Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
Lubegard Red or Platinum
by diyjake. 09/21/18 11:01 AM
Storing Car Outside
by Delta. 09/21/18 10:47 AM
Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
107 registered members (379KITTY, 853okg, andyd, 2010Civic, 14Accent, 9 invisible), 1,813 guests, and 40 spiders.
Topics290,766
Posts4,849,983
Members66,034
Most Online3,590
Jan 24th, 2017
Jack stand/ bottle jack combos #4487225
08/13/17 11:07 AM
08/13/17 11:07 AM
Indiana
dlundblad Offline OP
Indiana
Anyone here have one? They look super handy and convenient.
https://www.amazon.com/Powerbuilt-640912-3-Ton-Bottle-Stand/dp/B003ULZGFU
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Jack stand/ bottle jack combos [Re: dlundblad] #4487230
08/13/17 11:14 AM
08/13/17 11:14 AM
MN
oil_film_movies Offline
MN
I'm not liking the offset distance between the bottle jack and jackstand lift spot. That would create rubbing as that little connection piece is torqued.
Maybe overcome by applying lithium grease to the inboard side of the jackstand shaft.
Re: Jack stand/ bottle jack combos [Re: dlundblad] #4487260
08/13/17 11:39 AM
08/13/17 11:39 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I use jack stands in pairs. I'd rather use my current setup, a good floor jack and jack stands. I also think jacking a car with a good floor jack is safer, and easier. Then if I want to jack from under my rear pumpkin, I can with a floor jack, I wouldn't dare try it with that.
God Bless Our Troops
Re: Jack stand/ bottle jack combos [Re: demarpaint] #4487280
08/13/17 12:15 PM
08/13/17 12:15 PM
MN
MN
This device needs to be used in pairs too. Notice the jackstand top isn't a circular shape like a floor jack has. Also, its a problem that the bottom can't move slightly on wheels like a floor jack is designed to do. I'm giving it a thumbs down. Careful with this one. This combo jackstand/bottle-jack is stabilized at the bottom by the broad base, which means the vehicle must shift at the top slightly as the vehicle moves upward in a slight arc.
Re: Jack stand/ bottle jack combos [Re: dlundblad] #4487295
08/13/17 12:31 PM
08/13/17 12:31 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
I have 4 of them in the larger size to lift my Montero all 4 wheels off the ground and they work great. You will want to check ebay out as mine were under $50 each delivered from Pepboys. Only thing better for my SUV would be an actual lift. Very stable and well built.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Jack stand/ bottle jack combos [Re: oil_film_movies] #4487349
08/13/17 01:22 PM
08/13/17 01:22 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Exactly, that would be the only way to use it. Although I bet there are people who'd try and use it as a floor jack. Then if you were to use it in pairs you'd have to slowly go from side to side, lifting a little at a time. When I do brake work for example, I want both wheels on the axle in the air. Tire rotations, all four in the air. Again imo a good floor jack and jack stands will be safer, and faster.
Re: Jack stand/ bottle jack combos [Re: dlundblad] #4487354
08/13/17 01:27 PM
08/13/17 01:27 PM
MN
MN
spk2000, using 4 like you do avoids the arc-lift geometry issues. I'd keep the inboard side of the jackstand shaft dry-lubed or lithium greased to avoid binding there, as the torque from lift produces loads of around ~400 lbs in that small area per ton of lift.
Re: Jack stand/ bottle jack combos [Re: dlundblad] #4487371
08/13/17 01:43 PM
08/13/17 01:43 PM
Indiana
Indiana
Couple things that the above commenters should consider: (I should have also mentioned this would be used on my Jeep. I can't see it working with my truck with an exception of the rear end.)
If you pick a vehicle up by it's axle tube, the jack shouldn't move at all. Place it below the axle tube and lift straight up. The typical trolley jack needs wheels and moves because the cylinder is perpendicular to the lifting direction. You can get a bigger cylinder and higher lifting distances with this design too.
As far as the design, (the offset between the jack and the stand), it definitely comes at a cost. 6000 lbs isn't much for a bottle jack that size. Just looking at Harbor Freight's site, a jack around that diameter is rated for 8000 lbs.
Re: Jack stand/ bottle jack combos [Re: dlundblad] #4487373
08/13/17 01:48 PM
08/13/17 01:48 PM
MN
MN
That offset produces what we engineers call "wing root bending moment", if this was an airplane wing. Anyway, Statics 101 engineering. That moment must be opposed by large lateral force on the shaft, which creates a high-friction condition on the jackstand shaft. (The bottle jack is fine.) Like I said, dry-lube or lithium grease and it should be fine. Also keep it clean.
Re: Jack stand/ bottle jack combos [Re: oil_film_movies] #4487382
08/13/17 01:54 PM
08/13/17 01:54 PM
Indiana
Indiana
I would have to see (or hear) it in action to determine whether this is an actual issue or not.
Re: Jack stand/ bottle jack combos [Re: dlundblad] #4487566
08/13/17 04:36 PM
08/13/17 04:36 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Problem with that is the minimum lift height. So you already have to get all four corners decently high up already.
Re: Jack stand/ bottle jack combos [Re: dlundblad] #4487695
08/13/17 06:43 PM
08/13/17 06:43 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
I have used these one jack to lift one wheel and had no issues. It is solid and stable.
I understand the statics and forces applied but it still works fine. Mine are the larger size rated for 6,000 lbs each so they are way overkill for my suv. I think it weighs slightly under 5,000 lbs total vehicle weight.
96 Grand Marquis
01 Sable LS
02 Montero
