So I noticed today that my airbag light was on. I cycled the ignition and it flashed 3 and 3 for Driver side seatbelt pretensioner fault.
I connected Forscan and Got B2292 which corresponds to the same issue. I went into the Restraint Control Module PIDs and had it show me the resistance that it was seeing for the driver side and passenger side pretensioners.
Driver 6 ohm
Passenger 3 ohm
So if 3 ohm extra is enough to make it trip a light idk. Unfortunatly allll my tools are at work, including my DMM, so I couldnt check the wiring from the RCM to the plug as per the service manual to make sure it wasnt in the wiring. I will tomorrow though.
If it is the seatbelt module itself, has any one tried rebuild services like myairbags.com? It pretty obvious the seatbelt is tired anyway. Wont retract unless I push it up into the hole. Im tempted to try it.
Driver 6 ohm
Passenger 3 ohm
