S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
119 registered members (anndel, 2015_PSD, AndyB, 2010Civic, ARB1977, agpatel, 15 invisible), 2,048 guests, and 66 spiders.
Topics286,429
Posts4,908,099
Members67,622
Most Online2,967
Mar 10th, 2019
HID light intermittently won't turn on #4488180
08/14/17 09:04 AM
08/14/17 09:04 AM
Ohio
L_Sludger Offline OP
Ohio
I'm wondering about the generalized failure mode of an HID system where the following conditions are met.
1) Of the two headlights, the right side headlight no longer comes on every time.
2) When the headlight won't come on, it stays that way. It won't turn on later with the light switch still turned ON.
3) On several occasions, I was able to get the bad light to turn on by cycling the light switch through on/off cycles several times.
4) When the faulty headlight does turn on, the light output is normal, and it stays on and works properly until it is shut down again.
The system is the headlight setup of a 2002 Acura TL-S. Factory HID lights.
I verified that the electrical connections are clean, secure, and that +12v is being supplied to the bad headlight's interface point at the electrical transformer box. (I think that's the one, the ballast.)
Long story short, I am leaning towards just ordering a replacement ballast. I don't have the means to test whether the ballast is providing +25,000V to the headlamp for obvious reasons, and I am not inclined to do any left to right switcheroo diagnosis to narrow out the bad parts.
So, anyone who has had any experience or anecdotal knowledge of the failure mode of an HID system, regarding which component is likely the culprit among the several components that are involved - what say you? Any reason for me not to just order a ballast?
In the time it took for me to type out this rambling nonsense, I could have had a ballast already ordered and on the way. But I wanted to bend some ears first.
too many cars and oil combinations to list in 150 characters or less
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488191
08/14/17 09:15 AM
08/14/17 09:15 AM
GA, USA
Blokey Offline
Blokey  Offline
GA, USA
This happened with my '00 Acura 3.2TL. I replaced the bulb and I never had the problem again.
Running CAM2 because "you know it's tough and you love it"
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488255
08/14/17 10:20 AM
08/14/17 10:20 AM
Vancouver, Canada
jaj Offline
jaj  Offline
Vancouver, Canada
Can you swap bulbs or ballasts from side-to-side? Try that - then you'll know if the problem is the bulb or the ballast.
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488262
08/14/17 10:25 AM
08/14/17 10:25 AM
MA
Wolf359 Online content
Wolf359  Online Content
MA
Standard way to throw parts at a problem is to replace the bulb first and if that doesn't fix it, the ballast is next. Just don't get cheap bulbs, fake bulbs for $10 will also give you problems.
Re: HID light intermittently won't turn on [Re: Blokey] #4488286
08/14/17 10:51 AM
08/14/17 10:51 AM
Ohio
Ohio
Wow, so the bulb would sometimes work and sometimes wouldn't, and replacing it fixed it?? Shows what I know about HID lights. I figured once a light bulb is dead, it should really be dead and not play half dead.
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488291
08/14/17 11:00 AM
08/14/17 11:00 AM
Ohio
Ohio
Thanks guys, watch this space. My replacement bulbs arrive tomorrow, and I will update accordingly. Prepare to see a post where someone actually follows up on their problem's resolution, rather than leaving everyone hanging on the edge of their seat with nowhere to go!
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488301
08/14/17 11:12 AM
08/14/17 11:12 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Some bulbs have the ignitor circuit in the bulb base (DS1) and some have it in the ballast.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488304
08/14/17 11:15 AM
08/14/17 11:15 AM
NY
Clarkbug Offline
Clarkbug  Offline
NY
Yup, I had a similar experience. One light wouldnt fire up, but would after cycling. Replaced the bulbs and was back to them operating as intended. Ordered a pair of them to get consistent color temps between the bulbs. I hope that fixes it for you!
Re: HID light intermittently won't turn on [Re: jaj] #4488440
08/14/17 02:37 PM
08/14/17 02:37 PM
CA
shinyWheels Offline
shinyWheels  Offline
CA
+1 I would try ^^^ first.
Other thing you might try is starting the engine first and revving it a little and then turn on the headlights. If there's not enough current, the ballast sometimes may have a hard time starting the bulb.
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488456
08/14/17 03:00 PM
08/14/17 03:00 PM
USA
mk378 Offline
mk378  Offline
USA
HID bulbs do that. They start by a high voltage pulse ionizing the gas inside. As they get older it requires more an more voltage until it is more than the ballast / starter can always supply. So, put in a new bulb.
Swapping parts side to side runs the risk of breaking both sides. All of the parts are the ones that came with the car, right, so they're 15 years old. If it turns out the problem was the ballast you have a well-used "good" bulb to keep as a spare.
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488484
08/14/17 03:36 PM
08/14/17 03:36 PM
Texas
440Magnum Offline
440Magnum  Offline
Texas
Its a gas-discharge bulb, more similar to a fluorescent tube or metal-halide streetlight than a regular bulb. They can (and do) fail by becoming hard to "ignite," but once on they'll work fine. Its not like an incandescent where there's a filament that fails and never works again.
Be careful with the old bulb, they're under pressure and once they get hard to light they are at higher risk for bursting.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488535
08/14/17 04:53 PM
08/14/17 04:53 PM
Ohio
Ohio
The fluorescent analogy is perfect 440Magnum. Gas discharge. Eureka! I am disappointed in myself for taking the blame straight to the HVDC transformer. I'm eager to put the new bulbs in. This thread is going places cheers
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488552
08/14/17 05:14 PM
08/14/17 05:14 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Like bigger industrial HID lamps what goes wrong is the center bulb eventually gets coated with black something inside. This then cause too much heat retention ad the bulb and pop with melted glass. had some do this over stored cardboard at the old cheese factory once and stared a fire.
With the bulbs I have and replace about every 18 months they turn pink and if you look closely at the center bulb it is dark colored.
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488608
08/14/17 06:25 PM
08/14/17 06:25 PM
Ohio
Ohio
SHOZ - sodium vapor?
Re: HID light intermittently won't turn on [Re: L_Sludger] #4488715
08/14/17 08:20 PM
08/14/17 08:20 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
For the fire it was 400w MH, sodium bulbs are a bit different. When they get bad they start to cycle, but the center filament will be dark too. But until they start to cycle their light output is fairly stable. The MH and mercury bulbs will start to get dimmer almost immediately.
