th, 2019
Worth it to convert to dot 4 lv #4488536
08/14/17 05:01 PM
08/14/17 05:01 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Is it worth it to convert to dot 4 lv? Would be in my F150 and the wife's newer explorer sport. Seems like it would be good in Michigan winter but would it really matter? Other than price, what are the drawbacks?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Worth it to convert to dot 4 lv [Re: buck91] #4488546
08/14/17 05:11 PM
08/14/17 05:11 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Out of curiosity, I looked up what a 2016 Explorer specs. Ford says to use a DOT 4 LV fluid in it.
http://www.fordservicecontent.com/Ford_C...ch=IE&div=f
Me: 13' VW GTI 3 door 6 speed manual
Re: Worth it to convert to dot 4 lv [Re: buck91] #4488551
08/14/17 05:14 PM
08/14/17 05:14 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I should have added in my opinion, it's easier on the pump utilizing a lower viscosity fluid than a thicker fluid.
Re: Worth it to convert to dot 4 lv [Re: buck91] #4488553
08/14/17 05:16 PM
08/14/17 05:16 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
What about the truck, though. It's spec is for dot 3. Any reason not to switch?
2011 F150 4x4 5.0L
Re: Worth it to convert to dot 4 lv [Re: buck91] #4488554
08/14/17 05:17 PM
08/14/17 05:17 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Well it depends what you have...
If only basic ABS then DOT4 is enough...
If you have other candies as ASR....TCS...then you need DOT4 LV to support them (better response)
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Worth it to convert to dot 4 lv [Re: buck91] #4488566
08/14/17 05:31 PM
08/14/17 05:31 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
We are doing a bunch of recall master cylinders on F-150s and the new ones have caps that say DOT 4LV if that means anything.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Worth it to convert to dot 4 lv [Re: buck91] #4488603
08/14/17 06:21 PM
08/14/17 06:21 PM
USA
slacktide_bitog Offline
USA
It certainly won't harm anything! Plus, you do get the higher boiling points of DOT 4 vs DOT 3, which makes it worth the extra $5 smile
Re: Worth it to convert to dot 4 lv [Re: buck91] #4488627
08/14/17 06:41 PM
08/14/17 06:41 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Only drawback is that Dot 4 is more hygroscopic than Dot 3. Mercedes uses Super Dot 4 and recommends brake fluid flushes every 2 years. Dot 3 can go for longer.
Re: Worth it to convert to dot 4 lv [Re: buck91] #4488652
08/14/17 07:06 PM
08/14/17 07:06 PM
Plano, TX
dparm Offline
dparm  Offline
Plano, TX
I've heard that the LV stuff gives a better brake pedal feel at lower temps. If you change the fluid every other year, it should be fine.
I say give it a shot. Worst case, you're out the $20 for the fluid and an hour of your time.
2017 Chevrolet Corvette Grand Sport
Re: Worth it to convert to dot 4 lv [Re: buck91] #4488658
08/14/17 07:20 PM
08/14/17 07:20 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
So dot 4 is supposed to improve ABS vs dot 3?
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Worth it to convert to dot 4 lv [Re: SilverFusion2010] #4488693
08/14/17 07:54 PM
08/14/17 07:54 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
DOT 4LV, yes.
Re: Worth it to convert to dot 4 lv [Re: buck91] #4490858
08/17/17 09:26 AM
08/17/17 09:26 AM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
If the system is calibrated or designed for LV then use it.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Worth it to convert to dot 4 lv [Re: buck91] #4491326
08/17/17 06:30 PM
08/17/17 06:30 PM
Crawfordville FL
Crawfordville FL
Mine is dot 3. Dot 4 is compatible. I haven't changed because it's miserably hot here right now and I've already changed the fluid this year.
If dot 4LV would improve anti-lock and traction control performance I'll give it a go
