Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
93 registered members (4WD, -SyN-, AndyB, 2010Civic, 11 invisible), 1,947 guests, and 35 spiders.
Topics290,939
Posts4,852,889
Members66,062
Most Online3,590
Jan 24th, 2017
Need a Wall Outlet Adapter, But Can't Find It? #4488047
08/14/17 04:49 AM
08/14/17 04:49 AM
Central Oklahoma
tony1679 Offline OP
tony1679  Offline OP
Central Oklahoma
I don't think I'm asking the impossible here. Surely a major store would have this...?
I need an adapter that plugs into a standard wall outlet. It needs to be a single outlet in and out, and can NOT have any length of cord (to avoid 'daisy-chaining'), but it needs to turn 90 DOWN to the floor. It doesn't matter if the downward facing outlet is turned 0, 90, 180, or 270, just as long as the bend turns 90 down to the floor. All I've been able to find is this, but I want to buy it local instead. I've tried using all the websites (Lowe's, Home Depot, Ace, Walmart, etc.), but nothing similar exists on their sites. All I find are countless left or right adapters, never down. Help? I'll be going to these stores today, but if their websites are correct, I'll leave empty handed...
Edit: This is going to have a corded surge protector plugged into it. To be clear, I am NOT trying to convert a 2-prong to a 3-prong. This outlet is one of the few in my house that is actually proper and grounded correctly. The surge protector's cord just sticks straight out from the wall and I wish to keep the cord against the wall to prevent snagging or tripping.
2008 Chevrolet Impala SS (Tuned- DOD/AFM is EVIL!)
2003 Mercury Grand Marquis LS Ultimate Edition
Macro beer... puke
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488051
08/14/17 05:03 AM
08/14/17 05:03 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Me: 13' VW GTI 3 door 6 speed manual
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: skyactiv] #4488056
08/14/17 05:30 AM
08/14/17 05:30 AM
Central Oklahoma
tony1679 Offline OP
tony1679  Offline OP
Central Oklahoma
In theory, it would work. But would prefer a single outlet instead of 3, and again, local. But kudos, I didn't see that one. thumbsup (added to my last resort options) Thanks!
Macro beer... puke
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488067
08/14/17 06:22 AM
08/14/17 06:22 AM
Virginia
mattwithcats Offline
Virginia
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488105
08/14/17 07:24 AM
08/14/17 07:24 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Good luck on the local availability. Most will only stock what sells and with computers that see sales trends many items end up going to special order. I wanted a 90 degree adapter for a wall mount tv and had to order.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488112
08/14/17 07:34 AM
08/14/17 07:34 AM
USA
mk378 Online content
mk378  Online Content
USA
You can buy a Hubbell right angle plug at Lowes, cut the standard plug off and replace it. I think on those the cord comes out parallel to the wall, "down" in the same direction as the ground pin.
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488122
08/14/17 07:53 AM
08/14/17 07:53 AM
MI
doitmyself Offline
doitmyself  Offline
MI
mk378 beat me to the punch: http://www.homedepot.com/p/Leviton-15-Am...6-ACS/300861765
http://www.acehardware.com/product/index.jsp?productId=29265686&cp=2568443.2568454.1259126
Also, if available, check the commercial suppliers like Kendall, Graybar, Grainger,etc.. Hardware stores tend to be better than big box stores for odd stuff.
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488124
08/14/17 07:54 AM
08/14/17 07:54 AM
near Chicago
Carbon Offline
Carbon  Offline
near Chicago
Not acceptable? Maybe you could find a low profile NEMA 5-15P and replace the existing plug.
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: doitmyself] #4488158
08/14/17 08:44 AM
08/14/17 08:44 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
was about to type this. You WANT to replace the plug, not add an adapter - esp in a high current application. Could you not get a surge protector with a right angle - or better yet replace existing duplex and add a surge protector outlet. have fun.
I was going to add a special home theatre circuit for my "hi Fi system" using metal clad 10/3 I also have a bunch of 230V 50hz subwoofer amps I was going to add a 220V circuit to the living room - haven't check code on that yet smile
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: ARCOgraphite] #4488172
08/14/17 08:56 AM
08/14/17 08:56 AM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Yeah a big plus one for ARCO here if its feasible.
too many cars and oil combinations to list in 150 characters or less
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488183
08/14/17 09:06 AM
08/14/17 09:06 AM
Lemont IL
Fattylocks Offline
Fattylocks  Offline
Lemont IL
I found two different cords marked air conditioner extension cord. Heavy gauge wire and a 90 degree plug at the wall.
94 Caprice Wagon Daily driver
05 Focus Wagon 2.0 Duratech Thrifty city car
05 P71 ex Homeland Security emergency Beagle cruiser
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: Carbon] #4488187
08/14/17 09:09 AM
08/14/17 09:09 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: Carbon
Not acceptable?
^^^ This looks like the winner ^^^
I was thinking used "refrigerator cord" (these have a very flat plug) then add a good female to it.
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488237
08/14/17 10:00 AM
08/14/17 10:00 AM
Michigan
slug_bug Online content
slug_bug  Online Content
Michigan
This looks like exactly what you are looking for: Hosa PWA-486
https://www.amazon.com/Hosa-PWA-486-5-15...ds=Hosa+PWA-486
2016 Miata 2.0l (12k)
2013 Fusion 2.5l(78k)
2013 Focus(56K)
2010 Linc MKX 3.5l(88k)
2007 Dodge Caravan 3.8l(179k)
2003 Merc. Mountaineer 4.6l(114k)
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488341
08/14/17 11:58 AM
08/14/17 11:58 AM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
Above are good choices.
But for future references, you can buy surge protectors that are already angled.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Need a Wall Outlet Adapter, But Can't Find It? [Re: tony1679] #4488411
08/14/17 01:43 PM
08/14/17 01:43 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
For anyone else needing one that goes to the side, it's called hug-a-plug.
https://www.hugaplug.com/
