Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
115 registered members (alphadog, 1978elcamino, addyguy, Alfred_B, 69Torino, 11 invisible), 2,381 guests, and 55 spiders.
Topics286,019
Posts4,900,869
Members67,548
Most Online2,967
Mar 10th, 2019
Installed new sway bar bushings #4487279
08/13/17 12:14 PM
08/13/17 12:14 PM
VetteElite Offline OP
Wow, what an improvement. After 9 years on the stock rubber bushings, they were shot. Crumbly and super soft, no wonder I had a persistent clunk over bumps as the sway bar rattled up and down in its bushings instead of turning and flexing like it should. I went with the blue Moog thermoplastic bushings and greased them with Sil-Glyde per a tip I read somewhere else to reduce the chance of squeaking when switching from rubber to thermoplastic. Steering response is improved, no more clunking over bumps or when accelerating while turning, and so much less body roll! Makes the car feel much more sportier and makes me feel much more in control, both things I like.
Installation of the driver's side was fine, just had to crawl under the car a bit and fit my hand in some tight spots to wrench the bolts out. Luckily they came right out with a squirt of PBlaster. Passenger side was way worse, however. Much less clearance to fit a wrench. Used the 12 point box end and probably had to take it on and off about 100 times turning it barely any each turn before running out of space. Luckily, with the thermoplastic bushings I'm banking on never having to do it again on the front. However, now I'm really considering tackling the rear sway bar as well. I'm sure the bushings are just as bad and could use a replacement.
Re: Installed new sway bar bushings [Re: VetteElite] #4487331
08/13/17 01:06 PM
08/13/17 01:06 PM
Georgia
DeepFriar Offline
DeepFriar  Offline
Georgia
I'm a big believer in changing all of them. Nothing I've ever done, short of replacing a bad shock, has contributed more to ride quality and that "feels new" feeling. The other is the control arm bushings. Benefits out of all proportion to the modest cost.
