Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on ‚Äúclearance‚ÄĚ at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
19 registered members (billt460, ctechbob, dlundblad, avi1777, cjolson140, 2 invisible), 542 guests, and 55 spiders.
Topics286,171
Posts4,903,552
Members67,572
Most Online2,967
Mar 10th, 2019
My next set of tires: 205/70R15 on a 2007 Corolla #4487038
08/13/17 04:22 AM
08/13/17 04:22 AM
nyc
mareakin Offline OP
mareakin  Offline OP
nyc
OEM tires were 185/65R15 for the base model (what I have,) and 195/65R15 for the more common LE model. The base model looks better by the way.
So much sidewall looks clownish but I want that extra soft ride, that extra ground clearance (by about .8 inch)
I have chosen a set of Hankooks that weigh only 19lbs. and has a short tread width (thus negating the extra impact on fuel economy of a wider tire.)
Ground clearance will be 6.5 inches (almost like a crossover!)
So much extra sidwall!!!! YIPEEEE!!!!
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487051
08/13/17 05:56 AM
08/13/17 05:56 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
Does it clear from the inner wheel arch when steering? What does the law tell about this oversizing ? In Europe we can't go more than +/-3% of the total wheel diameter. You're at +5.2% going from 195/65, +7.3% from 185/65 that you have, and almost +20% sidewall FYI
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealerís overfilled, 16000 Km
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487053
08/13/17 05:59 AM
08/13/17 05:59 AM
NC
Cgreene221 Offline
Cgreene221  Offline
NC
You need to make sure your turning clearance is ok before putting all 4 on. I'm not really sure that size will work
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487055
08/13/17 06:03 AM
08/13/17 06:03 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
IMHO there will be some interference when steering and pushing down body... get a 205/70 R15 complete wheel and mount it on each corner, then steer and press body down to test. Before buying 4 tires...
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487057
08/13/17 06:04 AM
08/13/17 06:04 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
I dont see why it wouldnt work. Its just a different trim on the same model.
And law about oversizing tires, thats a knee slapper. That wouldnt fly here; everybody and their grandfather wants a lifted pickup truck with 38" all terrain tires.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: Colt45ws] #4487058
08/13/17 06:12 AM
08/13/17 06:12 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
It's 185/65 R15 (CE trim), 195/65 R15 (S or LE trim), 195/55 R16 (S model)
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: Superflan] #4487067
08/13/17 06:27 AM
08/13/17 06:27 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Oh I didnt even fully read/process the title; I thought he was going from 185/65 to 195/65 which is almost nothing.
I don't think it will be a problem on a stock-sprung vehicle, but OP needs to run his front tires to lock and see how much clearance he has then.
Also, he should be aware that he will be traveling further than his odometer is reading. Speedometer will be well off and gas mileage will appear to tank. You'd have to apply a correction to any MPG calculations to get the real number.
-Colton
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487084
08/13/17 07:03 AM
08/13/17 07:03 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Those particular Hankooks are JUNK.
Any tire with a narrow cross sectional width relative to the tire casing width is a cheap tire, using cheap construction by omitting
a better layout for the belts. They will not last as long and use a cheap tread compound that is lousy in wet weather. They will not ride as good compared to tires with better construction in the same size.
Plus you gotta devote added mental energy to your driving for the speedometer correction.
Me: 13' VW GTI 3 door 6 speed manual
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487089
08/13/17 07:10 AM
08/13/17 07:10 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
You can't judge by the opening of your wheel well, you have to measure where your struts & strut towers are. Most likely you will be rubbing something.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: skyactiv] #4487092
08/13/17 07:17 AM
08/13/17 07:17 AM
ME
eljefino Offline
eljefino  Offline
ME
How do you even know, since the OP never mentioned the model? (I assume they're 724s BTW)
I have a set of 724s on my benz in 75-series and hoo boy do they squeal on gentle corners. But they ride extremely well.
Cars are designed with clearance for snow chains, so if OP doesn't need them, I bet everything will work fine.
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487095
08/13/17 07:24 AM
08/13/17 07:24 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
It's been my experience that going up 2 tire sizes is OK, but this is 3 - and I think there will be rubbing - very bad!
Plus, I doubt any retailer would sell/mount that size tire on the car - liability reasons.
And according to Discount Tire, that size doesn't fit - but they don't publish anything over 3% different in diameter even if there is room, and this is 7%
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: skyactiv] #4487129
08/13/17 08:26 AM
08/13/17 08:26 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
Just install a speedo corrector
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487167
08/13/17 09:43 AM
08/13/17 09:43 AM
USA
slacktide_bitog Offline
USA
Going from 185/65 to 205/70 is a huge difference, and the downsides will outweigh the upsides to a point where it's not worth doing.
You should just go to the 195/65-15 size that was available on the higher Corollas. It will give you a little more sidewall that will be enough to give you a better ride.
Also, the choice of tire can make a difference on ride quality, too. What kind of tires do you have on now? How many miles on them?
Are your shocks in good shape? When is the last time they were replaced? Worn shocks will give you a rough ride. They wear gradually, so even though you might not notice poor ride and handling now, you may notice an improvement once you replace them smile
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487237
08/13/17 11:21 AM
08/13/17 11:21 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
Going with 195/65 R15 is 6.4% SIDEWALL INCREASE smile and choosing tires rhat provide comfortable ride will do the rest. Shocks also, maybe...
Re: My next set of tires: 205/70R15 on a 2007 Corolla [Re: mareakin] #4487299
08/13/17 12:35 PM
08/13/17 12:35 PM
Rijeka, EU
chrisri Offline
chrisri  Offline
Rijeka, EU
195/65/15 is "normal" size tyre for 00s base model compacts in Europe, can't see why would be different in NA. 205/70/15? That can't be standard size for any modern car, maybe for some older bigger cars or cargo vans?
Certainly it would look odd and rub on wheel arches.
02 Nissan Terrano 2.7.TDi Motul 15w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
