Rust Belt vs Sun Belt cars
by ZZman. 09/25/18 11:33 AM
Enginer rebuilder's view of GDI intake issues
by Brigadier. 09/25/18 11:09 AM
Oil for '84 Caddy w/HT-4100
by StillLearning. 09/25/18 10:41 AM
Interesting video of diff with clear cover
by mrdctaylor. 09/25/18 10:15 AM
The death of American footbal
by Brigadier. 09/25/18 10:01 AM
Tire leaking from bead/rim
by Brybo86. 09/25/18 09:39 AM
2000 4Runner 3.4L
by ka9mnx. 09/25/18 08:59 AM
VW 508 Spec 0w20 Updates?
by Zee09. 09/25/18 08:36 AM
Laptop Recommendations
by buster. 09/25/18 08:24 AM
Mac OSX Mojave - vid card requirements
by OVERKILL. 09/25/18 08:05 AM
Age of first drive
by madRiver. 09/25/18 08:02 AM
Please, maintain your tires properly
by 53' Stude. 09/25/18 06:58 AM
Cycling health
by CourierDriver. 09/25/18 06:08 AM
Stupidest thing you've ever done (or not done)
by Speak2Mountain. 09/25/18 06:01 AM
First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
113 registered members (ARCOgraphite, Aichiguy, 69Torino, 1JCB, 28oz, 11 invisible), 1,705 guests, and 38 spiders.
Topics290,988
Posts4,853,832
Members66,063
Most Online3,590
Jan 24th, 2017
Fuel Polishing #4487366
08/13/17 01:39 PM
08/13/17 01:39 PM
Georgia
DeepFriar Offline OP
Georgia
Those of you who have experience with either heavy equipment, marine or JP-type aircraft fuel storage, can you discuss or point me toward more or less automatic high filtration systems? Some questions I have: Is a continous system necessary or could a periodic polish by a contractor be more economic? Should the fuel be filtered as it is delivered into a new or clean tank or wait till it's in there? What type filtration is thought to be best (for instance there are centrifugal systems and simple media filters)? The initial application is for minimum two, maximum five, 10,000 gallon tanks in a storage/backup system. Thanks.
Edit: The specification is for ISO particle code 18/16/13 who ch I am not familiar with.
2nd Edit: I found the Parker-Hanefin (sp?) handbook on standards and still not sure if I know what I'm looking at.
Re: Fuel Polishing [Re: DeepFriar] #4487460
08/13/17 03:16 PM
08/13/17 03:16 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Typically polishing is for diesel fuel. Bacteria can grown in diesel fuel. You can kill them but the reminents are there still.
Typically boats.
2015 Ford F250 w/Powerstroke
Re: Fuel Polishing [Re: DeepFriar] #4488003
08/14/17 12:48 AM
08/14/17 12:48 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Visit your local airport and see what filters they are using for their "Jet A"
Now, the fuel delivered to the airport bulk tanks comes in on normal bulk semi-trucks.
However, the truck that drives up to your King Air 200 or Cessna Citation has a LOT of filters located on it.
Re: Fuel Polishing [Re: DeepFriar] #4488030
08/14/17 02:18 AM
08/14/17 02:18 AM
Georgia
Georgia
The end application for this one is something of an unknown. It's a federal government RFP (Request for Proposal) for equipment to be delivered stateside for installation "by others", probably offshore and probably remote (I'm guessing). Whatever it may be for they apparently anticipate that the fuel will either sit for extended periods or have resupply with less than high quality fuel. I'm just doing some back of the envelope trades to see if there are other options to present that might make sense.
By the time an RFP hits the street and you haven't been working the problem leading up to that point, you'd better have a different and "better" answer to push. So that's where I am or rather that's where my customer is. Thanks for your input. I have found some mechanical systems from Racor, Alfa Laval, Reverso and others. My approach will be to treat the fuel chemically and then perodically clean it for water and debris of all sorts. I don't like the idea of a continuously running fuel circuit. Somebody's got to monitor it, fix it if it breaks, uses energy, etc. BTW I lived a couple of years in Lincoln. One of my girls was born there. Nice town.
Re: Fuel Polishing [Re: DeepFriar] #4491423
08/17/17 08:35 PM
08/17/17 08:35 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
I care for four 2000 kW Caterpillar generator sets at work. We have two six thousand gallon fuel tanks in the basement.
A few years back, the fills which are out in the sidewalk got water in them and froze. I ended up with a whole bunch of water in one of my tanks. I got the bulk of it out in my Racors but I also got a bunch of Algae in it as well. Between algaecide and fuel treatment, I also installed fuel polishers on both tanks. They run for a few hours every time I activate them and I change the filter every month to keep the flow rate up.
I had my fuel tested last month and it came back good. I feel fortunate I was able to save the fuel. It would have been almost unthinkable to drain that tank.
Re: Fuel Polishing [Re: DeepFriar] #4491504
08/17/17 10:59 PM
08/17/17 10:59 PM
Georgia
Georgia
Thanks NYEng, that gives me some confidence. If I may ask, what units did you choose for the polishers? What sort of price target should I be looking for? Any maintenance issues with them? Thanks again for your input, much appreciated.
Re: Fuel Polishing [Re: DeepFriar] #4491956
08/18/17 01:48 PM
08/18/17 01:48 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
Fuelseps by Walker. They were about 4500 dollars apiece. No issues at all. I'm a freak for changing filters.
Re: Fuel Polishing [Re: NYEngineer] #4492373
08/18/17 10:34 PM
08/18/17 10:34 PM
Georgia
Georgia
A true BITOGGER then..... Thanks again for the help.
Re: Fuel Polishing [Re: DeepFriar] #4492392
08/18/17 10:56 PM
08/18/17 10:56 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
No problem.
