2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
13 minutes 4 seconds ago
VOA Ravenol ECS 0W-20
by PWMDMD
20 minutes 50 seconds ago
2020 mid-engine Corvette spy vid?!
by AZjeff
22 minutes 39 seconds ago
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
33 minutes 38 seconds ago
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
57 minutes 23 seconds ago
High Lead Redline 5W40 thoughts? Ty
by Pajero
Today at 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
Today at 09:32 PM
Another thick/thin article to discuss
by JLTD
Today at 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
Today at 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
Today at 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
Today at 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
Today at 08:32 PM
VWs at Pick n Pull
by Eric Smith
Today at 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
Today at 08:12 PM
Breaking in new short block
by Bub
Today at 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
Today at 06:32 PM
Weber Q300 Grill Parts Help
by gathermewool
Today at 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
Today at 05:13 PM
Xfinity mobile cell service
by jay929
Today at 04:37 PM
Fuse "failure"
by dlundblad
Today at 04:32 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
76 registered (4WD, 2015_PSD, ag_ghost, 92saturnsl2, 69Torino, 6 invisible), 1264 Guests and 30 Spiders online.
65299 Members
67 Forums
285812 Topics
#4487966 - 08/13/17 11:20 PM 1996 vortec 5.7 oil recommendation
96Vortec Offline
Loc: South Alabama
I just bought a 1996 chevrolet c1500 with the 5.7 Vortec with 167,000 miles. I want to know what weight and type to use. Here in south alabama I have always ran 10w30 conventional chevron supreme in my beater Chevy 350 tbi's but i want this motor to last. My father had a 99 suburban with the 5.7 and his finally slung a rod at 307,000 miles. I want this engine to last like that one. This is not a work truck. Just my daily driver. Currently im looking at Havoline 10w30 synthetic blend but ive had a bad experience with a 350 and synthetic oil. It was a tbi 350 but i still could see multiple leaks occuring again considering its already a high mileage engine. If not the Havoline then what do you think about the dino chevron supreme? Also i want your opinion on oil filters. Something specifically with great drainback protection. Thank you
#4487970 - 08/13/17 11:21 PM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
JHZR2 Offline
Loc: New Jersey
I don't think you can go wrong with PYB in those engines. Fur years I ran fancy oils in my 98 4.3, but I'm just not seeing the benefit.
#4487975 - 08/13/17 11:30 PM Re: 1996 vortec 5.7 oil recommendation [Re: JHZR2]
96Vortec Offline
Loc: South Alabama
This is my first vortec. What commonly fails on these engines in your experience. Whats your mileage?
#4487976 - 08/13/17 11:31 PM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
Run Offline
Loc: Canada
Valvoline Maxlife should work nicely.
03 Neon 2.0 - VSP 5W-30 Pentius XL
#4487985 - 08/14/17 12:05 AM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
Chris142 Online   content
Loc: Deplorable in apple valley, ca
The truck will fall apart around that 350.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4487995 - 08/14/17 12:28 AM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
Linctex Offline
Loc: Waco, TX
15W-40.
The flavor doesn't matter.
It'll see 400,000.
#4488002 - 08/14/17 12:46 AM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
ArrestMeRedZ Online   content
Loc: Las Vegas
Intake manifold gaskets. Yours have probably already been changed out, but watch it in case they weren't, or were replaced with the gaskets that were the original bad design. 1996 was the first year for the use of Dexcool, and those gaskets combined with Dexcool were a problem. Mine went at 66k. Other than that, my engine has been bulletproof.
Cheap parts, easy to work on, and reliable to boot, other than the gasket problem. I have used synthetic oil from the start, and haven't had a leak yet. Factory recommendation is for 5W-30 anywhere, with 10W-30 acceptable for non-freezing weather conditions.
#4488027 - 08/14/17 01:44 AM Re: 1996 vortec 5.7 oil recommendation [Re: ArrestMeRedZ]
JHZR2 Offline
Loc: New Jersey
+1. Id do an oil change, with a quick 500 mile OCI on the same oil, just to get consistent oil in there, then pull a UOA after 1000-3000 miles on the second change.
Look for telltale signs of a LIM leak.
If you have a diagonal radiator neck, check the cap. Plastic caps are bad. Stant caps at least were good.
Id do a change of the coolant regardless. My truck has all original, clean and bright cooling system, having never seen anything besides dex cool. Dex isnt bad in an dof itself, with new gaskets at least. Mixing it with other stuff like green coolant is. Rebaseline it by changing out the radiator and then after 1000 miles doing the radiator again, that will get >50% out at least. Any signs of brown sludge and you may need to be a bit more aggressive and/or flush the block.
Why not get some fresh Dex VI in there too, if you trust that the AT has been serviced before?
plugs, wires, and distributor all ok?
#4488029 - 08/14/17 02:08 AM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
maxdustington Online   content
Loc: Toronna
The spider injectors go bad and have to be replaced with a conventional mpfi conversion harness which is available pretty cheap on amazon. We have a 97 305 and my dad told me the plastic intake manifold exploded?! Due to this. It was running like trash before that so i want to believe him. Ours went bad at about 190k km.
You can also run a different intake from a boat 350 vortec that has a more conventional injector set up but that would be more for a hotrod instead of a DD.
Make sure you block the air intake silencer box off with the bottom of a pop can, too. I did that back in 2006 and i think it's still there.
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
#4488041 - 08/14/17 03:40 AM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
We have a few in Izusu NPR HD's. They've been run on HDEO 15w40 their entire lives with only one issue. One started Rod knocking at 330k and now gets SAE60. Going almost 40k on the rod knock with SAE60.
Skip the 5w30 if you drive your truck like a truck and want longevity. Seen too many of those engines with excessive blowby north of 150k miles using that.
I'd say a high HTHS 10w-30 at a minimum, but 15w40 being the preference.
#4488083 - 08/14/17 06:55 AM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
FordCapriDriver Offline
Loc: Balearic Islands , Spain
Valvoline Maxlife 10W-40 should work great, it's known to stop leaks quite well.
I would change the coolant too.
1975 Ford Capri II Ghia 3000 V6, - Valvoline VR1 20W-50
1988 Ford Escort MkIV 1.6 Xr3i Cabrio, - Shell Rimula R4X 15W-40 HDEO.
#4488106 - 08/14/17 07:25 AM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
czbrian Offline
Loc: Houston, TX
My family has had a ton of trucks or tahoes with either the Vortec 5.7 or 5.0. All lasted to around 300K miles before they were either wrecked or eventually sold using various flavors of 10w30. Early in their lives we used mostly Mobil 1 but usually switch to something less expensive later on such as Mobil 5000.
#4488223 - 08/14/17 09:45 AM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Run whatever HM grade between 5W30 and 20W50 that gets the hot oil pressure in a good range (around 15-20 at idle, 35 or higher at cruise)-but if it hasn't been done, the lower intake manifold gasket WILL FAIL and kill your bottom end. Losing the Dexcool (if its old enough to have come with it) isn't a bad idea either-but replace thos LIMK gaskets!
Edited by bullwinkle (08/14/17 09:45 AM)
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4488282 - 08/14/17 10:43 AM Re: 1996 vortec 5.7 oil recommendation [Re: 96Vortec]
Merkava_4 Offline
Loc: Clovis, CA
Some kind of 40 weight would be good. I like the MaxLife idea.
