JHZR2
Staff member
I keep a dehumidifier and condensate pump in my shop in my basement. They are both fed by a power strip that plugs into a GFCI outlet. Has been this way for years. Over the last few months, three times now the GFCI is tripped. When I reset it, everything comes on, but the only loads that are powered on down there when I'm not working are the dehumidifier and pump.
I'm not seeing any issue with the dehumidifier, but the condensate pump I don't hear as readily. I do think it may be louder than when it was younger, but at the same time, I suspect it gets much less use than one connected to an AC or mod/con boiler.
How long should I expect from these pumps, and how do you know when they are getting close to failing?
