64806 Members
68 Forums
282100 Topics
#4486980 - 08/13/17 12:37 AM
Wix 51516 cut open 4940 miles 97 Nissan Maxima
Loc: Anaheim, CA
1997 Maxima 175k, Delvac 15w40, Wix 51315 2004 Corolla 189k, VWB 5w20 + SSS 10w40, MGL4967
#4486992 - 08/13/17 01:16 AM
Re: Wix 51516 cut open 4940 miles 97 Nissan Maxima
[Re: zorobabel]
Loc: PNW
No defects that I can detect on this filter, though I'm not sure the metal part in the second photo is supposed to be loose like that. That's the bypass valve assembly located at the base plate end, and it's normal for it to be loose after the filter is cut open. The coil spring in the dome end keeps all the internal parts tight together.
We Don't Need No Stinkin' Efficiency!
#4486995 - 08/13/17 01:18 AM
[Re: zorobabel]
Loc: South Eastern, CT
Looks great.
The "metal piece" you are referring to is the bypass valve, it just sits on top of the end cap. The spring at the bottom of the filter forces everything together tightly, making a good seal between the parts of the filter.
Thanks for posting!
11 Chevy Silverado - PP 5w-30 10 Ford Focus - QSAD 5w-20 14 Yamaha Super Tenere - Delo 15w-40
#4487009 - 08/13/17 01:48 AM
[Re: zorobabel]
Loc: Anaheim, CA
Thanks for the comments! The bypass valve has been tightly attached to the filter element on other K&N filters of a similar contruction that I've cut.
#4487076 - 08/13/17 06:45 AM
[Re: zorobabel]
Loc: The Old North State
Filter looks good at ~5k miles. Typical Wix/Napa Gold quality construction IME. Bypass valve designed as explained above.
Something doesn't add up though. 97 Nissan Maxima calls for the Wix/NG 5/7356 (7317) oil filter which uses metric threads. The topic filter uses SAE threads. I thought the filter looked tall/large for a Nissan filter application.
Perhaps a remote/relocation filter kit on the Maxima?
Thanks for c&p.
#4487175 - 08/13/17 09:55 AM
[Re: Sayjac]
Loc: USA
Just make sure you didn't damage the threads on where the filter screws in... Filter looks good at ~5k miles. Typical Wix/Napa Gold quality construction IME. Bypass valve designed as explained above.
Thanks for c&p.  Came here to say this. I have a Maxima of this vintage, which takes the 57356, which uses a different thread than the 51516 uses  Also, the filter on this car is mounted sideways, and points to the side of the car, located near the right tire, not really enough room to fit a 51516!
#4487235 - 08/13/17 11:19 AM
[Re: Sayjac]
Loc: Anaheim, CA
Thanks for c&p. Good catch. I had my father make me a filter mounting nipple before he retired. It has 20mmx1.5 on one side and 3/4x16 on the other. I switched this for the original so I could use my extensive stash of 3/4x16 oil filters and use larger filters at that (the larger 20mmx1.5 options I used in the past are extinct).
#4487240 - 08/13/17 11:24 AM
[Re: slacktide_bitog]
Loc: Anaheim, CA
Just make sure you didn't damage the threads on where the filter screws in... Came here to say this. I have a Maxima of this vintage, which takes the 57356, which uses a different thread than the 51516 uses  Also, the filter on this car is mounted sideways, and points to the side of the car, located near the right tire, not really enough room to fit a 51516! See the above post for the nipple switch. The 51516 has enough room to not even touch the splash guard, there's about 1 cm clearance to the splash guard. Now if you run wide tires that possibly rub the splash guard you might run into issues.
#4487321 - 08/13/17 12:54 PM
[Re: zorobabel]
Loc: PNW
Good catch. I had my father make me a filter mounting nipple before he retired. It has 20mmx1.5 on one side and 3/4x16 on the other. I switched this for the original so I could use my extensive stash of 3/4x16 oil filters and use larger filters at that (the larger 20mmx1.5 options I used in the past are extinct). Make sure to swap it back if you ever sell or trade-in the car, otherwise a future owner is going to have a problem using the specified filter for the car.
#4487379 - 08/13/17 01:53 PM
[Re: ZeeOSix]
Loc: Anaheim, CA
Good catch. I had my father make me a filter mounting nipple before he retired. It has 20mmx1.5 on one side and 3/4x16 on the other. I switched this for the original so I could use my extensive stash of 3/4x16 oil filters and use larger filters at that (the larger 20mmx1.5 options I used in the past are extinct). Make sure to swap it back if you ever sell or trade-in the car, otherwise a future owner is going to have a problem using the specified filter for the car. Absolutely, in fact I have the original nipple on the car right now, as I want to use up the rest of my filters in 20mmx1.5.
#4487384 - 08/13/17 01:55 PM
[Re: zorobabel]
Loc: PNW
#4487580 - 08/13/17 04:58 PM
[Re: zorobabel]
Thanks for c&p. Good catch. I had my father make me a filter mounting nipple before he retired. It has 20mmx1.5 on one side and 3/4x16 on the other.... Interesting, first time I've seen that mentioned here. When I looked at the filter I thought, back in 97 Nissan used a significantly larger filter. Then I looked it up. Now many Nissans spec the smallest filter, 6607 size. Fairly ingenious I'd say.
