and chime in about what you agree with and not.
thx........
I was in discussions with my friends in OZ who also run Direct Injection engines on the Mazdaspeed engines and they have reached this conclusion to avoid carbon buildup.
Do not change your oil every 3k or 5K. Go synthetic and change it every 10K.
Quote:
Why is it harmful to change the oil too frequently?
In a word; volatility. Oil volatility is at its greatest in the first 3000km after an oil change. After that the volatility reduces and the oil stabilises.
Volatility is particularly bad for a DI engine because all of the lost fractions exit via the PCV system. Much of it goes out through the rocker cover vent, into the intake, through the turbo compressor and intercooler, then puddles in the bottom of the inlet manifold where it combines with the stuff coming through the PCV valve to coat the inlet valves and combustion chambers in gunk.
That black soot you see in your exhaust pipes, don’t assume it’s all caused by rich mixture. Excessive oil changing will contribute more soot.
The presence of oil in the intake also lowers the octane rating of your fuel leading to detonation.
The NOACK volatility test quantifies the extent of oil evaporation. The test standard - ASTM D5800 - 08 Standard Test Method for Evaporation Loss of Lubricating Oils by the Noack Method – also hints at another kind of danger associated with frequent oil changes where it states “Procedure C, using the Selby-Noack apparatus, also permits collection of the volatile oil vapors for determination of their physical and chemical properties. Elemental analysis of the collected volatiles may be helpful in identifying components such as phosphorous, which has been linked to premature degradation of the emission system catalyst.”
A lot of phosphorous is lost in the initial boil-off phase of new oil and it’s likely to be harming oxygen sensors and cats.
Engine manufacturers understand the problem and it would be easy for them to identify the type of damage done by over servicing and potentially result in a warranty claim denial.
Summary
By changing your oil at 5000km, you are subjecting your engine to oil that is almost always in the initial boil-off phase. It's contaminating and filling your engine with gunk. Contrary to popular and uninformed opinion, oil that is 10,000 km old is not likely to be harmful, and would certainly be less harmful than fresh oil.
thx........
Summary
