And wow! What I thought was a spark plug induced stumble on cold start and idle is GONE! Idling smooth as glass and everything about driving the car has improved. Engine is smoother at all RPM and shifts are smoother as well.
If you have a high mileage vehicle it is worth spending the $8 at Walmart for the CRC throttle body cleaner and MAF cleaner. It took me about 30 min to pull the airbox, remove the MAF, spray it out and set it aside to dry while I pulled the throttle body and cleaned it out. Reassembled everything and got a funky start because of leftover throttle body cleaner and it settled into the smoothest idle it has had since I bought it.
Not a gimmick!
Not a gimmick!
