K&N HP2009 older version 8331 miles 04 Corolla
Roseville, CA
I know this is not relevant to filters you can buy now, but there has to be someone interested...
The filter was used for almost 8 months, oil used was QSUD 5w30.
This run has seen less road trips than usual, also shorter commutes (10 miles one way) for the last 3 months of the interval.
The filter held up great, as expected. I'm not happy about all the sediments though, not sure what's going on.
The bypass valve assembly is not easily removable.
The PITA to cut can was thicker than the Wix 51516 which again was thicker than the Purolator PSL20195 (which I'll hopefuly post in the tranny filters section tomorrow).
Made January 12, 2012
Thank You for cut&post
